OEM-CYCLE
OEM-Cycle
Kawasaki KLX ENGINE, PARTS, AND FRAME Identification page
In an effort to help fellow bikers properly ID their bike I have provided the following information on VIN ( Vehicle Identification Number ) , Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix it.
This information is not intended for use outside of this web site or for publication.
Scroll to the right as there is a lot of data :-)
YEAR TYPE VIN FRAME USA ONLY ENGINE ID ENGINE CASES AIR BOX YEAR TYPE CAM SHAFT EXHAUST CAM SHAFT INTAKE CARBURETOR YEAR TYPE CDI CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH BASKET COIL YEAR TYPE CONDENSOR CRANK SHAFT CYLINDER EXHAUST HEADER EXHAUST MUFFLER FLY WHEEL ROTOR YEAR TYPE FOOT PEGS PASSENGER FOOT PEG PASSENGER MOUNTS YEAR TYPE FORK FORK GUARDS YEAR TYPE FORK GUARD MOUNTS FRONT AXLE FRONT BRAKE CALIPER YEAR TYPE FRONT BRAKE CALIPER MOUNT FRONT BRAKE LEVER FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE ROTOR FRONT HUB HEAD HEAD LIGHT BODY KICK IDLER GEAR YEAR TYPE KICK LEVER KICK LEVER SHAFT YEAR TYPE LEFT CONTROL SWITCH ONE WAY CLUTCH GEAR PISTON PRIMARY CRANK GEAR RADIATOR LEFT RADIATOR RIGHT REAR AXLE YEAR TYPE RADIATOR SHROUDS REAR HUB YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE YEAR TYPE REAR BRAKE MASTER CYLINDER REAR BRAKE ROTOR REAR WHEEL SPACERS YEAR TYPE SHOCK SIDE STAND YEAR TYPE STATOR SWING ARM SWING ARM PIN / AXLE YEAR TYPE TIMING CHAIN TENSIONER YEAR TYPE TRANSMISSION YEAR TYPE TRANSMISSION OUT PUT SHAFT TRIPLE TREE BOTTOM YEAR TYPE TRIPLE TREE TOP VOLTAGE REGULATOR WIRE HARNESS WATER PUMP IMPELLER YEAR TYPE
1993 KLX250R         1993 KLX250R       1993 KLX250R     FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1993 KLX250R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1993 KLX250R             1993 KLX250R     1993 KLX250R     1993 KLX250R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352   1993 KLX250R       1993 KLX250R           1993 KLX250R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1993 KLX250R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1993 KLX250R     1993 KLX250R     1993 KLX250R       1993 KLX250R     1993 KLX250R       1993 KLX250R   1993 KLX250R   1993 KLX250R     1993 KLX250R         1993 KLX250R
1994 KLX250R         1994 KLX250R   FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 KEIHIN CVK G188 32.5MM 1994 KLX250R   FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1994 KLX250R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1994 KLX250R             1994 KLX250R     1994 KLX250R   FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1994 KLX250R FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352   1994 KLX250R   FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1994 KLX250R OD: 9 7/8" - ID 4" - 4 HOLES ON A 4 9/16" BC - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07   FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 1994 KLX250R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1994 KLX250R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1994 KLX250R     1994 KLX250R FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R   1994 KLX250R       1994 KLX250R   FITS 94-96 KLX250R, 97-98 KLX300R 1994 KLX250R   FITS 94-96 KLX250   1994 KLX250R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 1994 KLX250R   1994 KLX250R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    1994 KLX250R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   1994 KLX250R
1995 KLX250R JKALXMD12SA00---- LX250DE111111     1995 KLX250R   FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 KEIHIN CVK G188 32.5MM 1995 KLX250R 21119-1376 071000-0520 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1995 KLX250R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1995 KLX250R             1995 KLX250R     1995 KLX250R   FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1995 KLX250R FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1995 KLX250R   FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1995 KLX250R     FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 1995 KLX250R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1995 KLX250R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1995 KLX250R   R-1237 - AXLE DIA 20MM - BRG TO BRG 128-129MM - ROTOR BC 6 ON 116MM - SPROCKET BC 6 ON 150MM - FITS 91-94 KDX250, 93-96 KLX650R, 94-96 KLX250R, 95-06 KDX200 1995 KLX250R     1995 KLX250R       1995 KLX250R   FITS 94-96 KLX250R, 97-98 KLX300R 1995 KLX250R   FITS 94-96 KLX250 FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1995 KLX250R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 1995 KLX250R   1995 KLX250R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    1995 KLX250R   SH623-12 FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   1995 KLX250R
1996 KLX250R         1996 KLX250R   FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 KEIHIN CVK G188 32.5MM 1996 KLX250R   FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1996 KLX250R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1996 KLX250R             1996 KLX250R     1996 KLX250R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1996 KLX250R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1996 KLX250R   FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186   1996 KLX250R     FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 1996 KLX250R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1996 KLX250R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1996 KLX250R     1996 KLX250R FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R   1996 KLX250R       1996 KLX250R   FITS 94-96 KLX250R, 97-98 KLX300R 1996 KLX250R FITS 96 KLX250, 97-07 KLX300 FITS 94-96 KLX250 FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1996 KLX250R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 1996 KLX250R   1996 KLX250R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    1996 KLX250R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   1996 KLX250R
