YZ250F YAMAHA ENGINE, PARTS, AND FRAME Identification
page
In an effort to help fellow bikers properly ID their bike I have provided the following information on VIN ( Vehicle Identification Number ) , Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix it.
This information is not intended for use outside of this web site or for publication.
Please scroll to the right as there is a lot of data :-)
| YEAR | TYPE | VIN FRAME USA | ENGINE ID | AIR BOX (NO BOOT) | YEAR | AIR BOX BOOT | ENGINE CASE LEFT | ENGINE CASE RIGHT | YEAR | CABLE (CHOKE) | CABLE (CLUTCH) | YEAR | CABLE THROTTLE | CAM SHAFT EXHAUST 2 LOBES | YEAR | CAM SHAFT INTAKE 3 LOBES | CARBURETOR | YEAR | CARBURETOR BOOT | CARBURETOR ACCELERATOR DIAPHRAGM COVER | YEAR | CARBURETOR THROTTLE SENSOR ASSEMBLY | CARBURETOR VACUUM CONTROL VALVE | YEAR | CDI | YEAR | CHAIN GUIDE ALUMINUM BODY (THRUST COVER) | CHAIN GUIDE PLASTIC INSERT (CHAIN SUPPORT) | YEAR | CHAIN PULLER BLOCKS | CHAIN SLIDER | YEAR | CLUTCH ARM (PUSH LEVER) | CLUTCH BASKET (PRIMARY DRIVEN GEAR) | YEAR | CLUTCH COVER INNER | CLUTCH COVER OUTER | YEAR | CLUTCH INNER HUB BOSS | CLUTCH PERCH HOLDER | YEAR | CLUTCH PLATES FRICTION | YEAR | CLUTCH PRESSURE PLATE OUTER | COIL | YEAR | COUNTER BALANCE SHAFT | COUNTER SPROCKET GUARD ALUMINUM | YEAR | COUNTER SPROCKET GUARD PLASTIC | CRANK SHAFT | YEAR | CRANK SHAFT HOT RODS | YEAR | CRANK SHAFT WISECO | CYLINDER | YEAR | ENGINE MOUNTS UPPER | EXHAUST HEADER | YEAR | EXHAUST HEADER FMF POWER BOMB | YEAR | EXHAUST MUFFLER | FLY WHEEL ROTOR | YEAR | FORK INFO | YEAR | FORK SEAL SIZES | FORK GUARDS | YEAR | FORK GUARD MOUNTS | YEAR | FRAME GUARD WORKS CONNECTION | FRONT AXLE | YEAR | FRONT BRAKE CALIPER | FRONT BRAKE CALIPER MOUNT | YEAR | FRONT BRAKE MASTER CYLINDER | FRONT BRAKE ROTOR | YEAR | FRONT FENDER | YEAR | FRONT HUB | YEAR | FRONT RIM | YEAR | GAS TANK | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | YEAR | MUD FLAP | NEUTRAL SWITCH ASSEMBLY | YEAR | NUMBER PLATE | OIL FILLER PLUG | OIL PUMP HOUSING | YEAR | OIL PUMP IDLE GEAR | OIL PUMP ROTOR ASSEMBLY | OIL TANK | YEAR | PISTON | PISTON WISECO | YEAR | PRIMARY CRANK DRIVE GEAR | RADIATOR HOSES | YEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR SCREEN LEFT | RADIATOR SCREEN RIGHT | YEAR | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | REAR AXLE | YEAR | REAR AXLE SPACERS COLLARS | REAR BRAKE CALIPER GUARD | YEAR | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | YEAR | REAR BRAKE LEVER | REAR BRAKE MASTER CYLINDER | REAR FENDER | YEAR | REAR HUB | YEAR | SEAT | SHIFT DRUM | SHIFT FORKS | SHIFT LEVER | SHIFT SHAFT | YEAR | SHOCK | SHOCK ARM (RELAY) | SHOCK ARM LINKAGE (CONNECTING ROD) | YEAR | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE HOUSING | YEAR | TIMING CHAIN TENSIONER | TRANSMISSION | TRANSMISSION MAIN SHAFT | TRANSMISSION DRIVE AXLE | YEAR | TRIPLE TREE UPPER | YEAR | WATER PUMP IMPELLER | WATER PUMP IMPELLER SHAFT | YEAR |
| 2001 | YZ250F | 5NL00 Y-1 G321E-01#### | 2001 | FITS 00-02 YZ426F, 01-02 YZ250F, WR250F, WR426F, 00 WR400F - 5JG-14453-00-00 | FITS 01 YZ250F WR250F - 5NL-15150-00-00 | FITS 01 YZ250F WR250F - 5NL-15150-00-00 | 2001 | 2001 | FITS 01-02 YZ250F - 5NL-12180-00-00 - NO AUTO DECOMPRESS | 2001 | FITS 01-02 YZ250F - 5NL-12170-00-00 | KEIHIN FLAT CR 5NL1 | 2001 | FITS 01 YZ250F WR250F 5NL-13597-00-00 | 2001 | FITS 01-05 YZ250F, 00-02 YZ426F, 03-09 YZ450F, 01-06 WR250F, 00 WR400F, 01-02 WR426F, 03-06 WR450F - 5JG-14388-00-00 | 2001 | 5NL FITS 2001 | 2001 | 2001 | FITS 01-02 YZ250 YZ250 YZ250F YZ426F WR250F WR426F - 5MV-22151-00-00 | 2001 | FITS 01-06 YZ250F WR250F, 01-02 YZ426F WR426F - 5JG-16381-00-00 | 2001 | FITS 01-02 YZ250F WR250F - 5NL-15431-00-00 | FITS 01-06 YZ250F - 01-07 WR250F - 5NL-15415-00-00 | 2001 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | 2001 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2001 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 96-98 YZ250, 01-02 YZ250F WR250F - 4SR-82310-00-00 | 2001 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2001 | FITS 01-03 YZ250F WR250F, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F - 5BE-15421-00-00 | FITS 01 YZ250F - 5NL-11400-00-00 | 2001 | ROD ONLY FITS 01-02 YZ250F - 8618 | 2001 | N/A | 2001 | FITS 01-05 YZ250F, 01-06 WR250F - 5NL-21425-10-00 | FITS 01-03 YZ250F WR250F 5NL-14611-00-00 - INTAKE END OD 43-43.72MM - OUTLET END WITH COLLAR OD 43.5MM - PIPE OD 38.6-38.82MM | 2001 | 40073 - FITS 01-06 YZ250F | 2001 | F5J - FITS 01-02 YZ250F - 5JG-85550-11-00 | 2001 | USD - Y5DH-L Y5DH-R - 46MM CHROME OD - 37" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE C/L 102MM - AXLE 20MM & 25MM | 2001 | 46mm x 58mm x 10.5 | 2001 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | 2001 | 15-270 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | 2001 | NISSIN ML3 2 - FITS 01-02 YZ250 YZ250F YZ426F WR250F WR426F - 5MV-2580T-10-00 | 2001 | FITS 01 YZ125 YZ250 YZ250F YZ426F WR250F WR450F YZ80 - 5MV-W2587-00-00 | 2001 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2001 | 2001 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | 2001 | 5JG - FITS 01-02 YZ250F YZ426F – 5JG-24110-50-00 | FITS 01 YZ250F WR250F 5NL-11102-00-00 | 2001 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 01-02 YZ250F WR250F 5NL-15620-00-00 | FITS 01-05 YZ250F WR250F - 5NL-15601-00-00 | 2001 | 2001 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | 2001 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2001 | FITS 01-04 YZ250F - 77MM BORE - 53.6MM STROKE - 12.7:1 CR - 4872M07700 | 2001 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | 2001 | FITS 01-03 YZ250F - 5NL-1240A-00-00 | FITS 01-03 YZ250F – 5NL-12461-00-00 | 2001 | 2001 | 2001 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2001 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR426F - 4GY-27491-00-00 | 2001 | 2001 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | 2001 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2001 | PAN # 5BE-00 FITS 01 YZ250F YZ426F - 5JG-24710-50-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2001 | 2001 | FITS 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F - 5BE-21711-00-00 COVER | FITS 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F - 5BE-21721-00-00 | 2001 | 5BE01 | FITS 01 YZ125 YZ250 YZ250F YZ426F WR250F WR450F - 5MV-22110-00-00 | 2001 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2001 | FITS 98-99 YZ400F, 00-02 YZ426F, 98-00 WR400F, 01-02 YZ250F WR426F - 5BE-12210-00-00 | FITS 01-03 YZ250F 01 WR25F - 5NL-17421-00-00 | 2001 | 5NL – FITS 01-03 YZ250F, 02-03 YZ125 YZ250, 02 YZ426F - 5NL-23435-00-00 | 2001 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | 2001 | ||||||||||||||||||||||||||||||||||||||||||||
