OEM-CYCLE
OEM-Cycle
KX400, KX420, KX500 ENGINE PARTS AND FRAME IDENTIFICATION
In an effort to help fellow bikers properly ID their bike I have provided the following information on VIN ( Vehicle Identification Number ) , Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix it.
This information is not intended for use outside of this web site or for publication.
Scroll to the right as there is a lot of data :-)
Need parts for your KX500? Click on this link
Need technical specifications for your KX500? Click on this link
YEAR TYPE VIN FRAME USA  ENGINE ID ENGINE CASES AIR BOX CAGE ELEMENT HOLDER AIR BOX NO BOOT (DUCT) YEAR TYPE AIR BOX BOOT JOINT DUCT CABLE CLUTCH CABLE THROTTLE CARBURETOR YEAR TYPE CARBURETOR FLOAT VALVE CARBURETOR BOOT CDI YEAR TYPE CHAIN ADJUSTER BLOCKS CHAIN GUIDE YEAR TYPE CHAIN SLIDE CLUTCH ARM CLUTCH BASKET CLUTCH FRICTION PLATES CLUTCH COVER CLUTCH HUB (INNER) CLUTCH PRESSURE PLATE (OUTER) YEAR TYPE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CRANK SHAFT ROD KIT HOT RODS CYLINDER YEAR TYPE CYLINDER WATER NECK ELBOW ENGINE MOUNTS FRONT ENGINE MOUNTS UPPER EXHAUST PIPE EXHAUST PIPE FMF GNARLY YEAR TYPE EXHAUST PIPE PRO CIRCUIT PLATINUM EXHAUST PIPE PRO CIRCUIT PLATINUM 2 EXHAUST PIPE PRO CIRCUIT WORKS EXHAUST VALVE EXHAUST VALVE COVER FRONT EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL FOOT PEGS YEAR TYPE FOOT PEG SPRINGS FORK FORK SEAL SIZES YEAR TYPE FORK GUARDS FORK GUARD MOUNTS FORK UNDER HOLDER (STEERING STEM LOWER CLAMP) TRIPLE TREE FORK UPPER HOLDER (TOP CLAMP) TRIPLE TREE YEAR TYPE FORK HOLDER BEARINGS (LOWER) FORK HOLDER BEARINGS (UPPER) YEAR TYPE FRONT AXLE FRONT AXLE HOLDER FRONT AXLE SPACERS COLLARS FRONT BRAKE CALIPER YEAR TYPE FRONT BRAKE CALIPER MOUNT FRONT BRAKE HOSE FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER FRONT BRAKE ROTOR YEAR TYPE FRONT BRAKE ROTOR GUARD FRONT FENDER FRONT HUB YEAR TYPE FUEL/GAS TANK GAS TANK CAP YEAR TYPE GOVERNOR GOVERNOR LEVER GOVERNOR SHAFT GOVERNOR WATER PUMP SPUR GEAR GOVERNOR WEIGHT HOLDER HEAD KICK IDLER GEAR KICK LEVER YEAR TYPE KICK LEVER SHAFT MUD FLAP NUMBER PLATE OIL CAPACITY OIL DRAIN PLUG PETCOCK FUEL VALVE TAP PISTON WISECO STD PISTON YEAR TYPE PRIMARY CRANK GEAR RADIATORS RADIATOR SCREENS RADIATOR SHROUDS RADIATOR SHROUD RIGHT YEAR TYPE REAR AXLE REAR BRAKE BACKING PLATE YEAR REAR BRAKE CALIPER REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER MOUNT REAR BRAKE HOSE YEAR TYPE REAR BRAKE ROTOR REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER YEAR TYPE REAR FENDER REAR HUB YEAR TYPE REAR WHEEL SPACERS YEAR TYPE REED VALVE SEAT SHIFT DRUM SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE UNI TRAK SHOCK ARM SUSPENSION RODS (DOG BONES) YEAR TYPE SHOCK BRACKETS SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR YEAR TYPE STATOR COVER SUB FRAME SWING ARM SWING ARM PIVOT PIN YEAR TYPE THROTTLE ASY TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION INPUT 2ND GEAR YEAR TYPE TRANSMISSION INPUT 3RD GEAR TRANSMISSION INPUT 4TH GEAR TRANSMISSION INPUT 5TH GEAR TRANSMISSION OUTPUT SHAFT TRANSMISSION OUTPUT SHAFT NUT YEAR TYPE TRANSMISSION OUTPUT 1ST GEAR TRANSMISSION OUTPUT 2ND GEAR YEAR TYPE TRANSMISSION OUTPUT 3RD GEAR TRANSMISSION OUTPUT 4TH GEAR TRANSMISSION OUTPUT 5TH GEAR WATER PUMP COVER YEAR TYPE WATER PUMP COVER NECK YEAR TYPE WATER PUMP IMPELLER WATER PUMP NECK ELBOW
1975 KX400     FITS 75 KX400, 80-81 KX420, 79-80 KDX450     1975 KX400         1975 KX400       1975 KX400     1975 KX400               1975 KX400       N/A   1975 KX400 N/A       N/A 1975 KX400 N/A N/A N/A NO VALVE     1975 KX400 MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420   1975 KX400   CONVENTIONAL – CHROME OD 35MM 35MM X 48MM X 10.5/11 1975 KX400   CONVENTIONAL     1975 KX400   FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1975 KX400         1975 KX400   DRUM STYLE   1975 KX400 DRUM STYLE DRUM STYLE 1975 KX400 DRUM STYLE   15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420 1975 KX400 LIME GREEN – 51001-095-2G   1975 KX400       N/A       FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500 - 13064-5003 1975 KX400               N/A 1975 KX400   AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1975 KX400   DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059 1975 DRUM BRAKE DRUM BRAKE       1975 KX400 DRUM BRAKE   DRUM BRAKE 1975 KX400 BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1975 KX400   1975 KX400             1975 KX400       1975 KX400       1975 KX400 FITS 75-76 KX400 - 21003-029 1975 KX400   PART OF MAIN FRAME     1975 KX400         1975 KX400           1975 KX400     1975 KX400       N/A 1975 KX400   1975 KX400
1976 KX400           1976 KX400         1976 KX400       1976 KX400     1976 KX400               1976 KX400       N/A   1976 KX400           1976 KX400             1976 KX400     1976 KX400   CONVENTIONAL – CHROME OD 36MM 36MM X 48MM X 10.5/11 1976 KX400   CONVENTIONAL     1976 KX400     1976 KX400         1976 KX400   DRUM STYLE   1976 KX400 DRUM STYLE DRUM STYLE 1976 KX400 DRUM STYLE     1976 KX400     1976 KX400       N/A         1976 KX400                 1976 KX400           1976 KX400   DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059 1976   DRUM BRAKE       1976 KX400       1976 KX400   17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1976 KX400   1976 KX400             1976 KX400       1976 KX400       1976 KX400 FITS 75-76 KX400 - 21003-029 1976 KX400   PART OF MAIN FRAME     1976 KX400         1976 KX400           1976 KX400     1976 KX400       N/A 1976 KX400   1976 KX400
YEAR TYPE VIN FRAME USA  ENGINE ID ENGINE CASES AIR BOX CAGE ELEMENT HOLDER AIR BOX NO BOOT (DUCT) YEAR TYPE AIR BOX BOOT JOINT DUCT CABLE CLUTCH CABLE THROTTLE CARBURETOR YEAR TYPE CARBURETOR FLOAT VALVE CARBURETOR BOOT CDI YEAR TYPE CHAIN ADJUSTER BLOCKS CHAIN GUIDE YEAR TYPE CHAIN SLIDE CLUTCH ARM CLUTCH BASKET CLUTCH FRICTION PLATES CLUTCH COVER CLUTCH HUB (INNER) CLUTCH PRESSURE PLATE (OUTER) YEAR TYPE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CRANK SHAFT ROD KIT HOT RODS CYLINDER YEAR TYPE CYLINDER WATER NECK ELBOW ENGINE MOUNTS FRONT ENGINE MOUNTS UPPER EXHAUST PIPE EXHAUST PIPE FMF GNARLY YEAR TYPE EXHAUST PIPE PRO CIRCUIT PLATINUM EXHAUST PIPE PRO CIRCUIT PLATINUM 2 EXHAUST PIPE PRO CIRCUIT WORKS EXHAUST VALVE EXHAUST VALVE COVER FRONT EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL FOOT PEGS YEAR TYPE FOOT PEG SPRINGS FORK FORK SEAL SIZES YEAR TYPE FORK GUARDS FORK GUARD MOUNTS FORK UNDER HOLDER (STEERING STEM LOWER CLAMP) TRIPLE TREE FORK UPPER HOLDER (TOP CLAMP) TRIPLE TREE YEAR TYPE FORK HOLDER BEARINGS (LOWER) FORK HOLDER BEARINGS (UPPER) YEAR TYPE FRONT AXLE FRONT AXLE HOLDER FRONT AXLE SPACERS COLLARS FRONT BRAKE CALIPER YEAR TYPE FRONT BRAKE CALIPER MOUNT FRONT BRAKE HOSE FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER FRONT BRAKE ROTOR YEAR TYPE FRONT BRAKE ROTOR GUARD FRONT FENDER FRONT HUB YEAR TYPE FUEL/GAS TANK GAS TANK CAP YEAR TYPE GOVERNOR GOVERNOR LEVER GOVERNOR SHAFT GOVERNOR WATER PUMP SPUR GEAR GOVERNOR WEIGHT HOLDER HEAD KICK IDLER GEAR KICK LEVER YEAR TYPE KICK LEVER SHAFT MUD FLAP NUMBER PLATE OIL CAPACITY OIL DRAIN PLUG PETCOCK FUEL VALVE TAP PISTON WISECO STD PISTON YEAR TYPE PRIMARY CRANK GEAR RADIATORS RADIATOR SCREENS RADIATOR SHROUDS RADIATOR SHROUD RIGHT YEAR TYPE REAR AXLE REAR BRAKE BACKING PLATE YEAR REAR BRAKE CALIPER REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER MOUNT REAR BRAKE HOSE YEAR TYPE REAR BRAKE ROTOR REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER YEAR TYPE REAR FENDER REAR HUB YEAR TYPE REAR WHEEL SPACERS YEAR TYPE REED VALVE SEAT SHIFT DRUM SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE UNI TRAK SHOCK ARM SUSPENSION RODS (DOG BONES) YEAR TYPE SHOCK BRACKETS SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR YEAR TYPE STATOR COVER SUB FRAME SWING ARM SWING ARM PIVOT PIN YEAR TYPE THROTTLE ASY TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION INPUT 2ND GEAR YEAR TYPE TRANSMISSION INPUT 3RD GEAR TRANSMISSION INPUT 4TH GEAR TRANSMISSION INPUT 5TH GEAR TRANSMISSION OUTPUT SHAFT TRANSMISSION OUTPUT SHAFT NUT YEAR TYPE TRANSMISSION OUTPUT 1ST GEAR TRANSMISSION OUTPUT 2ND GEAR YEAR TYPE TRANSMISSION OUTPUT 3RD GEAR TRANSMISSION OUTPUT 4TH GEAR TRANSMISSION OUTPUT 5TH GEAR WATER PUMP COVER YEAR TYPE WATER PUMP COVER NECK YEAR TYPE WATER PUMP IMPELLER WATER PUMP NECK ELBOW KX500 ENGINE WEIGHT
1980 KX420     FITS 75 KX400, 80-81 KX420, 79-80 KDX450     1980 KX420         1980 KX420       1980 KX420     1980 KX420 FITS 80-81 KX125 KX250 KX420 12053-1046             1980 KX420       N/A   1980 KX420 N/A       N/A 1980 KX420 N/A N/A N/A NO VALVE     1980 KX420 MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420   1980 KX420   CONVENTIONAL – CHROME OD 38MM – C/L 36 5/16” - 15MM AXLE CLAMP – M14 X 1.5 – OAL 42.5” - FITS 80-81 KX250 KX420 – 44001-1118 38MM X 50MM X 10.5 1980 KX420   CONVENTIONAL     1980 KX420 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1980 KX420 15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006       1980 KX420   DRUM STYLE   1980 KX420 DRUM STYLE DRUM STYLE 1980 KX420 DRUM STYLE   15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420 1980 KX420 GREEN – FITS 80-81 KX250 KX420 – 51001-1030-7F   1980 KX420               FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500 - 13064-5003 1980 KX420               N/A 1980 KX420 26T - FITS 80-81 KX420, 79-80 KDX400, 80-81 KDX420 - 13097-1019 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1980 KX420   FITS 80-81 KX250 KX420, 80 KDX250, 79-80 KDX400 - 41035-4001 1980 DRUM BRAKE DRUM BRAKE       1980 KX420 DRUM BRAKE   DRUM BRAKE 1980 KX420 GREEN - FITS 80-81 KX125 KX250 KX420 - 35022-1043-6W 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 80-81 KX250 KX420, 80-82 KDX250, 81-82 KDX450 - 41034-1019 1980 KX420   1980 KX420             1980 KX420       1980 KX420       1980 KX420 FITS 74-79 KX250, 80-81 KX420 - 21003-1010 1980 KX420   PART OF MAIN FRAME FITS 80-81 KX250 KX420 - 33001-1043   1980 KX420         1980 KX420         FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1980 KX420 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 32T - FITS 80-81 KX420, 83-85 KX500 - 13129-1622 1980 KX420 FITS 80-81 KX420, 83-85 KX500 - 13129-1679 FITS 80-81 KX420, 83-85 KX500, 79-80 KDX400 - 13129-1132 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 N/A 1980 KX420   1980 KX420