1997 KLX300R         1997 KLX300R FITS 97-02 KLX300R, 06-10 KLX250S - 12044-1365 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 1997 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1997 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1997 KLX300R             1997 KLX300R     1997 KLX300R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1997 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 1997 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1997 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 1997 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1997 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1997 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1997 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   1997 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1997 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R FITS 94-96 KLX250R, 97-98 KLX300R 1997 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1997 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 1997 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 1997 KLX300R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    1997 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   1997 KLX300R
1998 KLX300R         1998 KLX300R FITS 97-02 KLX300R, 06-10 KLX250S - 12044-1365 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 1998 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1998 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1998 KLX300R             1998 KLX300R     1998 KLX300R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1998 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 1998 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1998 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 1998 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1998 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1998 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1998 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   1998 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1998 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R FITS 94-96 KLX250R, 97-98 KLX300R 1998 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1998 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 1998 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 1998 KLX300R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    1998 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   1998 KLX300R
1999 KLX300R         1999 KLX300R FITS 97-02 KLX300R, 06-10 KLX250S - 12044-1365 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 1999 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1999 KLX300R 1119 1KX250D-A201 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1999 KLX300R             1999 KLX300R     1999 KLX300R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1999 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 1999 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1999 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 1999 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 1999 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296       1999 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1999 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   1999 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1999 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R   1999 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1999 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 1999 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 1999 KLX300R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    1999 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   1999 KLX300R
2000 KLX300R         2000 KLX300R FITS 97-02 KLX300R, 06-10 KLX250S - 12044-1365 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2000 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2000 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2000 KLX300R             2000 KLX300R     2000 KLX300R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 2000 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 2000 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2000 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2000 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2000 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2000 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2000 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   2000 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 2000 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R   2000 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2000 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2000 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2000 KLX300R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    2000 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2000 KLX300R