| 2002 | YZ250F | JYACG10C12A01#### | 5NL00 Y-1 G321E-01#### | 2002 | FITS 00-02 YZ426F, 01-02 YZ250F, WR250F, WR426F, 00 WR400F - 5JG-14453-00-00 | FITS 02 YZ250R WR250F - 5SG-15150-00-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2002 | 2002 | FITS 01-02 YZ250F - 5NL-12180-00-00 - NO AUTO DECOMPRESS | 2002 | FITS 01-02 YZ250F - 5NL-12170-00-00 | KEIHIN FLAT CR 5SG1 00QA07 | 2002 | FITS 02 YZ250F WR250F 5NL-13597-10-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2002 | FITS 01-05 YZ250F, 00-02 YZ426F, 03-09 YZ450F, 01-06 WR250F, 00 WR400F, 01-02 WR426F, 03-06 WR450F - 5JG-14388-00-00 | 2002 | FITS 02 YZ250F - 5SG-85540-00-00 | 2002 | 2002 | FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00 | FITS 01-02 YZ250 YZ250 YZ250F YZ426F WR250F WR426F - 5MV-22151-00-00 | 2002 | FITS 01-06 YZ250F WR250F, 01-02 YZ426F WR426F - 5JG-16381-00-00 | FITS 02-07 YZ250F, 02-09 WR250F - 5NL-16150-10-00 | 2002 | FITS 01-02 YZ250F WR250F - 5NL-15431-00-00 | FITS 01-06 YZ250F - 01-07 WR250F - 5NL-15415-00-00 | 2002 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | 2002 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2002 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 96-98 YZ250, 01-02 YZ250F WR250F - 4SR-82310-00-00 | 2002 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2002 | FITS 01-03 YZ250F WR250F, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F - 5BE-15421-00-00 | FITS 01-02 WR250F, 02 YZ250F - 5NL-11400-10-00 | 2002 | ROD ONLY FITS 01-02 YZ250F - 8618 | 2002 | N/A | 2002 | FITS 01-05 YZ250F, 01-06 WR250F - 5NL-21425-10-00 | FITS 01-03 YZ250F WR250F 5NL-14611-00-00 - INTAKE END OD 43-43.72MM - OUTLET END WITH COLLAR OD 43.5MM - PIPE OD 38.6-38.82MM | 2002 | 40073 - FITS 01-06 YZ250F | 2002 | F5J - FITS 01-02 YZ250F - 5JG-85550-11-00 | 2002 | USD - Y5DH-L Y5DH-R - 46MM CHROME OD - 37" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE C/L 102MM - AXLE 20MM & 25MM | 2002 | 46mm x 58mm x 10.5 | 2002 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | 2002 | 15-270 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | 2002 | NISSIN ML3 2 - FITS 01-02 YZ250 YZ250F YZ426F WR250F WR426F - 5MV-2580T-10-00 | 2002 | FITS 02 YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-W2587-01-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2002 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2002 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2002 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | 2002 | 5JG - FITS 01-02 YZ250F YZ426F – 5JG-24110-50-00 | FITS 02 YZ250F WR250F - 5NL-11102-11-00 | 2002 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 01-02 YZ250F WR250F 5NL-15620-00-00 | FITS 01-05 YZ250F WR250F - 5NL-15601-00-00 | 2002 | 2002 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2002 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2002 | FITS 01-04 YZ250F - 77MM BORE - 53.6MM STROKE - 12.7:1 CR - 4872M07700 | 2002 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | SET FITS 02-05 YZ250F, 02-06 WR250F - 5SG-12576-00-00 5SG-12577-00-00 5SG-12578-00-00 5SG-12579-00-00 | 2002 | FITS 01-03 YZ250F - 5NL-1240A-00-00 | FITS 01-03 YZ250F – 5NL-12461-00-00 | 2002 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | 2002 | 2002 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2002 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR426F - 4GY-27491-00-00 | 2002 | 2002 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | 5BE-21611-10-00 | 2002 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2002 | PAN # 5BE-00 - FITS 02 YZ250F YZ426F - 5SF-24710-00-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2002 | SPRING THICKNESS 11.2MM, OD 88.5MM, MOUNTED LENGTH 247MM - BODY OD 53.6MM – CHROME SHAFT OD 16MM – UPPER MOUNT 29.7MM HOLE ID 10MM – LOWER MOUNT 22.75MM, HOLE ID 10MM – EYE TO EYE 498MM (19.625”) | FITS 02-04 YZ125 YZ250 YZ250F WR250F, 02 YZ426F WR426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 5NY 0112EK - FITS 02-03 YZ125 YZ250 YZ250F, 02 YZ426F WR426F, 03 YZ450F WR450F - 5NY-2217F-00-00 | 2002 | FITS 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F - 5BE-21711-00-00 COVER | FITS 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F - 5BE-21721-00-00 | 2002 | FITS 02-04 YZ250F, 02 YZ426F, 03-04 YZ450F - 5SF-85560-00-00 | FITS 02 YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-22110-00-00 | 2002 | FITS 02 YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-22141-00-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2002 | FITS 98-99 YZ400F, 00-02 YZ426F, 98-00 WR400F, 01-02 YZ250F WR426F - 5BE-12210-00-00 | SHAFTS FOR 02-03 YZ250F, GEARS | FITS 02-07 YZ250F - 5NL-17411-10-00 | FITS 01-03 YZ250F 01 WR25F - 5NL-17421-00-00 | 2002 | 5NL – FITS 01-03 YZ250F, 02-03 YZ125 YZ250, 02 YZ426F - 5NL-23435-00-00 | 2002 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | 2002 | ||||||||||||||||||||||||||||