1981 KX420   KX420AE00XXXX FITS 75 KX400, 80-81 KX420, 79-80 KDX450     1981 KX420         1981 KX420   A1 21119-1001 CU1172 1981 KX420     1981 KX420 FITS 80-81 KX125 KX250 KX420 12053-1046             1981 KX420       N/A   1981 KX420 N/A       N/A 1981 KX420 N/A N/A N/A NO VALVE     1981 KX420 MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420   1981 KX420   CONVENTIONAL – CHROME OD 38MM – C/L 36 5/16” - 15MM AXLE CLAMP – M14 X 1.5 – OAL 42.5” - FITS 80-81 KX250 KX420 – 44001-1118 38MM X 50MM X 10.5 1981 KX420   CONVENTIONAL     1981 KX420 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1981 KX420 15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006       1981 KX420   DRUM STYLE   1981 KX420 DRUM STYLE DRUM STYLE 1981 KX420 DRUM STYLE   15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420 1981 KX420 GREEN – FITS 80-81 KX250 KX420 – 51001-1030-7F   1981 KX420           1030   FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500 - 13064-5003 1981 KX420       1.0 LITER       N/A 1981 KX420 26T - FITS 80-81 KX420, 79-80 KDX400, 80-81 KDX420 - 13097-1019 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1981 KX420   FITS 80-81 KX250 KX420, 80 KDX250, 79-80 KDX400 - 41035-4001 1981 DRUM BRAKE DRUM BRAKE       1981 KX420 DRUM BRAKE   DRUM BRAKE 1981 KX420 GREEN - FITS 80-81 KX125 KX250 KX420 - 35022-1043-6W 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 80-81 KX250 KX420, 80-82 KDX250, 81-82 KDX450 - 41034-1019 1981 KX420   1981 KX420             1981 KX420       1981 KX420       1981 KX420 FITS 74-79 KX250, 80-81 KX420 - 21003-1010 1981 KX420 -1 PART OF MAIN FRAME FITS 80-81 KX250 KX420 - 33001-1043   1981 KX420         1981 KX420         FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1981 KX420 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 32T - FITS 80-81 KX420, 83-85 KX500 - 13129-1622 1981 KX420 FITS 80-81 KX420, 83-85 KX500 - 13129-1679 FITS 80-81 KX420, 83-85 KX500, 79-80 KDX400 - 13129-1132 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 N/A 1981 KX420   1981 KX420
1983 KX500 JKAKXVA1-DA--XXXX KX500AE000001-001500 FITS 83-85 KX500 - 14001-5158   FITS 83-84 KX250 11011-1115 1983 KX500 FITS 83-84 KX500 - 14073-1079 FITS 84-85 KXT, 83-85 KX250, 83-84 KX500 - 54011-1112 FITS 85 KX250, 83-85 KX500 - 54012-1211 MIKUNI 38MM - FITS 83-84 KX500 1983 KX500   FITS 83-84 KX500 FITS 83-85 KX500 – 21119-1133 1983 KX500   FITS 82-83 KX125, 83-85 KX250 & KX500, 83 KDX200 & KDX250 1983 KX500   FITS 83-85 KX250, 83-84 KX500, 84-85 KXT250 13102-1077 FITS 83-84 KX500 - 13095-1103   FITS 83-84 KX500 - 14032-1079 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044 FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1983 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 83-84 KX500 - 86MM STD STROKE - 13031-1074 N/A FITS 83-84 KX500 - 11005-1188 1983 KX500 N/A     FITS 83-84 KX500 N/A 1983 KX500 N/A N/A N/A NO VALVE     1983 KX500 F3T205 FITS 83-85 KX500 - 21007-1052  FITS 83-84 KX250 & KX500 - 34028-1050 - 34028-1051 1983 KX500 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 CHROME OD 43MM - C/L 36 5/8" - C/L OF CALIPER MOUNTS 62MM - AXLE CLAMP 20MM 43MM X 55MM X 9.5/10.5/11 1983 KX500   CONVENTIONAL FITS 83-84 KX250, KX500, 84 KX125 FITS 83-84 KX250, KX500 1983 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1983 KX500 FITS 82-83 KX125, 82-84 KX250, 83-84 KX500     FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 1983 KX500 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1983 KX500 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 - 43015-1281 OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500 1983 KX500     PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES 1983 KX500 GREEN - FITS 83-84 KX500 51001-5384-6W   1983 KX500           FITS 83-84 KX500 27T - FITS 83-85 KX500 - 59051-1107 FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500 - 13064-5003 1983 KX500 FITS 83-84 KX500     800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FITS 83-84 KX500 – 13001-1088 N/A 1983 KX500 25T - FITS 83-84 KX500 - 13097-1060 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1983 KX500   41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500 1983 DRUM BRAKE DRUM BRAKE       1983 KX500 DRUM BRAKE FITS 83-84 KX250 KX500 43001-1159 DRUM BRAKE 1983 KX500 GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 41034-5005 1983 KX500   1983 KX500   FITS 83-84 KX500   FITS 83-85 KX500 FITS 83-86 KX250, KX500 - 13242-1166 FITS 83-86 KX500 1983 KX500   FITS 83-84 KX250 KX500 -39007-1052   1983 KX500   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1146-6W GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1147-6W 1983 KX500 FITS 83-85 KX500 - 21003-1109 - 336-504 OHMS BLACK/RED TO BLACK YELLOW - 14.2-21.4 OHMS RED TO BLACK/YELLOW - 10.4-15.6 OHMS WHITE/RED TO BLACK/YELLOW 1983 KX500 BLACK FITS 83-04 KX500 - 14031-1091 PART OF MAIN FRAME FITS 83-84 KX250 KX500 - 33001-1205 FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1983 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036   FITS 83-84 KX500 - 13127-1126 22T - FITS 83-85 KX500 - 13129-1407 1983 KX500 22T - FITS 83-85 KX500 - 13129-1408 22T - FITS 83-85 KX500 - 13129-1409 24T - FITS 83-85 KX500, 84-86 KL600, 87-96 KLR650 - 13129-1410 FITS 83-85 KX500 - 13128-1042 FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1983 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 32T - FITS 80-81 KX420, 83-85 KX500 - 13129-1622 1983 KX500 FITS 80-81 KX420, 83-85 KX500 - 13129-1679 FITS 80-81 KX420, 83-85 KX500, 79-80 KDX400 - 13129-1132 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 N/A 1983 KX500   1983 KX500
1984 KX500 JKAKXVA1-EA--0015 KX500AE0015001-002400 FITS 83-85 KX500 - 14001-5158   FITS 83-84 KX250 11011-1115 1984 KX500 FITS 83-84 KX500 - 14073-1079 FITS 84-85 KXT, 83-85 KX250, 83-84 KX500 - 54011-1112 FITS 85 KX250, 83-85 KX500 - 54012-1211 MIKUNI 38MM - FITS 83-84 KX500 1984 KX500   FITS 83-84 KX500 FITS 83-85 KX500 – 21119-1133 1984 KX500   FITS 82-83 KX125, 83-85 KX250 & KX500, 83 KDX200 & KDX250 1984 KX500   FITS 83-85 KX250, 83-84 KX500, 84-85 KXT250 13102-1077 FITS 83-84 KX500 - 13095-1103   FITS 83-84 KX500 - 14032-1079 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044 FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1984 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 83-84 KX500 - 86MM STD STROKE - 13031-1074 N/A FITS 83-84 KX500 - 11005-1188 1984 KX500 N/A     FITS 83-84 KX500 N/A 1984 KX500 N/A N/A N/A NO VALVE     1984 KX500 F3T205 FITS 83-85 KX500 - 21007-1052  FITS 83-84 KX250 & KX500 - 34028-1050 - 34028-1051 1984 KX500 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 CHROME OD 43MM - C/L 36 5/8" - C/L OF CALIPER MOUNTS 62MM - AXLE CLAMP 20MM 43MM X 55MM X 9.5/10.5/11 1984 KX500   CONVENTIONAL FITS 83-84 KX250, KX500, 84 KX125 FITS 83-84 KX250, KX500 1984 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1984 KX500 FITS 82-83 KX125, 82-84 KX250, 83-84 KX500     FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 1984 KX500 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1984 KX500 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 - 43015-1281 OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500 1984 KX500     PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES 1984 KX500 GREEN - FITS 83-84 KX500 51001-5384-6W   1984 KX500           FITS 83-84 KX500 27T - FITS 83-85 KX500 - 59051-1107 FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500 - 13064-5003 1984 KX500 FITS 83-84 KX500     800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 DOME TOP 1 RING - BOOK SAYS 83-84 , KAWI MAN SAYS 83-04 WILL WORK – 13001-1199 N/A 1984 KX500 25T - FITS 83-84 KX500 - 13097-1060 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1984 KX500   41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500 1984 DRUM BRAKE DRUM BRAKE       1984 KX500 DRUM BRAKE FITS 83-84 KX250 KX500 43001-1159 DRUM BRAKE 1984 KX500 GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 41034-5005 1984 KX500   1984 KX500   FITS 83-84 KX500   FITS 83-85 KX500 FITS 83-86 KX250, KX500 - 13242-1166 FITS 83-86 KX500 1984 KX500   FITS 83-84 KX250 KX500 -39007-1052   1984 KX500   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1146-6W GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1147-6W 1984 KX500 FITS 83-85 KX500 - 21003-1109 - 336-504 OHMS BLACK/RED TO BLACK YELLOW - 14.2-21.4 OHMS RED TO BLACK/YELLOW - 10.4-15.6 OHMS WHITE/RED TO BLACK/YELLOW 1984 KX500 BLACK FITS 83-04 KX500 - 14031-1091 PART OF MAIN FRAME FITS 83-84 KX250 KX500 - 33001-1205 FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1984 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036   FITS 83-84 KX500 - 13127-1126 22T - FITS 83-85 KX500 - 13129-1407 1984 KX500 22T - FITS 83-85 KX500 - 13129-1408 22T - FITS 83-85 KX500 - 13129-1409 24T - FITS 83-85 KX500, 84-86 KL600, 87-96 KLR650 - 13129-1410 FITS 83-85 KX500 - 13128-1042 FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1984 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 32T - FITS 80-81 KX420, 83-85 KX500 - 13129-1622 1984 KX500 FITS 80-81 KX420, 83-85 KX500 - 13129-1679 FITS 80-81 KX420, 83-85 KX500, 79-80 KDX400 - 13129-1132 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 N/A 1984 KX500   1984 KX500