2001 KLX300R         2001 KLX300R FITS 97-02 KLX300R, 06-10 KLX250S - 12044-1365 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2001 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2001 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2001 KLX300R             2001 KLX300R     2001 KLX300R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 2001 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 2001 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2001 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2001 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2001 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2001 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2001 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   2001 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 2001 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R   2001 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2001 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2001 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2001 KLX300R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    2001 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2001 KLX300R
2002 KLX300R         2002 KLX300R FITS 97-02 KLX300R, 06-10 KLX250S - 12044-1365 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2002 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2002 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2002 KLX300R             2002 KLX300R     2002 KLX300R USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 2002 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 2002 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2002 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   29T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2002 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2002 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2002 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2002 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   2002 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 2002 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R   2002 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2002 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2002 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2002 KLX300R FITS 96-96 KLX250R, 97-02 KLX300R - 13128-1213    2002 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2002 KLX300R
2003 KLX300R         2003 KLX300R FITS 03-07 KLX300R - 12044-1487 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2003 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2003 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2003 KLX300R             2003 KLX300R     2003 KLX300R   FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 2003 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 2003 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2003 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   28T - FITS 03-07 KLX300R - 59051-1400 / 29T FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2003 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2003 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2003 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2003 KLX300R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R   2003 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 2003 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R   2003 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2003 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2003 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2003 KLX300R     2003 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2003 KLX300R
2004 KLX300R         2004 KLX300R FITS 03-07 KLX300R - 12044-1487 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2004 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2004 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2004 KLX300R             2004 KLX300R     2004 KLX300R     2004 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352   2004 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2004 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   28T - FITS 03-07 KLX300R - 59051-1400 / 29T FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2004 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2004 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2004 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2004 KLX300R FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S   2004 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 2004 KLX300R Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R SIDE STAND 2004 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2004 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2004 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2004 KLX300R     2004 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2004 KLX300R
2005 KLX300R         2005 KLX300R FITS 03-07 KLX300R - 12044-1487 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2005 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2005 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2005 KLX300R             2005 KLX300R     2005 KLX300R     2005 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352   2005 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2005 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   28T - FITS 03-07 KLX300R - 59051-1400 / 29T FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2005 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2005 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2005 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2005 KLX300R FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S   2005 KLX300R     20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 2005 KLX300R     2005 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2005 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2005 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2005 KLX300R     2005 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2005 KLX300R
