Bottom end identification
Bottom end tips and mods
borntworide
Post by borntworide »
I am looking at used bottom end for my 97 kx 250 , its on eBay is there any way to tell what year without the side cover with vin?
Re: Bottom end identification
Cylinder ID and carb ID
borntworide
It's just a lower end ,no cylinder , head or side cover! That's why i was wondering if there was a way to determine what year it was from actually.
It can be narrowed down to a year range.
97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM
Is the engine apart?
borntworide
No the cases are not separated yet. Where is the case bolt missing from?
borntworide
Finally got the lower half after all that the engine is on it. For some reason I had it stuck in my head engine number was on the side cover not the case.
KX250KE017363
If you had the cylinder or carb we could nail the year.
SHIFT FORK ROD GUIDE SHAFTS 1995 9.98MM OD
SHIFT FORK ROD GUIDE SHAFTS 1996-1998 11.89MM OD
borntworide
I see what you mean with the extra bolt, my case and cover do not match. From what you stated the lower end is 97 up and the cover is 96 down? Is that correct or do I have it backward? The bolt in the red circle goes all the way through the right side cover to the case, the red arrow is the extra bolt hole.
Posting pic for clarification
kx case.JPG (153.68 KiB) Viewed 12636 times
I don't know, I'm a 500 guy :lol:
borntworide
:lol:
Return to “Bottom end”