1985 KX500 JKAKXVA17EA00XXXX KX500BE000001-001800 FITS 83-85 KX500 - 14001-5158 FITS 84-85 KX125, 85-86 KX250 KX500, 86-88 KDX200 - 13091-1267 FITS 85 KX250 KX500 11011-1180 1985 KX500 FITS 85-86 KX500 - 14073-1194   FITS 85 KX250, 83-85 KX500 - 54012-1211 MIKUNI 39MM FITS 85 KX500  1985 KX500 FITS 85-86 KX250 KX500 - 16030-1060 FITS 85 KX500  FITS 83-85 KX500 – 21119-1133 1985 KX500   FITS 82-83 KX125, 83-85 KX250 & KX500, 83 KDX200 & KDX250 1985 KX500   FITS 85 KX500  FITS 85 KX500 - 13095-1122   FITS 85 KX500  FITS 85 KX250 KX500 - 13087-1061  FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1985 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 85-86 KX500 - 86MM STD STROKE  - 13031-1182 FITS 85-04 KX500 - 8148 FITS 85 KX500  1985 KX500 FITS 83-85 KX250, 85-87 KX500, 84-85 KXT250 - 52014-1004     FITS 85 KX500  N/A 1985 KX500 FITS 85 KX500  N/A N/A NO VALVE     1985 KX500 F3T205 FITS 83-85 KX500 - 21007-1052  FITS 85 KX125 KX250 KX500 1985 KX500 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 CHROME OD 43MM - C/L 36 5/8" - C/L OF CALIPER MOUNTS 62MM - AXLE CLAMP 20MM 43MM X 55MM X 9.5/10.5/11 1985 KX500   CONVENTIONAL FITS 85 KX125, KX250, KX500 FITS 85 KX250, KX500 1985 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1985 KX500 FITS 85-88 KX125 KX250 KX500 - 41068-1241     FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 1985 KX500 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1985 KX500 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 - 43015-1281 OD: 250MM OD - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 1985 KX500     F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115 1985 KX500 GREEN - FITS 85-86 KX500 51001-1193-6W   1985 KX500       FITS 85-04 KX500 - 59051-1129   FITS 85 KX500 - 11001-1189 27T - FITS 83-85 KX500 - 59051-1107 FITS 85-86 KX500 – 13064-1118 - KAWI MAN SAYS 86-04 WILL ALL WORK 1985 KX500 FITS 85-04 KX500 - 13066-1056      800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 DOME TOP 1 RING - BOOK SAYS 83-84 , KAWI MAN SAYS 83-04 WILL WORK – 13001-1199 N/A 1985 KX500 26T - FITS 85 KX500 - 13097-1133 FITS 85-86 KX500 BLACK  14037-1077-6C FITS 85-86 KX500, 83-86 KX250, 86-87 KXT250 GREEN – FITS 85 KX250 KX500 - 49089-5004-6W GREEN - FITS 85 KX250 KX500 - 49089-5005-6W 1985 KX500 FITS 85-87 KX125 KX250 KX500 - 41068-1180 HYDRAULIC BRAKE 1985 DRUM BRAKE DRUM BRAKE       1985 KX500 DRUM BRAKE FITS 84-85 KX125, 85 KX250 KX500 43001-1173 DRUM BRAKE 1985 KX500 GREEN – FITS 84-85 KX125, 85 KX250 KX500 - 35022-1203-6W BLACK - 20MM AXLE DIA - BRG TO BRG 131-132MM - DRUM - FITS 85 KX250 & KX500 1985 KX500 FITS 85 KX125, KX250, KX500 1985 KX500   FITS 85 KX125, 250 & 500   FITS 83-85 KX500 FITS 83-86 KX250, KX500 - 13242-1166 FITS 83-86 KX500 1985 KX500   FITS 85 KX250 KX500 - 39007-5006   1985 KX500   GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1279-AE GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1280-AE 1985 KX500 FITS 83-85 KX500 - 21003-1109 - 336-504 OHMS BLACK/RED TO BLACK YELLOW - 14.2-21.4 OHMS RED TO BLACK/YELLOW - 10.4-15.6 OHMS WHITE/RED TO BLACK/YELLOW 1985 KX500 BLACK FITS 83-04 KX500 - 14031-1091 PART OF MAIN FRAME   FITS 85 KX125, 85-86 KX250 KX500 1985 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036     22T - FITS 83-85 KX500 - 13129-1407 1985 KX500 22T - FITS 83-85 KX500 - 13129-1408 22T - FITS 83-85 KX500 - 13129-1409 24T - FITS 83-85 KX500, 84-86 KL600, 87-96 KLR650 - 13129-1410 FITS 83-85 KX500 - 13128-1042 FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1985 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 32T - FITS 80-81 KX420, 83-85 KX500 - 13129-1622 1985 KX500 FITS 80-81 KX420, 83-85 KX500 - 13129-1679 FITS 80-81 KX420, 83-85 KX500, 79-80 KDX400 - 13129-1132 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 FITS 85-86 KX500 - 16142-1060 1985 KX500   1985 KX500
1986 KX500 JKAKXVB18GA00XXXX KX500BE001801-004100 FITS 86 KX500 - 14001-5207 FITS 84-85 KX125, 85-86 KX250 KX500, 86-88 KDX200 - 13091-1267 FITS 86 KX250 KX500 11011-1220 1986 KX500 FITS 85-86 KX500 - 14073-1194 FITS 86 KX250 KX500 - 54011-1233 FITS 86 KX250 KX500 - 54012-1309 MIKUNI E5 92 FITS 86 KX500  1986 KX500 FITS 85-86 KX250 KX500 - 16030-1060 FITS 86 KX500  - 16065-1137 FITS 86 KX500  – 21119-1191 - 15 deg BTDC @ 6000 RPM 1986 KX500   FITS 86-87 KX125 & KX250 & KX500 1986 KX500   FITS 86 KX500, KX250, 86-87 TECATE 17T & 66T - FITS 86 KX500  - 13095-1137   KX500B 1 FITS 86-87 KX500 FITS 86 KX500 - 13087-1074 - 5 bolt post FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1986 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 85-86 KX500 - 86MM STD STROKE  - 13031-1182 FITS 85-04 KX500 - 8148 .499L FITS 86 KX500  1986 KX500 FITS 83-85 KX250, 85-87 KX500, 84-85 KXT250 - 52014-1004     FITS 86 KX500  N/A 1986 KX500 FITS 86 KX500  N/A N/A FITS 86 KX500 2 VALVE- 12005-1066 DRUMS - STEEL OR ALLOY YOU NEVER KNOW…     1986 KX500 F3T81171 5801 FITS 86-88 and sometimes 89 - 21007-1140 - 1.35lb or 21.6 oz - 3.475" OD FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 1986 KX500 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 CHROME OD 43MM - C/L 36 5/8" - C/L OF CALIPER MOUNTS 62MM - AXLE CLAMP 20MM 43MM X 55MM X 9.5/10.5/11 1986 KX500   CONVENTIONAL FITS 86 KX125, KX250, KX500 FITS 86 KX125 KX250 KX500 44039-1142 1986 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1986 KX500 FITS 85-88 KX125 KX250 KX500 - 41068-1241     FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 1986 KX500 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1986 KX500 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 - 43015-1281 OD: 250MM OD - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 1986 KX500     F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115 1986 KX500 GREEN - FITS 85-86 KX500 51001-1193-6W   1986 KX500     FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129   FITS 86 KX500 - 11001-1214 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 85-86 KX500 – 13064-1118 - KAWI MAN SAYS 86-04 WILL ALL WORK 1986 KX500 FITS 85-04 KX500 - 13066-1056    FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 DOME TOP 1 RING - BOOK SAYS 86 , KAWI MAN SAYS 85-04 WILL WORK – 13001-1226 N/A 1986 KX500 26T - FITS 86-87 KX500 - 13097-1154 FITS 85-86 KX500 BLACK  14037-1077-6C FITS 85-86 KX500, 83-86 KX250, 86-87 KXT250 GREEN - FITS 86 KX250 KX500 - 49089-5009-6W GREEN - FITS 86 KX250 KX500 - 49089-5010-6W 1986 KX500 FITS 85-87 KX125 KX250 KX500 - 41068-1180 HYDRAULIC BRAKE 1986 FITS 86 KX125, KX250, KX500       FITS 86-87 KX125 KX250 KX500 - 43059-1364  1986 KX500 FITS 86 KX250 & KX500 FITS 86 KX250 KX500 43001-1195 FITS 86 KX125 & KX250 & KX500 1986 KX500 GREEN – FITS 86-87 KX125 KX250 KX500 - 35022-1217-6W  R-1158 – BLACK - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 86-87 KX125 KX250 KX500 - 41034-1139 1986 KX500 LEFT FITS 86-88 KX125 KX250 KX125 - 92027-1942 1986 KX500 FITS 85 KX250, 86 KX500, 86-87 KXT250 - 12021-1058  FITS 86 KX125, KX250 & KX500 - 53001-1436   FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 83-86 KX250, KX500 - 13242-1166 FITS 83-86 KX500 1986 KX500 Spring thickness: 12MM OD - Spring Diameter: 88MM - Spring length as mounted: 267MM - Upper mount tab thickness: 32MM - Upper mount tab hole ID: 12MM - Lower Mount Internal Width: 26.5MM - Lower mount hole ID: 10MM - Eye to Eye: 420MM FITS 86 KX250 KX500 - 39007-1081   1986 KX500   GREEN – FITS 86 KX500  – 36002-5185-AC GREEN – FITS 86 KX500  – 36002-5186-AC 1986 KX500 (2 coil style) FITS 86 KX500 - 21003-1141 - 432-648 OHMS BLACK/RED TO BLACK/YELLOW - 4.0-6.0 OHMS WHITE/GREEN TO WHITE/RED 1986 KX500 BLACK FITS 83-04 KX500 - 14031-1091 PART OF MAIN FRAME FITS 86 KX250 & KX500 - 33001-1246 FITS 85 KX125, 85-86 KX250 KX500 1986 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 86 KX500 - GEARS FIT 86-87 KX500 FITS 86 KX500 - 13127-1131 FITS 86-87 KX500 - 13129-1741 1986 KX500 FITS 86-87 KX500 - 13129-1742 FITS 86-88 KX500 - 13129-1743 24T - FITS 86-04 KX500 - 13129-1744 FITS 86 KX500 - 13128-1128 FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1986 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 FITS 86-87 KX500 - 13129-1746 1986 KX500 FITS 86-87 KX500 - 13129-1747 FITS 86-88 KX500 - 13129-1748 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 FITS 85-86 KX500 - 16142-1060 1986 KX500   1986 KX500
1987 KX500 JKAKXVC19HA00XXXX KX500BE004101-006600 FITS 87 KX500  FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 87 KX125 KX250 KX500 11011-1241 1987 KX500 1286 - FITS 87 KX500 - 14073-1286 FITS 87 KX250 KX500 - 54011-1252 FITS 87 KX250 KX500 - 54012-1324 MIKUNI FITS 87 KX500 - 40MM 1987 KX500   FITS 87 KX500  17 deg BTDC @ 6000 RPM 1987 KX500   FITS 86-87 KX125 & KX250 & KX500 1987 KX500 FITS 87 KX125 KX250 KX500, 87-88 KDX200, 87-88 KXF250 FITS 87 KX250 & KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 86-87 KX500 FITS 87 KX250 KX500 - 13087-1085 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1987 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 1987 - 86MM STD STROKE  - 13031-1231 FITS 85-04 KX500 - 8148 FITS 87 KX500  1987 KX500 FITS 83-85 KX250, 85-87 KX500, 84-85 KXT250 - 52014-1004     FITS 87 KX500  N/A 1987 KX500 FITS 87 KX500  N/A N/A FITS 87-88 KX500 2 VALVE - 12005-1080 DRUMS - STEEL OR ALLOY YOU NEVER KNOW…     1987 KX500 F3T81171 5801 FITS 86-88 and sometimes 89 - 21007-1140 - 1.35lb or 21.6 oz - 3.475" OD FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 1987 KX500 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 CONVENTIONAL - CHROME OD 43MM - C/L 36 5/8" - C/L OF CALIPER MOUNTS 89MM - AXLE CLAMP 20MM 43MM X 55MM X 9.5/10.5/11 1987 KX500   CONVENTIONAL FITS 87 KX250, KX500 FITS 87 KX250 KX500 44039-1147 1987 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1987 KX500 FITS 85-88 KX125 KX250 KX500 - 41068-1241     FITS 87 KX125 KX250 KX500 1987 KX500 CALIPER HOLDER FITS 87-88 KX500, 88 KX125 KX250 - 43044-1069  FITS 87 KX125 KX250 KX500 - 43059-1385 FITS 87 KX125 KX250 KX500 46092-1141 1987 KX500 FITS 87 KX125 KX250 KX500 OD: 250MM OD - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 1987 KX500     F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115 1987 KX500 GREEN – FITS 87 KX500 51001-1254-6W FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1987 KX500     FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 87  26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 87 KX500 - 13064-1130 - KAWI MAN SAYS 86-04 WILL ALL WORK 1987 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 DOME TOP 1 RING - BOOK SAYS 87 , KAWI MAN SAYS 85-04 WILL WORK – 13001-1245 N/A 1987 KX500 26T - FITS 86-87 KX500 - 13097-1154 FITS 87 KX500  BLACK 14037-1087 FITS 87 KX250, KX500 GREEN - FITS 87 KX500  – 49089-5020-6W GREEN - FITS 87 KX500  – 49089-5021-6W  1987 KX500 FITS 85-87 KX125 KX250 KX500 - 41068-1180 HYDRAULIC BRAKE 1987 FITS 87-88 KX125, KX250, KX500 - 43041-1244     FITS 87-88 KX125 KX250 KX500 - 43044-1068 FITS 86-87 KX125 KX250 KX500 - 43059-1364  1987 KX500 OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE - 86-88 KX125, 87-88 KX250 & KX500 FITS 87 KX250 KX500 43001-1217  FITS 87 KX125 & KX250 & KX500 1987 KX500 GREEN – FITS 86-87 KX125 KX250 KX500 - 35022-1217-6W  R-1158 – BLACK - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 86-87 KX125 KX250 KX500 - 41034-1139 1987 KX500   1987 KX500   FITS 87 KX125 KX250 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 87 KX250 & KX500 FITS 87-93 KX500 - 13161-1144 1987 KX500   FITS 87 KX125 KX250 KX500 - 39007-1115 FITS 87 KX250 KX500 - 46102-1200 1987 KX500   GREEN - FITS 87 KX125 KX250 KX125 – 36002-5310-6W  GREEN - FITS 87 KX125 KX250 KX125 – 36001-1345-AC 1987 KX500 (2 coil style) FITS 87-89 KX500 - 21003-1169 - 432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW - 4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW 1987 KX500 BLACK FITS 83-04 KX500 - 14031-1091 FITS 87 KX125 KX250 KX500 - 32002-1911 FITS 87 KX250 KX500 - 33001-1276   1987 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 87 KX500  - GEARS FIT 86-87 KX500 FITS 87 KX500 - 13127-1143 FITS 86-87 KX500 - 13129-1741 1987 KX500 FITS 86-87 KX500 - 13129-1742 FITS 86-88 KX500 - 13129-1743 24T - FITS 86-04 KX500 - 13129-1744 FITS 87 KX500 - 13128-1142 FITS 83-87 KX500, 80-81 KX420, 74-79 KX250, 79-80 KDX400, 81-82 KDX420 - 42045-008 - M24X1.0 1987 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 FITS 86-87 KX500 - 13129-1746 1987 KX500 FITS 86-87 KX500 - 13129-1747 FITS 86-88 KX500 - 13129-1748 FITS 80-81 KX420, 83-87 KX500, 79-80 KDX400, 81 KDX420, 82 KDX450 - 13129-1133 FITS 87 KX500 - 16142-1072 1987 KX500   1987 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065   59.25LB NO OIL, SPARK PLUG, CARBURETOR