| 2003 | YZ250F | JYACG14C43A00#### | 5UL-00 Y-1 G329E-00#### | FITS 03 YZ250F YZ450F - 5TA-14401-00-00 | 2003 | FITS 03-04 YZ250F YZ450F WR450F WR250F - 5TA-14453-00-00 | FITS 03 YZ250F - 5UL-15150-00-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2003 | FITS 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5TA-26334-00-00 | FITS 03-05 YZ250F, 04-05 YZ450F - 5UL-26335-00-00 | 2003 | FITS 03 YZ250F YZ450F WR250F WR450F - 5TA-26302-01-00 | FITS 03-04 YZ250F - 5UL-12180-00-00 | 2003 | FITS 03-04 YZ250F - 5UL-12170-00-00 | KEIHIN FLAT CR 5UL1 37MM | 2003 | FITS 03-04 YZ250F WR250F 5UL-13597-00-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2003 | FITS 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5TA-85885-00-00 | FITS 01-05 YZ250F, 00-02 YZ426F, 03-09 YZ450F, 01-06 WR250F, 00 WR400F, 01-02 WR426F, 03-06 WR450F - 5JG-14388-00-00 | 2003 | FITS 03 YZ250F - 5UL-85540-00-00 | 2003 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22128-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22199-00-00 | 2003 | FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-22151-00-00 | 2003 | FITS 01-06 YZ250F WR250F, 01-02 YZ426F WR426F - 5JG-16381-00-00 | FITS 02-07 YZ250F, 02-09 WR250F - 5NL-16150-10-00 | 2003 | FITS 03-05 YZ250F, 03-06 WR250F - 5NL-15431-10-00 | FITS 01-06 YZ250F - 01-07 WR250F - 5NL-15415-00-00 | 2003 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | FITS 03 YZ250F YZ450F - 5HD-82911-00-00 5TA-82913-00-00 | 2003 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2003 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 03 YZ250F WR250 - 5UL-82310-00-00 | 2003 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2003 | FITS 01-03 YZ250F WR250F, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F - 5BE-15421-00-00 | FITS 03 YZ250F - 5UL-11400-00-00 | 2003 | FITS 03-2013 YZ250F - 4049 | 2003 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | FITS 03 YZ250F WR250F - 5UL-11311-00-00 | 2003 | FITS 01-05 YZ250F, 01-06 WR250F - 5NL-21425-10-00 | FITS 01-03 YZ250F WR250F 5NL-14611-00-00 - INTAKE END OD 43-43.72MM - OUTLET END WITH COLLAR OD 43.5MM - PIPE OD 38.6-38.82MM | 2003 | 40073 - FITS 01-06 YZ250F | 2003 | FITS 03 YZ250F - 5UL-14753-00-00 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2003 | USD - Y5DH-L Y5DH-R - 46MM CHROME OD - 37" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE C/L 102MM - AXLE 20MM & 25MM | 2003 | 46mm x 58mm x 10.5 | SET FITS 03-04 YZ250F YZ450F, 04 YZ125 YZ250 - 5TA-2314J-00-00 5TA-2314H-00-00 | 2003 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | 2003 | 15-272 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | 2003 | NISSIN - 2V3 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-2580T-00-00 | NISSIN 3 A 1 1 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F | 2003 | NISSIN 2V4 - FITS 03 YZ125 YZ250 YZ250F YZ450F WR250F WR450F YZ85 - 5UN-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2003 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2003 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2003 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | 2003 | 5TA - FITS 03 YZ250F YZ450F - 5TA-24110-00-00 | FITS 03 YZ250F WR250F - 5NL-11102-11-00 | 2003 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 03 YZ250F WR250F - 5NL-15620-01-00 | FITS 01-05 YZ250F WR250F - 5NL-15601-00-00 | 2003 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 03-05 YZ250F YZ450F - 5TA-82540-00-00 | 2003 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2003 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2003 | FITS 03-04 YZ250 WR250F - 5NL-11631-10-00 - 77MM STD BORE | FITS 01-04 YZ250F - 77MM BORE - 53.6MM STROKE - 12.7:1 CR - 4872M07700 | 2003 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | SET FITS 02-05 YZ250F, 02-06 WR250F - 5SG-12576-00-00 5SG-12577-00-00 5SG-12578-00-00 5SG-12579-00-00 | 2003 | FITS 01-03 YZ250F - 5NL-1240A-00-00 | FITS 01-03 YZ250F – 5NL-12461-00-00 | 2003 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | 2003 | FITS 03-05 YZ250F YZ450F, 05-06 WR250F WR450F - 5TA-21730-00-00 | FITS 03-05 YZ250F YZ450F, 05-06 WR250F WR450F - 5TA-21740-00-00 | 2003 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2003 | FITS 03-05 YZ125 YZ250 YZ250F YZ450F, 03 WR250F WR450F - 5UN-25383-00-00 | FITS 03-05 YZ250F YZ450F WR250F WR450F, 04-05 YZ125 YZ250 - 5TA-27491-00-00 | 2003 | FITS 03-04 YZ250F YZ450F 04 WR250F WR450F - 5UN-2580W-20-00 | SOLD WITH CALIPER ONLY - 5UN-2580W-00-00 - FITS 03 YZ250 YZ250F YZ450F | 2003 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 03-04 YZ125 YZ250, 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5UN-2583V-00-00 | FITS 03 YZ250F YZ450F - 5TA-21610-00-00 | 2003 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2003 | PAN # 5TA-00 - FITS 03 YZ250F YZ450F - 5TA-24710-00-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18110-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18101-00-00 | 2003 | FITS 03 YZ250F - 5UL-22210-00-00 | FITS 02-04 YZ125 YZ250 YZ250F WR250F, 02 YZ426F WR426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 5NY 0112EK - FITS 02-03 YZ125 YZ250 YZ250F, 02 YZ426F WR426F, 03 YZ450F WR450F - 5NY-2217F-00-00 | 2003 | FITS 03 YZ250F YZ450F - 5TA-21711-00-00 | FITS 03-05 YZ250F YZ450F - 5TA-21721-00-00 | 2003 | FITS 02-04 YZ250F, 02 YZ426F, 03-04 YZ450F - 5SF-85560-00-00 | FITS 03-06 YZ250F | FITS 03 YZ250F YZ450F - 5TA-21190-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5UN-22110-00-00 | 2003 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5NY-22141-01-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2003 | FITS 03-05 YZ250F, 03-05 YZ450F, 03-06 WR250F WR450F - 5TA-12210-00-00 | SHAFTS FOR 02-03 YZ250F, GEARS | FITS 02-07 YZ250F - 5NL-17411-10-00 | FITS 01-03 YZ250F 01 WR25F - 5NL-17421-00-00 | 2003 | 5NL – FITS 01-03 YZ250F, 02-03 YZ125 YZ250, 02 YZ426F - 5NL-23435-00-00 | 2003 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | 2003 | ||
