Picture for 2005 Honda CRF230F
SPECS for 2005 Honda CRF230F:
ENGINE
Engine Type: 223cc air-cooled single-cylinder four-stroke
Bore and Stroke: 65.5mm x 66.2mm
Compression Ratio: 9.0:1
Valve Train: SOHC; two-valve
Carburetion: 26mm piston-valve
Ignition: CDI
DRIVE TRAIN
Transmission: Six-speed
Final Drive: #520 O-ring-sealed chain; 13T/50T
CHASSIS / SUSPENSION / BRAKES
Front Suspension: 37mm leading-axle Showa fork; 9.5-inch travel
Rear Suspension: Pro-Link Showa single-shock with spring-preload adjustability; 9.0-inch travel
Front Brake: Single 240mm disc
Rear Brake: Drum
Front Tire: 80/100-21
Rear Tire: 100/100-18
DIMENSIONS
Rake: 27.3 degrees
Trail: 112.0mm (4.4 inches)
Wheelbase: 54.1 inches
Seat Height: 34.1 inches
Ground Clearance: 11.7 inches
Dry Weight: 238.0 pounds
Fuel Capacity: 2.2 gallons, including 0.4-gallon reserve
ENGINE
Ignition: CDI
DRIVE TRAIN
Rear Brake: Drum
DIMENSIONS
Rake: 27.3 degrees