1988 KX500 JKAKXVD17JA00XXXX KX500BE006601-008500 FITS 88 KX500 - 14001-5245 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 88 KX500 - 11011-1288 1988 KX500 1329 - FITS 88 KX500 - 14073-1329 FITS 88-89 KX250 KX500 - 54011-1264 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V396 FITS 88 KX500 - 39MM 1988 KX500   FITS 88 KX500  FITS 88 KX500 – 17 deg BTDC @ 6000 RPM 1988 KX500 FITS 88-89 KX125 KX250 KX500 - 33040-1085 FITS 88-89 KX125 KX250 KX500 1988 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 FITS 88 KX250 & KX500 - 13102-1094 17T & 66T - FITS 87-04 KX500 - 13095-1196 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 88-04 KX500 - 14032-1245 FITS 88-91 KX250, 88 KX500 - 13087-1098 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1988 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   FITS 1988  – 86MM STD STROKE - 13031-1260 FITS 85-04 KX500 - 8148 FITS 88 KX500  – 86MM STD BORE 1988 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065     FITS 88 KX500 - 18002-1799 20055 FITS 88-04 KX500 1988 KX500 FITS 88 KX500  N/A N/A FITS 87-88 KX500 2 VALVE - 12005-1080 DRUMS - STEEL OR ALLOY YOU NEVER KNOW…   FITS 88-04 KX500 - 14024-1611 1988 KX500 F3T81171 5801 FITS 86-88 and sometimes 89 - 21007-1140 - 1.35lb or 21.6 oz - 3.475" OD FITS 88-89 KX125 KX250 KX500 - 34028-1233 - 34028-1234 1988 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 KYB - CONVENTIONAL - CHROME OD 43MM - C/L 37" - C/L OF CALIPER MOUNTS 89MM - AXLE CLAMP 20MM 43MM X 55MM X 9.5/10.5/11 1988 KX500   CONVENTIONAL FITS 88 KX250, KX500 FITS 88 KX250 KX500 44039-1176 1988 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1988 KX500 FITS 85-88 KX125 KX250 KX500 - 41068-1241     FITS 88 KX125 KX250 KX500 1988 KX500 CALIPER HOLDER FITS 87-88 KX500, 88 KX125 KX250 - 43044-1069    FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1988 KX500 FITS 88 KX125 KX250 KX500 - 43015-1367 OD: 250MM OD - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 1988 KX500   GREEN - FITS 88 KX250 KX500, 86-88 KDX200 - 35004-1176-6W   F-1123 - GRAY - 17MM AXLE DIA - BRG TO BRG 102MM - FITS 88 KX 125, 250, 500 - 41034-1170 1988 KX500 GREEN – FITS 88-91 KX500 51001-1281-6W (SHOULD FIT 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1988 KX500     FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 88 KX500 - 11001-1269 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 88-91 KX500 - 13064-1134 - KAWI MAN SAYS 86-04 WILL ALL WORK 1988 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 DOME TOP 1 RINGS - BOOK SAYS 88 , KAWI MAN SAYS 85-04 WILL WORK – 13001-1267 575M08600 FITS 88-04 KX500 86MM STD BORE 1988 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 88 KX500  - 49089-5035-6W GREEN – FITS 88 KX500  – 49089-5036-6W 1988 KX500 FITS 88 KX125 KX250 KX500 - 41068-1249 CLICK HERE FOR MEASUREMENTS HYDRAULIC BRAKE 1988 FITS 87-88 KX125, KX250, KX500 - 43041-1244     FITS 87-88 KX125 KX250 KX500 - 43044-1068   1988 KX500 OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE - 86-88 KX125, 87-88 KX250 & KX500 FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1988 KX500 GREEN – FITS 88 KX250 KX500 - 35022-1234-6W R-1158 – GRAY - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 88 KX 125, 250, 500 - 41034-1171 1988 KX500   1988 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 FITS 88-89 KX125 KX250, 88-90 KX500, 94 KX500  FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX500 - 13161-1144 1988 KX500 KYB - SPRING THICKNESS 11.5MM - SPRING OD 88MM, LENGTH 254MM - BODY OD 53.7MM - CHROME OD 16MM - EYE TO EYE 440MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH 27MM,  HOLE ID 10MM - FITS 88 KX500  - 45014-1387 FITS 88 KX125 KX250 KX500 - 39007-1145   1988 KX500   GREEN – FITS 88 KX125 KX250 KX500 - 36002-5451-6W GREEN - FITS 88 KX250 KX500 – 36001-1376-AC 1988 KX500 (2 coil style) FITS 87-89 KX500 - 21003-1169 - 432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW - 4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW 1988 KX500 GRAY FITS 83-04 KX500 - 14031-1220 FITS 88 KX125 KX250 KX500 - 32002-1965 FITS 88 KX125 KX250 KX500 - 33001-1306-X3 FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1988 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04KX500 - GEARS FIT 88-89 KX500 16T - FITS 88-04 KX500 - 13127-1159 20T - FITS 88-89 KX500 - 13129-1908 1988 KX500 22T - FITS 88-89 KX500 - 13129-1909 FITS 86-88 KX500 - 13129-1743 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1988 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 FITS 88-89 KX500 - 13129-1955 1988 KX500 26T - FITS 88-89 KX500 - 13129-1910 FITS 86-88 KX500 - 13129-1748 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1988 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1988 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067
1989 KX500 JKAKXVE10KA00XXXX KX500BE008501- FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX500 - 11011-1299 1989 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 88-89 KX250 KX500 - 54011-1264 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V461 FITS 89 KX500 - 39MM 1989 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1989 KX500 FITS 88-89 KX125 KX250 KX500 - 33040-1085 FITS 88-89 KX125 KX250 KX500 1989 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 89 KX250 & KX500 - 13102-1101 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1989 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 89-91 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE – 13031-1285 -  FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1989 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1989 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1989 KX500 F4T102 71 FITS 89-91 KX500 - 21007-1183 - 2.55lb or 41.6 oz. - 4.370" OD FITS 88-89 KX125 KX250 KX500 - 34028-1233 - 34028-1234 1989 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 CONVENTIONAL - KX 89 L / KX 89 R - CHROME OD 46MM - C/L 36.75" - BRAKE MOUNT 78MM - AXLE CLAMP ID'S 22MM 46MM X 58MM X 10.5 1989 KX500   CONVENTIONAL FITS 89 KX125, KX250, KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 89 KX125 KX250 KX500 44039-1192 1989 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1989 KX500 FITS 89 KX125 KX250 KX500 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056   FITS 89 KX125 KX250 KX500 - 43041-1294 1989 KX500 FITS 89 KX125 KX250 KX500 - 14079-1071   FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1989 KX500 FITS 89-90 KX125 KX250 KX500 KX80 - 43015-1395 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 1989 KX500     F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - ROTOR BC 4 ON 116MM - FITS 89 KX125 KX250 KX500 1989 KX500 GREEN – FITS 88-91 KX500 51001-1281-6W (SHOULD FIT 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1989 KX500 SET FITS 89-04 KX500 FITS 89-91 KX500 - 13168-1401 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 88-91 KX500 - 13064-1134 - KAWI MAN SAYS 86-04 WILL ALL WORK 1989 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS 89 , KAWI MAN SAYS 83-04 WILL WORK – 13001-1298 575M08600 FITS 88-04 KX500 86MM STD BORE 1989 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 89 KX500  – 49089-5069-6W GREEN – FITS 89 KX500  – 49089-5070-6W 1989 KX500   HYDRAULIC BRAKE 1989 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448     FITS 89 KX125 KX250 KX500 - 43044-1082   1989 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1989 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 – GRAY – 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM – 36 SPOKES – FITS 89 KDX200, KX125, KX250, KX500 - 2 BRG - 41034-1184 1989 KX500 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R 1989 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 - FITS 88 KX125 KX250 KX500 - 53001-1532 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX500 - 13161-1144 1989 KX500 WILL NOT FIT 90 OR NEWER FITS 89 KX125 KX250 KX500 - 39007-1170 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1989 KX500   GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN – FITS 89 KX125 KX250 KX500 - 36010-5135-6W 1989 KX500 (2 coil style) FITS 87-89 KX500 - 21003-1169 - (1 COIL STYLE) FITS 89-91 - 21003-1215 - 432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW - 4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW 1989 KX500 GRAY FITS 83-04 KX500 - 14031-1220 FITS 89-90 KX500, 89 KX125 KX250 - 32160-1031 - KAWI MAN SAYS IT FITS 89-04 KX500 FITS 89 KX125 KX250 KX500 – 33001-1324-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1989 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04KX500 - GEARS FIT 88-89 KX500 16T - FITS 88-04 KX500 - 13127-1159 20T - FITS 88-89 KX500 - 13129-1908 1989 KX500 22T - FITS 88-89 KX500 - 13129-1909 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1989 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 29T - FITS 88-89 KX500 - 13129-1955 1989 KX500 26T - FITS 88-89 KX500 - 13129-1910 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1989 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1989 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1990 KX500 JKAKXVE12LA00XXXX KX500BE010701- 004000 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1990 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V563 FITS 90-93 KX500 - 39MM 1990 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1990 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1990 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1990 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 89-91 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE – 13031-1285 FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1990 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1990 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1990 KX500 F4T102 71 FITS 89-91 KX500 - 21007-1183 - 2.55lb or 41.6 oz. - 4.370" OD FITS 90 KX125 KX250, 