2006 KLX300R         2006 KLX300R FITS 03-07 KLX300R - 12044-1487 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327 FITS 97-06 KLX300R - 15003-1260 2006 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2006 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2006 KLX300R             2006 KLX300R     2006 KLX300R     2006 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352   2006 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2006 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   28T - FITS 03-07 KLX300R - 59051-1400 / 29T FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2006 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2006 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2006 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2006 KLX300R FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S   2006 KLX300R       2006 KLX300R     2006 KLX300R FITS 96 KLX250, 97-07 KLX300   FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2006 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2006 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2006 KLX300R     2006 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2006 KLX300R
2007 KLX300R         2007 KLX300R FITS 03-07 KLX300R - 12044-1487 FITS 94-96 KLX250R, 97-07 KLX300R, 06--12 KLX250S - 12044-1327   2007 KLX300R Denso 21119-1479 071000-1090 FITS 97-2007 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2007 KLX300R   129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 2007 KLX300R             2007 KLX300R     2007 KLX300R     2007 KLX300R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352   2007 KLX300R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2007 KLX300R 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 94-96 KLX250R, 97-07 KLX300R   28T - FITS 03-07 KLX300R - 59051-1400 / 29T FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 2007 KLX300R   FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 2007 KLX300R       22T - FITS 93-96 KLX250R, 97-07 KLX300R - 13097-1296     FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2007 KLX300R   R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 2007 KLX300R FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S   2007 KLX300R       2007 KLX300R     2007 KLX300R FITS 96 KLX250, 97-07 KLX300     2007 KLX300R FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S 2007 KLX300R Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 2007 KLX300R     2007 KLX300R     FITS 94-96 KLX250R, 97-07 KLX300R - 26030-1165   2007 KLX300R
2008 KLX450R         2008 KLX450R       2008 KLX450R       2008 KLX450R   FITS 05 KX250F, 06-08 KX450F, 08-09 KLX450R - 21121-0016 2008 KLX450R             2008 KLX450R     2008 KLX450R     2008 KLX450R       2008 KLX450R       2008 KLX450R           2008 KLX450R     2008 KLX450R               2008 KLX450R     2008 KLX450R     2008 KLX450R       2008 KLX450R     2008 KLX450R       2008 KLX450R   2008 KLX450R   2008 KLX450R     2008 KLX450R         2008 KLX450R
2009 KLX450R         2009 KLX450R       2009 KLX450R       2009 KLX450R   FITS 05 KX250F, 06-08 KX450F, 08-09 KLX450R - 21121-0016 2009 KLX450R             2009 KLX450R     2009 KLX450R     2009 KLX450R       2009 KLX450R       2009 KLX450R           2009 KLX450R     2009 KLX450R               2009 KLX450R     2009 KLX450R     2009 KLX450R       2009 KLX450R     2009 KLX450R       2009 KLX450R   2009 KLX450R   2009 KLX450R     2009 KLX450R         2009 KLX450R
1993 KLX650R   LX650AE01XXXX   FITS 93-96 KLX650R 1993 KLX650R     KEIHIN CVK 792 40MM - 15001-1792 - FITS 93-96 KLX650R 1993 KLX650R DENSO 21119-1368/1361 070000-2410/071000-0510 FITS 93-96 KLX650R – 21119-1361 - G/W TO W/Y IS 90-170 OHM FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1993 KLX650R FITS 93-96 KLX650R – 13095-1256 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1993 KLX650R FITS 93-96 KLX650R - 21013-1051 FITS 93 KLX650R ONLY 13031-1377 FITS 93-96 KLX650R – 11005-1719 – 100MM STD BORE FITS 93-96 KLX650R - 18049-1664 FITS 93-96 KLX650R - 18090-1300   1993 KLX650R     1993 KLX650R KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1993 KLX650R FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1993 KLX650R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1993 KLX650R ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 93-96 KLX650R – 11008-1270     1993 KLX650R FITS 93-96 KLX650R - 13064-1171 - SPLINE ID APPROX 19.75MM   1993 KLX650R     FITS 93-94 KLX650R – 13001-1417   FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 93 KLX650R, 93-96 KLX650C -  39061-1189   1993 KLX650R GREEN FITS 93-94 KLX650R - LH 49089-5170-6W, RH 49089-5209-6W R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1993 KLX650R FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1993 KLX650R FITS 91-93 KX125 KX250 KDX250, 93-95 KLX650R ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1993 KLX650R KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R   1993 KLX650R FITS 93-96 KLX650R - 21003-1252 - yellow to yellow wires .3-1.0 ohm - pickup coil 100-148 OHM   FITS 92-93 KX125 KX250, 93-96 KLX650R 1993 KLX650R FITS 93-96 KLX650 C & R 1993 KLX650R   1993 KLX650R   FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) 1993 KLX650R FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT)       1993 KLX650R