| 2004 | YZ250F | 5XC00 Y-1 G342E-00#### | FITS 04-05 YZ250F YZ450F - 5TA-14401-01-00 | 2004 | FITS 03-04 YZ250F YZ450F WR450F WR250F - 5TA-14453-00-00 | FITS 04-05 YZ250F - 5XC-15150-00-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2004 | FITS 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5TA-26334-00-00 | FITS 03-05 YZ250F, 04-05 YZ450F - 5UL-26335-00-00 | 2004 | FITS 04-05 YZ250F YZ450F, 04-06 WR250F WR450F - 5XD-26302-00-00 | FITS 03-04 YZ250F - 5UL-12180-00-00 | 2004 | FITS 03-04 YZ250F - 5UL-12170-00-00 | KEIHIN FLAT CR 5XC1 - 37MM | 2004 | FITS 03-04 YZ250F WR250F 5UL-13597-00-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2004 | FITS 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5TA-85885-00-00 | FITS 01-05 YZ250F, 00-02 YZ426F, 03-09 YZ450F, 01-06 WR250F, 00 WR400F, 01-02 WR426F, 03-06 WR450F - 5JG-14388-00-00 | 2004 | 5XC - FITS 04 YZ250F - 5XC-85540-00-00 | 2004 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22128-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22199-00-00 | 2004 | FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-22151-00-00 | 2004 | FITS 01-06 YZ250F WR250F, 01-02 YZ426F WR426F - 5JG-16381-00-00 | FITS 02-07 YZ250F, 02-09 WR250F - 5NL-16150-10-00 | 2004 | FITS 03-05 YZ250F, 03-06 WR250F - 5NL-15431-10-00 | FITS 01-06 YZ250F - 01-07 WR250F - 5NL-15415-00-00 | 2004 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | 2004 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2004 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | DENSO 129700-4760 FITS 04-09 YZ250F, 04-11 WR250F - 5UL-82310-10-00 | 2004 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2004 | FITS 04-05 YZ250F - 5XC-11400-00-00 | 2004 | FITS 03-2013 YZ250F - 4049 | 2004 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | 5XC | 2004 | FITS 01-05 YZ250F, 01-06 WR250F - 5NL-21425-10-00 | 2004 | 40073 - FITS 01-06 YZ250F | 2004 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2004 | USD – YZ-L YZ-R – 48MM CHROME OD – C/L 36.75” - UPPER 55.9MM – LOWER 59.2MM – BRAKE C/L 102MM – AXLE 25MM & 20MM | 2004 | 48mm x 58mm x 8.5/10 | SET FITS 03-04 YZ250F YZ450F, 04 YZ125 YZ250 - 5TA-2314J-00-00 5TA-2314H-00-00 | 2004 | 2004 | 15-273 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | 2004 | NISSIN - 2V3 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-2580T-00-00 | NISSIN 3 A 1 1 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F | 2004 | FITS 04-06 YZ125 YZ250, 04-11 YZ85, 04-05 YZ250F YZ450F WR250F WR450F - 5XE-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2004 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2004 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2004 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | 2004 | 2004 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 01-05 YZ250F WR250F - 5NL-15601-00-00 | 2004 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 03-05 YZ250F YZ450F - 5TA-82540-00-00 | 2004 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2004 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2004 | FITS 03-04 YZ250 WR250F - 5NL-11631-10-00 - 77MM STD BORE | FITS 01-04 YZ250F - 77MM BORE - 53.6MM STROKE - 12.7:1 CR - 4872M07700 | 2004 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | SET FITS 02-05 YZ250F, 02-06 WR250F - 5SG-12576-00-00 5SG-12577-00-00 5SG-12578-00-00 5SG-12579-00-00 | 2004 | FITS 04-05 YZ250 05-06 WR250F - 5NL-1240A-10-00 | FITS 04-05 YZ250, 05-06 WR250F - 5NL-12461-10-00 | 2004 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | 2004 | FITS 03-05 YZ250F YZ450F, 05-06 WR250F WR450F - 5TA-21730-00-00 | FITS 03-05 YZ250F YZ450F, 05-06 WR250F WR450F - 5TA-21740-00-00 | 2004 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2004 | FITS 03-05 YZ125 YZ250 YZ250F YZ450F, 03 WR250F WR450F - 5UN-25383-00-00 | FITS 03-05 YZ250F YZ450F WR250F WR450F, 04-05 YZ125 YZ250 - 5TA-27491-00-00 | 2004 | FITS 03-04 YZ250F YZ450F 04 WR250F WR450F - 5UN-2580W-20-00 | SOLD WITH CALIPER ONLY - 5UN-2580W-20-00 - FITS 04 YZ250 YZ250F YZ450F | 2004 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 03-04 YZ125 YZ250, 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5UN-2583V-00-00 | 2004 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2004 | PAN # 5TA-00 - FITS 04-05 YZ250F YZ450F - 5XD-24710-00-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18110-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18101-00-00 | 2004 | FITS 02-04 YZ125 YZ250 YZ250F WR250F, 02 YZ426F WR426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 2004 | FITS 03 YZ250F YZ450F - 5TA-21711-00-00 | FITS 03-05 YZ250F YZ450F - 5TA-21721-00-00 | 2004 | FITS 02-04 YZ250F, 02 YZ426F, 03-04 YZ450F - 5SF-85560-00-00 | FITS 03-06 YZ250F | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5UN-22110-00-00 | 2004 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5NY-22141-01-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2004 | FITS 03-05 YZ250F, 03-05 YZ450F, 03-06 WR250F WR450F - 5TA-12210-00-00 | FITS 02-07 YZ250F - 5NL-17411-10-00 | 2004 | 2004 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2004 | |||||||||||||||||
| 2005 | YZ250F | JYACG21C05A00#### | 5NL00 Y-1 G321E-00#### | FITS 04-05 YZ250F YZ450F - 5TA-14401-01-00 | 2005 | FITS 04-05 YZ250F - 5XC-15150-00-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2005 | FITS 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5TA-26334-00-00 | FITS 03-05 YZ250F, 04-05 YZ450F - 5UL-26335-00-00 | 2005 | FITS 04-05 YZ250F YZ450F, 04-06 WR250F WR450F - 5XD-26302-00-00 | FITS 05-09 YZ250F - 5UL-12180-10-00 | 2005 | FITS 05-09 YZ250F - 5UL-12170-10-00 | KEIHIN FLAT CR 5XC5 - 37MM | 2005 | FITS 05 YZ250F, 05-06 WR250F 5XC-13597-00-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2005 | FITS 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5TA-85885-00-00 | FITS 01-05 YZ250F, 00-02 YZ426F, 03-09 YZ450F, 01-06 WR250F, 00 WR400F, 01-02 WR426F, 03-06 WR450F - 5JG-14388-00-00 | 2005 | FITS 05 YZ250F - 5XC-85540-50-00 | 2005 | 2005 | 2005 | FITS 01-06 YZ250F WR250F, 01-02 YZ426F WR426F - 5JG-16381-00-00 | FITS 02-07 YZ250F, 02-09 WR250F - 5NL-16150-10-00 | 2005 | FITS 03-05 YZ250F, 03-06 WR250F - 