90-91 KX500 - 34028-1318 - 34028-1319 1990 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - CHROME OD 41MM C/L 37.25" - BRAKE MOUNT C/L 61MM – AXLE CLAMP ID 22MM 41MM X 53MM X 8/9.5/10.5 1990 KX500 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 90 KX125, KX250, KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 90 KX250 KX500 44039-1190 1990 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1990 KX500 FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056   FITS 90 KX125 KX250 KX500 - 43041-1285 1990 KX500 FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1990 KX500 FITS 89-90 KX125 KX250 KX500 KX80 - 43015-1395 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 1990 KX500 FITS 90-93 KX125 KX250 KX500 - 14024-1859-6F   F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 1990 KX500 GREEN – FITS 88-91 KX500 51001-1281-6W (SHOULD FIT 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1990 KX500 SET FITS 89-04 KX500 FITS 89-91 KX500 - 13168-1401 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 88-91 KX500 - 13064-1134 - KAWI MAN SAYS 86-04 WILL ALL WORK 1990 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 90 KX125 KX250 KX500 58029-5027-6W GREEN 800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1990 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 90 KX500  – 49089-5087-6W GREEN – FITS 90 KX500  – 49089-5088-6W 1990 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1990 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   WHITE - FITS 90-93 KX125 KX250 KX500, 90-94 KDX200, 93-96 KLX650R KLX650C, 94-96 KLX250R - 55020-1323-6F FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092   1990 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1990 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1990 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1990 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 - FITS 89 KX125 KX250 KX500 - 53001-1577-MD - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX500 - 13161-1144 1990 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1990 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1990 KX500 (2 coil style) FITS 87-89 KX500 - 21003-1169 - (1 COIL STYLE) FITS 89-91 - 21003-1215 - 432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW - 4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW 1990 KX500 GRAY FITS 83-04 KX500 - 14031-1220 FITS 89-90 KX500, 89 KX125 KX250 - 32160-1031 - KAWI MAN SAYS IT FITS 89-04 KX500 FITS 90 KX500 - 33001-1347-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1990 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1990 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1990 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1990 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1990 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1990 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1991 KX500 JKAKXVE12MA00XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1991 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V563 FITS 90-93 KX500 - 39MM 1991 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1991 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1991 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1991 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 89-91 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE – 13031-1285 FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1991 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1991 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1991 KX500 F4T102 71 FITS 89-91 KX500 - 21007-1183 - 2.55lb or 41.6 oz. - 4.370" OD FITS 90 KX125 KX250, 90-91 KX500 - 34028-1318 - 34028-1319 1991 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD – KYB – X125-R X125-L - CHROME OD 43MM - C/L 37.25" - BLUE - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 61MM – AXLE CLAMP ID 22MM 43MM X 55MM X 9.5/10.5/11 1991 KX500 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 91 KX125, KX250, 91-93 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 91 KX250, 91-93 KX500 44039-1212 1991 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1991 KX500 FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056   FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 1991 KX500 FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1991 KX500 FITS 91-92 KX125 KX250, 91 KX500 - 43015-1443 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 1991 KX500 FITS 90-93 KX125 KX250 KX500 - 14024-1859-6F   F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 1991 KX500 GREEN – FITS 88-91 KX500 51001-1281-6W (SHOULD FIT 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1991 KX500 SET FITS 89-04 KX500 FITS 89-91 KX500 - 13168-1401 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 88-91 KX500 - 13064-1134 - KAWI MAN SAYS 86-04 WILL ALL WORK 1991 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 91 KX125 KX250 KX500 58029-5028-6W GREEN 800 ML = .846 QUARTS   FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1991 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 91 KX500  – 49089-5114-6W GREEN – FITS 91 KX500  – 49089-5115-6W 1991 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1991 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   WHITE - FITS 90-93 KX125 KX250 KX500, 90-94 KDX200, 93-96 KLX650R KLX650C, 94-96 KLX250R - 55020-1323-6F FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 FITS 91-93 KX500 - 43059-1682 1991 KX500 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 116MM FITS 91-94 KX125 KX250 KX500 - 41080-1294 FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1991 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1991 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1991 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 91 KX500  - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX500 - 13161-1144 1991 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 - 45014-1490 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1991 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1991 KX500 (2 coil style) FITS 87-89 KX500 - 21003-1169 - (1 COIL STYLE) FITS 89-91 - 21003-1215 - 432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW - 4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW 1991 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 91-93 KX500 - 33001-1371-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1991 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1991 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1991 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1991 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1991 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1991 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1992 KX500 JKAKXVE12NA00XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1992 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V563 FITS 90-93 KX500 - 39MM 1992 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1992 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1992 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1992 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1992 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1992 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1992 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 91 KX125 KX250 KDX25, 92 KX500 - 34028-1332 - 34028-1333 1992 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - CHROME OD 43MM - C/L 37.25" - BLUE - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 61MM 43MM X 55MM X 9.5/10.5/11 1992 KX500 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 91 KX125, KX250, 91-93 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 91 KX250, 91-93 KX500 44039-1212 1992 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1992 KX500 FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056   FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 1992 KX500 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1992 KX500 FITS 92-93 KX500 - 43015-1516 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 1992 KX500 FITS 90-93 KX125 KX250 KX500 - 14024-1859-6F   F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 1992 KX500 GREEN – FITS 92 KX500 51003-5390-6W (SHOULD FIT 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1992 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 92-97 KX500 - 13064-1165 - KAWI MAN SAYS 86-04 WILL ALL WORK 1992 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1992 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 92 KX500  – 49089-5136-6W GREEN – FITS 92 KX500  – 49089-5137-6W 1992 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1992 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   WHITE - FITS 90-93 KX125 KX250 KX500, 90-94 KDX200, 93-96 KLX650R KLX650C, 94-96 KLX250R - 55020-1323-6F FITS 92-95 KX500, 94 KX125 KX250 - 43044-1111 FITS 91-93 KX500 - 43059-1682 1992 KX500 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 116MM FITS 91-94 KX125 KX250 KX500 - 41080-1294 FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1992 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1992 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1992 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 92-93 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX500 - 13161-1144 1992 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 - 45014-1490 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1992 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1992 KX500 (1 COIL STYLE) BOOK SAYS FITS 92-96 KX500 - 21003-1242 - KAWI MAN SAYS 92-04 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1992 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 91-93 KX500 - 33001-1371-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1992 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1992 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1992 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1992 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1992 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1992 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1993 KX500 JKAKXVE12PA00XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1993 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V563 FITS 90-93 KX500 - 39MM 1993 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1993 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1993 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1993 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1993 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1993 