1994 KLX650R   LX650AE01XXXX   FITS 93-96 KLX650R 1994 KLX650R     KEIHIN CVK 792 40MM - 15001-1792 - FITS 93-96 KLX650R 1994 KLX650R DENSO 21119-1368/1361 070000-2410/071000-0510 FITS 93-96 KLX650R – 21119-1361 - G/W TO W/Y IS 90-170 OHM FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1994 KLX650R FITS 93-96 KLX650R – 13095-1256 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1994 KLX650R FITS 93-96 KLX650R - 21013-1051 FITS 94-96 KLX650R 13031-1380 FITS 93-96 KLX650R – 11005-1719 – 100MM STD BORE FITS 93-96 KLX650R - 18049-1664 FITS 93-96 KLX650R - 18090-1300   1994 KLX650R     1994 KLX650R KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1994 KLX650R FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1994 KLX650R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1994 KLX650R ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 93-96 KLX650R – 11008-1270     1994 KLX650R FITS 93-96 KLX650R - 13064-1171 - SPLINE ID APPROX 19.75MM   1994 KLX650R     FITS 93-94 KLX650R – 13001-1417   FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 94-96 KLX650R - 39061-1208   1994 KLX650R GREEN FITS 93-94 KLX650R - LH 49089-5170-6W, RH 49089-5209-6W R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1994 KLX650R FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1994 KLX650R FITS 91-93 KX125 KX250 KDX250, 93-95 KLX650R ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1994 KLX650R KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R   1994 KLX650R FITS 93-96 KLX650R - 21003-1252 - yellow to yellow wires .3-1.0 ohm - pickup coil 100-148 OHM   FITS 92-93 KX125 KX250, 93-96 KLX650R 1994 KLX650R FITS 93-96 KLX650 C & R 1994 KLX650R   1994 KLX650R   FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) 1994 KLX650R FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT)       1994 KLX650R
1995 KLX650R JKALXEA18SA00XXXX LX650AE01XXXX   FITS 93-96 KLX650R 1995 KLX650R     KEIHIN CVK 792 40MM - 15001-1792 - FITS 93-96 KLX650R 1995 KLX650R DENSO 21119-1368/1361 070000-2410/071000-0510 FITS 93-96 KLX650R – 21119-1361 - G/W TO W/Y IS 90-170 OHM FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1995 KLX650R FITS 93-96 KLX650R – 13095-1256 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1995 KLX650R FITS 93-96 KLX650R - 21013-1051 FITS 94-96 KLX650R 13031-1380 FITS 93-96 KLX650R – 11005-1719 – 100MM STD BORE FITS 93-96 KLX650R - 18049-1664 FITS 93-96 KLX650R - 18090-1300 DENSO 0320008261 1995 KLX650R     1995 KLX650R KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1995 KLX650R FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1995 KLX650R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1995 KLX650R ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 93-96 KLX650R – 11008-1270     1995 KLX650R FITS 93-96 KLX650R - 13064-1171 - SPLINE ID APPROX 19.75MM   1995 KLX650R     FITS 95-96 KLX650R – 13001-1438   FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 94-96 KLX650R - 39061-1208   1995 KLX650R GREEN FITS 95 KLX650R - LH 49089-5172-6W, RH 49089-5210-6W R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1995 KLX650R FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1995 KLX650R FITS 91-93 KX125 KX250 KDX250, 93-95 KLX650R ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1995 KLX650R KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R   1995 KLX650R FITS 93-96 KLX650R - 21003-1252 - yellow to yellow wires .3-1.0 ohm - pickup coil 100-148 OHM   FITS 92-93 KX125 KX250, 93-96 KLX650R 1995 KLX650R FITS 93-96 KLX650 C & R 1995 KLX650R   1995 KLX650R   FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) 1995 KLX650R FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT)       1995 KLX650R
1996 KLX650R   LX650AE01XXXX   FITS 93-96 KLX650R 1996 KLX650R     KEIHIN CVK 792 40MM - 15001-1792 - FITS 93-96 KLX650R 1996 KLX650R DENSO 21119-1368/1361 070000-2410/071000-0510 FITS 93-96 KLX650R – 21119-1361 - G/W TO W/Y IS 90-170 OHM FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1996 KLX650R FITS 93-96 KLX650R – 13095-1256 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 1996 KLX650R FITS 93-96 KLX650R - 21013-1051 FITS 94-96 KLX650R 13031-1380 FITS 93-96 KLX650R – 11005-1719 – 100MM STD BORE FITS 93-96 KLX650R - 18049-1664 FITS 93-96 KLX650R - 18090-1300   1996 KLX650R     1996 KLX650R KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R   1996 KLX650R   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 1996 KLX650R FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300     1996 KLX650R ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R  FITS 93-96 KLX650R – 11008-1270     1996 KLX650R FITS 93-96 KLX650R - 13064-1171 - SPLINE ID APPROX 19.75MM   1996 KLX650R     FITS 95-96 KLX650R – 13001-1438   FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 94-96 KLX650R - 39061-1208   1996 KLX650R GREEN FITS 96 KLX650R - LH 49089-5269-6W, RH 49089-5270-6W R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 1996 KLX650R FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1996 KLX650R   92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1996 KLX650R KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R   1996 KLX650R FITS 93-96 KLX650R - 21003-1252 - yellow to yellow wires .3-1.0 ohm - pickup coil 100-148 OHM   FITS 92-93 KX125 KX250, 93-96 KLX650R 1996 KLX650R FITS 93-96 KLX650 C & R 1996 KLX650R   1996 KLX650R   FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) 1996 KLX650R FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT)       1996 KLX650R