5NL-15431-10-00 | FITS 01-06 YZ250F - 01-07 WR250F - 5NL-15415-00-00 | 2005 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | 2005 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2005 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | DENSO 129700-4760 FITS 04-09 YZ250F, 04-11 WR250F - 5UL-82310-10-00 | 2005 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2005 | FITS 04-05 YZ250F - 5XC-11400-00-00 | 2005 | FITS 03-2013 YZ250F - 4049 | 2005 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | 5NL | 2005 | FITS 01-05 YZ250F, 01-06 WR250F - 5NL-21425-10-00 | 2005 | 40073 - FITS 01-06 YZ250F | 2005 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2005 | USD - 103-L 103-R2 - 48MM CHROME OD - C/L 37.25" - UPPER 55.9MM - LOWER 59.2MM - BRAKE C/L 102MM - AXLE 25MM & 20MM | 2005 | 48mm x 58mm x 8.5/10 | 2005 | 2005 | 15-273 | FITS 05 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-25181-00-00 | 2005 | FITS 05-07 YZ125 YZ250 YZ250F YZ450F, 05-11 WR250F WR450F - 1C3-2580T-00-00 | 2005 | FITS 04-06 YZ125 YZ250, 04-11 YZ85, 04-05 YZ250F YZ450F WR250F WR450F - 5XE-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2005 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2005 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2005 | 2005 | 2005 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 01-05 YZ250F WR250F - 5NL-15601-00-00 | 2005 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 03-05 YZ250F YZ450F - 5TA-82540-00-00 | 2005 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2005 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2005 | 2005 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | SET FITS 02-05 YZ250F, 02-06 WR250F - 5SG-12576-00-00 5SG-12577-00-00 5SG-12578-00-00 5SG-12579-00-00 | 2005 | FITS 04-05 YZ250 05-06 WR250F - 5NL-1240A-10-00 | FITS 04-05 YZ250, 05-06 WR250F - 5NL-12461-10-00 | 2005 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | 2005 | FITS 03-05 YZ250F YZ450F, 05-06 WR250F WR450F - 5TA-21730-00-00 | FITS 03-05 YZ250F YZ450F, 05-06 WR250F WR450F - 5TA-21740-00-00 | 2005 | FITS 05 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-25381-00-00 | 2005 | FITS 03-05 YZ125 YZ250 YZ250F YZ450F, 03 WR250F WR450F - 5UN-25383-00-00 | FITS 03-05 YZ250F YZ450F WR250F WR450F, 04-05 YZ125 YZ250 - 5TA-27491-00-00 | 2005 | 2005 | FITS 03-04 YZ125 YZ250, 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5UN-2583V-00-00 | 2005 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2005 | PAN # 5TA-00 - FITS 04-05 YZ250F YZ450F - 5XD-24710-00-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18110-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18101-00-00 | 2005 | SPRING THICKNESS 11.2MM, OD 88.5MM, MOUNTED LENGTH 247MM - BODY OD 53.6MM – CHROME SHAFT OD 16MM – UPPER MOUNT 25.5 MM (NO BUSHINGS) HOLE ID 10MM – LOWER MOUNT 22.75MM, HOLE ID 10MM – EYE TO EYE 498MM (19.625”) | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2005 | FITS 03 YZ250F YZ450F - 5TA-21711-00-00 | FITS 03-05 YZ250F YZ450F - 5TA-21721-00-00 | 2005 | FITS 03-06 YZ250F | FITS 05 YZ125 YZ250 YZ250F YZ450F WR250R WR450F - 1C3-22110-00-00 | 2005 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2005 | FITS 03-05 YZ250F, 03-05 YZ450F, 03-06 WR250F WR450F - 5TA-12210-00-00 | FITS 02-07 YZ250F - 5NL-17411-10-00 | 2005 | FITS 05 YZ125 YZ250 YZ250F YZ450F - 5XE-23435-20-00 - 190MM C/L TO C/L OF FORK TUBES | 2005 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2005 | ||||||||||||||||||||||||||||||
| 2006 | YZ250F | 2006 | FITS 06-10 YZ250F - 5NX-15111-01-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2006 | 2006 | FITS 05-09 YZ250F - 5UL-12180-10-00 | 2006 | FITS 05-09 YZ250F - 5UL-12170-10-00 | 2006 | FITS 06 YZ250F 5XC-13597-10-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2006 | 2006 | FITS 06 YZ250F - 5XC-85540-90-00 | 2006 | 2006 | 2006 | FITS 01-06 YZ250F WR250F, 01-02 YZ426F WR426F - 5JG-16381-00-00 | FITS 02-07 YZ250F, 02-09 WR250F - 5NL-16150-10-00 | 2006 | FITS 06 YZ250F - 5XC-15431-00-00 | FITS 01-06 YZ250F - 01-07 WR250F - 5NL-15415-00-00 | 2006 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | 2006 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2006 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | DENSO 129700-4760 FITS 04-09 YZ250F, 04-11 WR250F - 5UL-82310-10-00 | 2006 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2006 | FITS 06 YZ250F - 5XC-11400-10-00 | 2006 | FITS 03-2013 YZ250F - 4049 | 2006 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | FITS 06 YZ250F WR250F - 5XC-11311-01-00 | 2006 | FITS 06 YZ250F - 5XC-14611-10-00 | 2006 | 40073 - FITS 01-06 YZ250F | 2006 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2006 | 2006 | 48mm x 58mm x 8.5/10 | 2006 | 2006 | 15-275 | FITS 06-07 YZ125 YZ250 YZ450F, 06 YZ250F, 06-11 WR250F WR450F - 1C3-25181-10-00 | 2006 | FITS 05-07 YZ125 YZ250 YZ250F YZ450F, 05-11 WR250F WR450F - 1C3-2580T-00-00 | 2006 | FITS 07 YZ125 YZ250, 06 YZ250F, 06-07 YZ450F, 06-11 WR250F WR450F - 5XE-W2587-10-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2006 | FITS 06 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-21511-50-00 | 2006 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2006 | 2006 | 2006 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | 2006 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2006 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2006 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | FITS 06 YZ250F, 07-09 11 WR250F - 5XC-21751-90-00 | 2006 | 2006 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | 2006 | FITS 06 YZ250F - 5XC-1240A-90-00 | FITS 06 YZ250F - 5XC-12461-90-00 | 2006 | 2006 | 2006 | FITS 06 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-25381-10-00 | 2006 | 2006 | 2006 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | 2006 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2006 | PAN # 5XC-90 - FITS 06 YZ250F YZ450F - 5XC-24710-D0-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18110-00-00 | FITS 03-06 YZ250F WR250F - 5UL-18101-00-00 | 2006 | 2006 | FITS 06-09 YZ250F YZ450F - 5XC-21710-90-00 | FITS 06-09 YZ250F YZ450F – 5XC-21720-90-00 | 2006 | FITS 06-08 YZ250F - 5XC-85560-00-00 | FITS 03-06 YZ250F | FITS 06-07 YZ125 YZ250, 06 YZ250F YZ450F WR250F WR450F - 1C3-22110-50-00 | 2006 | FITS 06-11 YZ125 YZ250, 06-09 YZ250F YZ450F, 07-09 11 WR250F WR450F - 1C3-22141-10-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2006 | FITS 02-07 YZ250F - 5NL-17411-10-00 | 2006 | 2006 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2006 | ||||||||||||||||||||||||||||||||||||||||||||||||||