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1993 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1993 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - CHROME OD 43MM - C/L 37.25" - BLUE - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 61MM 43MM X 55MM X 9.5/10.5/11 1993 KX500 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 91 KX125, KX250, 91-93 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 91 KX250, 91-93 KX500 44039-1212 1993 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1993 KX500 FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056   FITS 92-93 KX125 KX250, 93 KX500 - 43041-1462 1993 KX500 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1993 KX500 FITS 92-93 KX500 - 43015-1516 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200 1993 KX500 FITS 90-93 KX125 KX250 KX500 - 14024-1859-6F   F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 1993 KX500 GREEN – FITS 93-94 KX500 51001-1473-6W (KAWI MAN SAYS FITS 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1993 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 92-97 KX500 - 13064-1165 - KAWI MAN SAYS 86-04 WILL ALL WORK 1993 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1993 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 93 KX500  – 49089-5159-6W GREEN – FITS 93 KX500  – 49089-5160-6W 1993 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1993 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   WHITE - FITS 90-93 KX125 KX250 KX500, 90-94 KDX200, 93-96 KLX650R KLX650C, 94-96 KLX250R - 55020-1323-6F FITS 92-95 KX500, 94 KX125 KX250 - 43044-1111 FITS 91-93 KX500 - 43059-1682 1993 KX500 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 116MM FITS 91-94 KX125 KX250 KX500 - 41080-1294 FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1993 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1993 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1993 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 92-93 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX500 - 13161-1144 1993 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 - 45014-1490 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1993 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1993 KX500 (1 COIL STYLE) BOOK SAYS FITS 92-96 KX500 - 21003-1242 - KAWI MAN SAYS 92-04 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1993 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 91-93 KX500 - 33001-1371-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1993 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1993 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1993 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1993 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1993 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1993 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1994 KX500 JKAKXVE12RA00XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1994 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V923 FITS 94-95 KX500 - 39MM 1994 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1994 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1994 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1994 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1994 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1994 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1994 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1994 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 KYB KX94L KX94R - CHROME OD 43MM - C/L 37.25" - UPPER 51.9MM - LOWER 56.6MM - BRAKE CALIPER C/L 102MM 43MM X 55MM X 9.5/10.5/11 1994 KX500 FITS 94-95 KX125 KX250 KX500 - 55020-1492-RZ FITS 94-95 KX125 KX250 KX500 - LH 13070-1277 - RH 13070-1278 FITS 94-95 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 94-95 KX500 44039-1252 1994 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1994 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 1994 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 94 KX125 KX250 KX500 - 43059-1760 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 1994 KX500 FITS 94-95 KX125 KX250 KX500 KX80 - 43015-1556 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 1994 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 1994 KX500 GREEN – FITS 93-94 KX500 51001-1473-6W (KAWI MAN SAYS FITS 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1994 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 92-97 KX500 - 13064-1165 - KAWI MAN SAYS 86-04 WILL ALL WORK 1994 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1994 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 94 KX500  – 49089-5195-6W GREEN – FITS 94 KX500  – 49089-5196-6W 1994 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1994 FITS 94 KX125 KX250, 94-95 KX500 - 43041-1532 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 92-95 KX500, 94 KX125 KX250 - 43044-1111   1994 KX500 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 116MM FITS 91-94 KX125 KX250 KX500 - 41080-1294 FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1994 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1994 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1994 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 88-89 KX125 KX250, 88-90 KX500, 94 KX500  - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 1994 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1994 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1994 KX500 (1 COIL STYLE) BOOK SAYS FITS 92-96 KX500 - 21003-1242 - KAWI MAN SAYS 92-04 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1994 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 94-95 KX500 - 33001-1371-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1994 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1994 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1994 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1994 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1994 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1994 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1995 KX500 JKAKXVE12SA00XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1995 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK V923 FITS 94-95 KX500 - 39MM 1995 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1995 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1995 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1995 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1995 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1995 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1995 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1995 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 KYB KX94L KX94R - CHROME OD 43MM - C/L 37.25" - UPPER 51.9MM - LOWER 56.6MM - BRAKE CALIPER C/L 102MM 43MM X 55MM X 9.5/10.5/11 1995 KX500 FITS 94-95 KX125 KX250 KX500 - 55020-1492-RZ FITS 94-95 KX125 KX250 KX500 - LH 13070-1277 - RH 13070-1278 FITS 94-95 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 94-95 KX500 44039-1252 1995 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1995 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 1995 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 95 KX125 KX250 KX500 - 43059-1881 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 1995 KX500 FITS 94-95 KX125 KX250 KX500 KX80 - 43015-1556 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 1995 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 1995 KX500 GREEN – FITS 95 KX500 51080-5123-6W (SHOULD FIT 88-04 KX500) FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089 1995 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 92-97 KX500 - 13064-1165 - KAWI MAN SAYS 86-04 WILL ALL WORK 1995 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1995 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 GREEN – FITS 95 KX500  – 49089-5229-6W GREEN – FITS 95 KX500  – 49089-5230-6W 1995 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1995 FITS 94 KX125 KX250, 94-95 KX500 - 43041-1532 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 92-95 KX500, 94 KX125 KX250 - 43044-1111   1995 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1995 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1995 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1995 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 95 & 97 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 1995 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1995 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1995 KX500 (1 COIL STYLE) BOOK SAYS FITS 92-96 KX500 - 21003-1242 - KAWI MAN SAYS 92-04 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1995 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 94-95 KX500 - 33001-1371-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1995 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1995 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1995 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1995 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1995 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1995 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1996 KX500 JKAKXVE12TA01XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1996 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 1996 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1996 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1996 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1996 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1996 KX500 FITS 88-96 KX500, 93-95 KLX650, 94-96 KLX250 - 52014-1065 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 89-96 KX500 - 18002-1862 20055 FITS 88-04 KX500 1996 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1996 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1996 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 CHROME OD 43MM C/L 37.25" - FITS 96 KX500 43MM X 55MM X 9.5/10.5/11 1996 KX500   FITS 96 KX500  FITS 96 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 96 KX500  44039-1266 1996 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1996 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 1996 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 1996 KX500 FITS 96 KX125 KX250 KX500 - 43015-1574 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 1996 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 1996 KX500 VIOLET – FITS 96 KX500 51001-1473-RE (SHOULD FIT 88-04 KX500)   1996 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 92-97 KX500 - 13064-1165 - KAWI MAN SAYS 86-04 WILL ALL WORK 1996 