1993 KLX650C   LX650AE00XXXX     1993 KLX650C     CVK V327 1993 KLX650C       1993 KLX650C FITS 93-96 KLX650C – 13095-1274   1993 KLX650C   FITS 93-96 KLX650C 13031-1378         1993 KLX650C     1993 KLX650C KYB - USD - K328-R K555-L - CHROME OD 43MM - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650C FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1993 KLX650C   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1993 KLX650C FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300     1993 KLX650C ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R    FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 FITS 93-96 KLX650R 1993 KLX650C     1993 KLX650C   FITS KLX650C 1993-1996     FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 93 KLX650R, 93-96 KLX650C -  39061-1189   1993 KLX650C   R-1250 - AXLE DIA 20MM - BRG TO BRG 138MM - ROTOR 6 ON A 115MM BC - 36 SPOKES - FITS 93 KLX650C ONLY 1993 KLX650C FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1993 KLX650C   ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1993 KLX650C     1993 KLX650C FITS 93-96 KLX650C - 21003-1255     1993 KLX650C FITS 93-96 KLX650 C & R 1993 KLX650C   1993 KLX650C   FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) 1993 KLX650C FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT)       1993 KLX650C
1994 KLX650C   LX650AE00XXXX     1994 KLX650C       1994 KLX650C       1994 KLX650C FITS 93-96 KLX650C – 13095-1274   1994 KLX650C   FITS 93-96 KLX650C 13031-1378         1994 KLX650C     1994 KLX650C KYB - USD - K328-R K555-L - CHROME OD 43MM - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650C FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1994 KLX650C   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1994 KLX650C FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300     1994 KLX650C ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R    FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 FITS 93-96 KLX650R 1994 KLX650C     1994 KLX650C   FITS KLX650C 1993-1996     FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 93 KLX650R, 93-96 KLX650C -  39061-1189   1994 KLX650C   R-1250 - AXLE DIA 20MM - BRG TO BRG 111MM - ROTOR 6 ON A 115MM BC - 36 SPOKES - FITS 94-96 KLX650C - 41034-1234 1994 KLX650C FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1994 KLX650C   ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1994 KLX650C     1994 KLX650C FITS 93-96 KLX650C - 21003-1255     1994 KLX650C FITS 93-96 KLX650 C & R 1994 KLX650C   1994 KLX650C   FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) 1994 KLX650C FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT)       1994 KLX650C
1995 KLX650C   LX650AE00XXXX     1995 KLX650C       1995 KLX650C       1995 KLX650C FITS 93-96 KLX650C – 13095-1274   1995 KLX650C   FITS 93-96 KLX650C 13031-1378         1995 KLX650C     1995 KLX650C KYB - USD - K328-R K555-L - CHROME OD 43MM - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650C FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1995 KLX650C   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1995 KLX650C FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300     1995 KLX650C ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R    FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 FITS 93-96 KLX650R 1995 KLX650C     1995 KLX650C   FITS KLX650C 1993-1996     FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 93 KLX650R, 93-96 KLX650C -  39061-1189   1995 KLX650C   R-1250 - AXLE DIA 20MM - BRG TO BRG 111MM - ROTOR 6 ON A 115MM BC - 36 SPOKES - FITS 94-96 KLX650C - 41034-1234 1995 KLX650C FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1995 KLX650C   ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1995 KLX650C     1995 KLX650C FITS 93-96 KLX650C - 21003-1255     1995 KLX650C FITS 93-96 KLX650 C & R 1995 KLX650C   1995 KLX650C   FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) 1995 KLX650C FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT)       1995 KLX650C
1996 KLX650C   LX650AE00XXXX     1996 KLX650C       1996 KLX650C DENSO 21119-1368 07000-2410     1996 KLX650C FITS 93-96 KLX650C – 13095-1274   1996 KLX650C   FITS 93-96 KLX650C 13031-1378       32000-8020 10NX 1996 KLX650C     1996 KLX650C KYB - USD - K328-R K555-L - CHROME OD 43MM - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650C FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ 1996 KLX650C   FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352 FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R 1996 KLX650C FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300     1996 KLX650C ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R    FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 FITS 93-96 KLX650R 1996 KLX650C     1996 KLX650C   FITS KLX650C 1993-1996     FITS 93-96 KLX650R KLX650C - 39061-1188 - BOTH OUTLETS ARE 20MM OD, CORE W5.25 X H9.5 X T1.25 FITS 93 KLX650R, 93-96 KLX650C -  39061-1189   1996 KLX650C   R-1250 - AXLE DIA 20MM - BRG TO BRG 111MM - ROTOR 6 ON A 115MM BC - 36 SPOKES - FITS 94-96 KLX650C - 41034-1234 1996 KLX650C FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 1996 KLX650C   ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC - FITS 93-96 KLX650C, 93-95 KLX650R - 41080-1368 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1996 KLX650C     1996 KLX650C FITS 93-96 KLX650C - 21003-1255     1996 KLX650C FITS 93-96 KLX650 C & R 1996 KLX650C   1996 KLX650C   FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) 1996 KLX650C FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT)       1996 KLX650C