| 2007 | YZ250F | JYACG27C77A00#### | 5XC12 Y-1 G357E-00#### | 2007 | FITS 06-10 YZ250F - 5NX-15111-01-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2007 | 2007 | FITS 05-09 YZ250F - 5UL-12180-10-00 | 2007 | FITS 05-09 YZ250F - 5UL-12170-10-00 | KEIHIN FLAT CR 5XCG - 37MM | 2007 | FITS 07-11 YZ250F WR250F 5XC-13597-30-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2007 | 2007 | FITS 07 YZ250F - 5XC-85540-G0-00 | 2007 | 2007 | 2007 | FITS 02-07 YZ250F, 02-09 WR250F - 5NL-16150-10-00 | 2007 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5XC-15431-01-00 COVER | FITS 07 YZ250F - 5NL-15415-10-00 | 2007 | FITS 01-07 YZ250F, 01-09 WR250F - 5NL-16371-00-00 | 2007 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | 2007 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | DENSO 129700-4760 FITS 04-09 YZ250F, 04-11 WR250F - 5UL-82310-10-00 | 2007 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2007 | FITS 07-10 YZ250F - 5XC-11400-20-00 | 2007 | FITS 03-2013 YZ250F - 4049 | 2007 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | FITS 07-11 YZ250F 07-09 11 WR250F - 5XC-11311-10-00 | 2007 | FITS 07-09 YZ250F - 5XC-21425-G0-00 - 5XC-21426-G0-00 | FITS 07-08 YZ250F - 5XC-14611-20-00 | 2007 | 2007 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2007 | USD - Y5XC L, Y5XC R - 48MM CHROME OD - C/L 37.25" - UPPER 55.9MM - LOWER 59.2MM - BRAKE C/L 78MM - AXLE 25MM & 20MM | 2007 | 48mm x 58mm x 8.5/10 | 2007 | 2007 | 15-275 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | 2007 | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2007 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2007 | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2007 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2007 | 2007 | FITS 07-09 YZ250F YZ450F - 2S2-24110-70-00 | FITS 07-09 YZ250F - 5XC-11102-20-00 | 2007 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 07-09 YZ250F, 07-09, 11 WR250F - 5XC-15620-10-00 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5NL-15601-20-00 | 2007 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2007 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2007 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | FITS 07-09 YZ250F - 5XC-21751-G0-00 | 2007 | 2007 | FITS 01-07 YZ250F WR250F - 5NL-11536-00-00 | 2007 | FITS 07-09 YZ250F - 5XC-1240A-G0-00 | FITS 07-09 YZ250F - 5XC-12461-G0-00 | 2007 | 2007 | 2007 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2007 | 2007 | 2007 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | 2007 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2007 | PAN # 5XC-90 - FITS 07-08 YZ250F YZ450F - 2S2-24710-80-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2007 | FITS 07 YZ250F- 5XC-2217A-G0-00 | FITS 07 YZ250F - 5XC-2217F-G0-00 | 2007 | FITS 06-09 YZ250F YZ450F - 5XC-21710-90-00 | FITS 06-09 YZ250F YZ450F – 5XC-21720-90-00 | 2007 | FITS 06-08 YZ250F - 5XC-85560-00-00 | FITS 07 YZ250F - 5NL-15411-20-00 | FITS 07-08 YZ250F YZ450F WR250F WR450F - 2S2-22110-70-00 | 2007 | FITS 06-11 YZ125 YZ250, 06-09 YZ250F YZ450F, 07-09 11 WR250F WR450F - 1C3-22141-10-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2007 | FITS 02-07 YZ250F - 5NL-17411-10-00 | 2007 | 2007 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2007 | |||||||||||||||||||||||||||||||||||||||||||
| 2008 | YZ250F | 2008 | FITS 06-10 YZ250F - 5NX-15111-01-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2008 | 2008 | FITS 05-09 YZ250F - 5UL-12180-10-00 | 2008 | FITS 05-09 YZ250F - 5UL-12170-10-00 | 2008 | FITS 07-11 YZ250F WR250F 5XC-13597-30-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2008 | 2008 | FITS 08 YZ250F - 5XC-85540-L1-00 | 2008 | 2008 | 2008 | 2008 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5XC-15431-01-00 COVER | FITS 08-09 YZ250F, 08-09 11 WR250F - 5NL-15415-30-00 | 2008 | 2008 | FITS 08-11 YZ250F - 5XC-16321-00-00 | 2008 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | DENSO 129700-4760 FITS 04-09 YZ250F, 04-11 WR250F - 5UL-82310-10-00 | 2008 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2008 | FITS 07-10 YZ250F - 5XC-11400-20-00 | 2008 | FITS 03-2013 YZ250F - 4049 | 2008 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | FITS 07-11 YZ250F 07-09 11 WR250F - 5XC-11311-10-00 | 2008 | FITS 07-09 YZ250F - 5XC-21425-G0-00 - 5XC-21426-G0-00 | FITS 07-08 YZ250F - 5XC-14611-20-00 | 2008 | 2008 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2008 | 2008 | 48mm x 58mm x 8.5/10 | 2008 | 2008 | 15-275 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | 2008 | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2008 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2008 | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2008 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2008 | 2008 | FITS 07-09 YZ250F YZ450F - 2S2-24110-70-00 | FITS 07-09 YZ250F - 5XC-11102-20-00 | 2008 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 07-09 YZ250F, 07-09, 11 WR250F - 5XC-15620-10-00 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5NL-15601-20-00 | 2008 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2008 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | FITS 02-08 YZ250F WR250F - 5SG-13300-00-00 | 2008 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | FITS 