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1996 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 88-96 KX500 - 39061-1112 39061-1113 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 VIOLET 14037-1099-RE FITS 96 KX500 KDX200 VIOLET – FITS 95 KX500  - 49089-1087-RE VIOLET – FITS 95 KX500  – 49089-1088-RE 1996 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1996 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    1996 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1996 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1213 OR 1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG - 41034-1205 1996 KX500 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM 1996 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 96 KX500  - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 1996 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1996 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 1996 KX500 (1 COIL STYLE) BOOK SAYS FITS 92-96 KX500 - 21003-1242 - KAWI MAN SAYS 92-04 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1996 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1996 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1996 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1996 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1996 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1996 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1996 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1997 KX500 JKAKXVE--VA--XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1997 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 1997 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1997 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1997 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1997 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1997 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 1997 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1997 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1997 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - KYB - KX94-L KX94-R - CHROME OD 46MM - C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 97-02 KX500 46MM X 58MM X 10.5 1997 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 97-99 KX500 44039-1269 1997 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1997 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 1997 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 1997 KX500 FITS 97-00 KX500 - 43015-1594 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 1997 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 1997 KX500 GREEN – FITS 97 KX500 51080-5349-6W (SHOULD FIT 88-04 KX500)   1997 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 92-97 KX500 - 13064-1165 - KAWI MAN SAYS 86-04 WILL ALL WORK 1997 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1997 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 1997 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1997 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    1997 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1997 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 1997 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 1997 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 95 & 97 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 1997 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1997 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 1997 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1997 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1997 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1997 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1997 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1997 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1997 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1997 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1998 KX500 JKAKXVE--WA--XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1998 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 1998 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1998 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1998 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1998 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1998 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 1998 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1998 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1998 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - KYB - KX94-L KX94-R - CHROME OD 46MM - C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 97-02 KX500 46MM X 58MM X 10.5 1998 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 97-99 KX500 44039-1269 1998 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1998 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 1998 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 1998 KX500 FITS 97-00 KX500 - 43015-1594 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 1998 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 1998 KX500 GREEN – FITS 98 KX500 51080-5428-6W (SHOULD FIT 88-04 KX500)   1998 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 1998 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1998 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 1998 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1998 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    1998 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1998 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 1998 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 1998 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 98-00 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 1998 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1998 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 1998 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1998 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1998 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1998 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1998 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1998 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1998 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1998 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
1999 KX500 JKAKXVE--XA--XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1999 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 1999 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 1999 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1999 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1999 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 1999 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 1999 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 1999 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 1999 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - KYB - KX94-L KX94-R - CHROME OD 46MM - C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 97-02 KX500 46MM X 58MM X 10.5 1999 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 97-99 KX500 44039-1269 1999 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1999 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 1999 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 1999 KX500 FITS 97-00 KX500 - 43015-1594 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 1999 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 1999 KX500 GREEN – FITS 99 KX500 51081-5070-6W (SHOULD FIT 88-04 KX500)   1999 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 1999 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 1999 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 1999 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 1999 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    1999 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 1999 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 1999 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 1999 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 98-00 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 1999 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1999 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 1999 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 1999 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1999 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  1999 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   1999 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 1999 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 1999 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1999 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
2000 KX500 JKAKXVEC7YA02XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 2000 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 2000 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 2000 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 2000 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 2000 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 2000 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 2000 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 2000 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 2000 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - KYB - KX94-L KX94-R - CHROME OD 46MM - C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 97-02 KX500 46MM X 58MM X 10.5 2000 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 00-04 KX500 44039-1295 2000 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 2000 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 2000 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 2000 KX500 FITS 97-00 KX500 - 43015-1594 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 2000 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 2000 KX500 GREEN – FITS 00 KX500 51081-5199-6W (SHOULD FIT 88-04 KX500)   2000 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 2000 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 2000 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 2000 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 2000 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    2000 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 2000 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 2000 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 2000 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 98-00 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 2000 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 2000 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 2000 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 2000 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2000 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  2000 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   2000 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 2000 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 2000 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2000 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