07-09 YZ250F - 5XC-21751-G0-00 | 2008 | 2008 | 2008 | FITS 07-09 YZ250F - 5XC-1240A-G0-00 | FITS 07-09 YZ250F - 5XC-12461-G0-00 | 2008 | 2008 | 2008 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2008 | 2008 | 2008 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | 2008 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-11 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-08 YZ250F YZ450F, 99-00 WR400F, 01-02 WR426F, 03-11 WR450F – 5ET-25311-00-00 | 2008 | PAN # 5XC-90 - FITS 07-08 YZ250F YZ450F - 2S2-24710-80-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2008 | 2008 | FITS 06-09 YZ250F YZ450F - 5XC-21710-90-00 | FITS 06-09 YZ250F YZ450F – 5XC-21720-90-00 | 2008 | FITS 06-08 YZ250F - 5XC-85560-00-00 | FITS 08-09 YZ250F - 5XC-21190-L0-00 | FITS 07-08 YZ250F YZ450F WR250F WR450F - 2S2-22110-70-00 | 2008 | FITS 06-11 YZ125 YZ250, 06-09 YZ250F YZ450F, 07-09 11 WR250F WR450F - 1C3-22141-10-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2008 | 2008 | 2008 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2008 | |||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2009 | YZ250F | 2009 | FITS 06-10 YZ250F - 5NX-15111-01-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2009 | 2009 | FITS 05-09 YZ250F - 5UL-12180-10-00 | 2009 | FITS 05-09 YZ250F - 5UL-12170-10-00 | 2009 | FITS 07-11 YZ250F WR250F 5XC-13597-30-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2009 | 2009 | FITS 09 YZ250F - 5XC-85540-R0-00 | 2009 | 2009 | 2009 | 2009 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5XC-15431-01-00 COVER | FITS 08-09 YZ250F, 08-09 11 WR250F - 5NL-15415-30-00 | 2009 | 2009 | FITS 08-11 YZ250F - 5XC-16321-00-00 | 2009 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | DENSO 129700-4760 FITS 04-09 YZ250F, 04-11 WR250F - 5UL-82310-10-00 | 2009 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2009 | FITS 07-10 YZ250F - 5XC-11400-20-00 | 2009 | FITS 03-2013 YZ250F - 4049 | 2009 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | FITS 07-11 YZ250F 07-09 11 WR250F - 5XC-11311-10-00 | 2009 | FITS 07-09 YZ250F - 5XC-21425-G0-00 - 5XC-21426-G0-00 | 2009 | 2009 | F5TA00 FITS 03-09 YZ250F, 03-05 YZ450F - 5TA-85550-00-00 | 2009 | 2009 | 48mm x 58mm x 8.5/10 | 2009 | 2009 | 15-275 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | 2009 | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2009 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2009 | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2009 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2009 | 2009 | FITS 07-09 YZ250F YZ450F - 2S2-24110-70-00 | FITS 07-09 YZ250F - 5XC-11102-20-00 | 2009 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 07-09 YZ250F, 07-09, 11 WR250F - 5XC-15620-10-00 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5NL-15601-20-00 | 2009 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2009 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | 2009 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | FITS 07-09 YZ250F - 5XC-21751-G0-00 | 2009 | 2009 | 2009 | FITS 07-09 YZ250F - 5XC-1240A-G0-00 | FITS 07-09 YZ250F - 5XC-12461-G0-00 | 2009 | 2009 | 2009 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2009 | 2009 | 2009 | 2009 | 2009 | FITS 09 YZ250F YZ450F - 3-24710-20-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2009 | 2009 | FITS 06-09 YZ250F YZ450F - 5XC-21710-90-00 | FITS 06-09 YZ250F YZ450F – 5XC-21720-90-00 | 2009 | FITS 08-09 YZ250F - 5XC-21190-L0-00 | 2009 | FITS 06-11 YZ125 YZ250, 06-09 YZ250F YZ450F, 07-09 11 WR250F WR450F - 1C3-22141-10-00 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2009 | 2009 | 2009 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2009 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2010 | YZ250F | 2010 | FITS 06-10 YZ250F - 5NX-15111-01-00 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2010 | 2010 | FITS 10-11 YZ250F - 17D-12180-10-00 | 2010 | FITS 10-11 YZ250F - 17D-12170-10-00 | 2010 | FITS 07-11 YZ250F WR250F 5XC-13597-30-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2010 | 2010 | FITS 10-11 YZ250F - 17D-85540-50-00 | 2010 | 2010 | 2010 | 2010 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5XC-15431-01-00 COVER | FITS 10-11 YZ250F - 5NL-15415-40-00 | 2010 | 2010 | FITS 08-11 YZ250F - 5XC-16321-00-00 | 2010 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | 2010 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2010 | FITS 07-10 YZ250F - 5XC-11400-20-00 | 2010 | FITS 03-2013 YZ250F - 4049 | 2010 | FITS 03-10 YZ250F - WPC140 - 53.60mm STROKE | FITS 07-11 YZ250F 07-09 11 WR250F - 5XC-11311-10-00 | 2010 | 2010 | 2010 | FITS 2010 YZ250F - 17D-85550-00-00 | 2010 | 2010 | 48mm x 58mm x 8.5/10 | 2010 | 2010 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | 2010 | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2010 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2010 | 2010 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2010 | 2010 | 2010 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5NL-15601-20-00 | 2010 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2010 | FITS 03-10 YZ250F - 3Y1-15363-00-00 | 2010 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2010 | 2010 | 2010 | FITS 10-11 YZ250F - 17D-1240A-50-00 | FITS 10-11 YZ250F - 17D-12461-50-00 | 2010 | 2010 | 2010 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2010 | 2010 | 2010 | 2010 | 2010 | PAN # 17D-00S - FITS 10 YZ250F - 17D-24710-10-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2010 | 2010 | 2010 | 2010 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2010 | 2010 | 2010 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2010 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2011 | YZ250F | 2011 | FITS 02-11 YZ250F - 5NX-15121-00-00 | 2011 | 2011 | FITS 10-11 YZ250F - 17D-12180-10-00 | 2011 | FITS 10-11 YZ250F - 17D-12170-10-00 | 2011 | FITS 07-11 YZ250F WR250F 5XC-13597-30-00 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2011 | 2011 | FITS 10-11 YZ250F - 17D-85540-50-00 | 2011 | 2011 | 2011 | 2011 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5XC-15431-01-00 COVER | FITS 10-11 YZ250F - 5NL-15415-40-00 | 2011 | 2011 | FITS 08-11 YZ250F - 5XC-16321-00-00 | 2011 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | 2011 | FITS 01-11 YZ250F, 01-09 WR250F - 5NL-11455-00-00 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2011 | 2011 | FITS 03-2013 YZ250F - 4049 | 2011 | FITS 07-11 YZ250F 07-09 11 WR250F - 5XC-11311-10-00 | 2011 | 2011 | 2011 | FITS 2011 YZ250F - 17D-85550-10-00 | 2011 | 2011 | 48mm x 58mm x 8.5/10 | 2011 | 2011 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | 2011 | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2011 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | 2011 | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2011 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-11 - YZ426F 02 - YZ450F 03-11 - 5NY-25111-00-00 | 2011 | 2011 | 2011 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | FITS 07-11 YZ250F, 07-09 11 WR250F - 5NL-15601-20-00 | 2011 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2011 | 2011 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2011 | 2011 | 2011 | FITS 10-11 YZ250F - 17D-1240A-50-00 | FITS 10-11 YZ250F - 17D-12461-50-00 | 2011 | 2011 | 2011 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2011 | 2011 | 2011 | 2011 | 2011 | FITS 11 YZ250F - 17D-24710-D0-00 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2011 | 2011 | 2011 | 2011 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2011 | 2011 | 2011 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 04-11 YZ250F, 04-09 11 WR250F - 5XC-12459-00-00 | 2011 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2012 | YZ250F | 2012 | 2012 | 2012 | 2012 | 2012 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | 2012 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2012 | 2012 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | 2012 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2012 | 2012 | 2012 | 2012 | FITS 01-13 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03-13 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 5BE-26281-00-00 - 5BE-26282-00-00 | 2012 | 2012 | 2012 | 2012 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2013 | YZ250F | 2013 | 2013 | 2013 | 2013 | 2013 | FITS 02-13 YZ250F, 03-09 YZ450F, 02-05 WR250F, 01-02 WR426F, 03-11 WR450F - 5JG-14940-18-00 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | FITS 01-13 YZ250F, 02-13 WR250F - 5NL-17466-00-00 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | FITS 01-13 YZ250F WR250F - 5NL-15651-00-00 | 2013 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 2013 | 2013 | FITS 01-13 YZ250 WR250F - 5NL-13341-00-00 | FITS 01-13 YZ250F WR250F - 5NL-13320-00-00 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | FITS 01-13 YZ250F WR250F, 03-13 WR450F, 06-09 YZ450F - 5NL-18541-00-00 | FITS 01-13 YZ250F WR250F - 5NL-18501-00-00 5NL-18502-00-00 5NL-18503-00-00 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | 2013 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2014 | YZ250F | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | 2014 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| 2015 | YZ250F | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | 2015 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| YEAR | TYPE | VIN FRAME USA | ENGINE ID | AIR BOX (NO BOOT) | YEAR | AIR BOX BOOT | ENGINE CASE LEFT | ENGINE CASE RIGHT | YEAR | CABLE (CHOKE) | CABLE (CLUTCH) | YEAR | CABLE THROTTLE | CAM SHAFT EXHAUST 2 LOBES | YEAR | CAM SHAFT INTAKE 3 LOBES | CARBURETOR | YEAR | CARBURETOR BOOT | CARBURETOR ACCELERATOR DIAPHRAGM COVER | YEAR | CARBURETOR THROTTLE SENSOR ASSEMBLY | CARBURETOR VACUUM CONTROL VALVE | YEAR | CDI | YEAR | CHAIN GUIDE ALUMINUM BODY (THRUST COVER) | CHAIN GUIDE PLASTIC INSERT (CHAIN SUPPORT) | YEAR | CHAIN PULLER BLOCKS | CHAIN SLIDER | YEAR | CLUTCH ARM (PUSH LEVER) | CLUTCH BASKET (PRIMARY DRIVEN GEAR) | YEAR | CLUTCH COVER INNER | CLUTCH COVER OUTER | YEAR | CLUTCH INNER HUB BOSS | CLUTCH PERCH HOLDER | YEAR | CLUTCH PLATES FRICTION | YEAR | CLUTCH PRESSURE PLATE OUTER | COIL | YEAR | COUNTER BALANCE SHAFT | COUNTER SPROCKET GUARD ALUMINUM | YEAR | COUNTER SPROCKET GUARD PLASTIC | CRANK SHAFT | YEAR | CRANK SHAFT HOT RODS | YEAR | CRANK SHAFT WISECO | CYLINDER | YEAR | ENGINE MOUNTS UPPER | EXHAUST HEADER | YEAR | EXHAUST HEADER FMF POWER BOMB | YEAR | EXHAUST MUFFLER | FLY WHEEL ROTOR | YEAR | FORK INFO | YEAR | FORK SEAL SIZES | FORK GUARDS | YEAR | FORK GUARD MOUNTS | YEAR | FRAME GUARD WORKS CONNECTION | FRONT AXLE | YEAR | FRONT BRAKE CALIPER | FRONT BRAKE CALIPER MOUNT | YEAR | FRONT BRAKE MASTER CYLINDER | FRONT BRAKE ROTOR | YEAR | FRONT FENDER | YEAR | FRONT HUB | YEAR | FRONT RIM | YEAR | GAS TANK | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | YEAR | MUD FLAP | NEUTRAL SWITCH ASSEMBLY | YEAR | NUMBER PLATE | OIL FILLER PLUG | OIL PUMP HOUSING | YEAR | OIL PUMP IDLE GEAR | OIL PUMP ROTOR ASSEMBLY | OIL TANK | YEAR | PISTON | PISTON WISECO | YEAR | PRIMARY CRANK DRIVE GEAR | RADIATOR HOSES | YEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR SCREEN LEFT | RADIATOR SCREEN RIGHT | YEAR | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | REAR AXLE | YEAR | REAR AXLE SPACERS COLLARS | REAR BRAKE CALIPER GUARD | YEAR | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | YEAR | REAR BRAKE LEVER | REAR BRAKE MASTER CYLINDER | REAR FENDER | YEAR | REAR HUB | YEAR | SEAT | SHIFT DRUM | SHIFT FORKS | SHIFT LEVER | SHIFT SHAFT | YEAR | SHOCK | SHOCK ARM (RELAY) | SHOCK ARM LINKAGE (CONNECTING ROD) | YEAR | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE HOUSING | YEAR | TIMING CHAIN TENSIONER | TRANSMISSION | YEAR | TRIPLE TREE UPPER | YEAR | WATER PUMP IMPELLER | WATER PUMP IMPELLER SHAFT | YEAR |