2001 KX500 JKAKXMLC91A02XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 2001 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 2001 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 2001 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 2001 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 2001 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 2001 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 2001 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 2001 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 2001 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - KYB - KX94-L KX94-R - CHROME OD 46MM - C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 97-02 KX500 46MM X 58MM X 10.5 2001 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 00-04 KX500 44039-1295 2001 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 2001 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 2001 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 2001 KX500 FITS 01-03 KX500 - 43015-1657 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 2001 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 2001 KX500 GREEN – FITS 01 KX500 51081-5379-6W (SHOULD FIT 88-04 KX500)   2001 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 2001 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 2001 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 2001 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 2001 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    2001 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 2001 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 2001 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 2001 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 01-02 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 2001 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 2001 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 2001 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 2001 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2001 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  2001 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   2001 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 2001 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 2001 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2001 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
2002 KX500 JKAKX----2----XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 2002 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 2002 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 2002 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 2002 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 2002 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 2002 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 2002 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 2002 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 2002 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 USD - KYB - KX94-L KX94-R - CHROME OD 46MM - C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 97-02 KX500 46MM X 58MM X 10.5 2002 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 00-04 KX500 44039-1295 2002 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 2002 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 2002 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 2002 KX500 FITS 01-03 KX500 - 43015-1657 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 2002 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 2002 KX500 GREEN – FITS 02 KX500 51082-5067-6W (SHOULD FIT 88-04 KX500)   2002 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 2002 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 2002 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 2002 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 2002 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F   FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    2002 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 2002 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 2002 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 2002 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 01-02 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 2002 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 2002 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 96-02 KX500 – 36001-1390-6F WHITE – FITS 96-02 KX500 – 36001-1419-6F 2002 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 2002 KX500 GRAY FITS 83-04 KX500 - 14031-1220 ALUMINUM COLOR - FITS 91-02 KX500 - 32160-1170 - KAWI MAN SAYS IT FITS 89-04 FITS 96-02 KX500 - 33001-1496-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2002 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  2002 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   2002 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 2002 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 2002 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2002 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
2003 KX500 JKAKXVECO3AO3XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 2003 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 2003 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 2003 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 2003 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 2003 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 2003 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 2003 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 2003 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 2003 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 CHROME OD 46MM C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 03-04 KX500 46MM X 58MM X 10.5 2003 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 00-04 KX500 44039-1295 2003 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 2003 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580 ML3 3 - FITS 94-96 KX125 & KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220, 96 KLX650R, 97-03 KLX300R - 43041-1576 2003 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 2003 KX500 FITS 01-03 KX500 - 43015-1657 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 2003 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 2003 KX500 BLACK – FITS 03 KX500 51082-5386-6Z (SHOULD FIT 88-04 KX500)   2003 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 2003 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 03-04 KX500 58029-1078-266 WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 2003 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 2003 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 2003 FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577     FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    2003 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 2003 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 2003 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 2003 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 03-04 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 2003 KX500 KYB - Spring thickness: 12.0MM OD - Spring Dia: 89MM - BODY DIA 53.5MM - Spring as mounted: 265MM - Upper tab: 20MM - Upper tab hole ID: 10MM - Lower Mount INTERNAL: 22.8MM – LOWER MOUNT EXTERNAL 41.7MM - Lower mount hole ID: 10MM - Eye to Eye: 450MM – FITS AT LEAST 90-04 KX500 1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 2003 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 03-04 KX500 - 36001-1390-266 WHITE – FITS 03-04 KX500 – 36001-1419-266 2003 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 2003 KX500 GRAY FITS 83-04 KX500 - 14031-1220 GRAY - FITS 03-04 KX500 - 32160-1807-GD - KAWAI MAN SAYS IT FITS 89-04 FITS 03-04 KX500 - 33001-1496-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2003 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  2003 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   2003 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 2003 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 2003 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2003 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
2004 KX500 JKAKX----4----XXXX KX500BE013001 FITS 89-04 KX500 - set 14001-5258 FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 2004 KX500 1360 - FITS 89-04 KX500 - 14073-1360 FITS 90 KX250, 90-04 KX500 - 54011-1304 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 KEIHIN PWK G250 FITS 96-04 KX500 - 39MM 2004 KX500   FITS 89-04 KX500 - 16065-1180 FITS 89-04 KX500 – 21119-1267 - 19 deg BTDC @ 6000 RPM 2004 KX500 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 2004 KX500 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 90 KX250, 90-04 KX500 13102-1107 - IT WILL FIT 88-04 KX500 17T & 66T - FITS 87-04 KX500 - 13095-1196   FITS 88-04 KX500 - 14032-1245 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 - 6 bolt posts FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 2004 KX500 F6T536 FITS 83-04 KX500 - 21121-1186 - 2.6-3.6 K ohms   BOOK SAYS 92-04 KX500, KAWAI MAN SAYS 89-04 - 29.95 MM FLY WHEEL SIDE – 30.00 PRIMARY GEAR SIDE – 86MM STD STROKE - 13031-1340 - 9.2LB FITS 85-04 KX500 - 8148 FITS 89-04 KX500 – 86MM STD BORE - 11005-1564 2004 KX500 FITS 97-04 KX500, 93-96 KLX650C, 96 KLX650R, 97-07 KLX300R - 52014-1084 FITS 89-04 KX500 - 32029-1652 FITS 89-04 KX500 - 32029-1639 FITS 97-04 KX500 20055 FITS 88-04 KX500 2004 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 FITS 89-04 KX500 3 VALVE FITS 88-92 KX250, 89-04 KX500 - 14024-1588 FITS 88-04 KX500 - 14024-1611 2004 KX500 F4T107 71 FITS 92-04 KX500 - 21007-1241 - 2.55lb or 41.6 oz. - 4.370" OD FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE 2004 KX500 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 CHROME OD 46MM C/L 37.25" - UPPER 53.8MM - LOWER 58.9MM - BRAKE CALIPER C/L 102MM - FITS 03-04 KX500 46MM X 58MM X 10.5 2004 KX500 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 97-04 KX500 - 190MM C/L TO C/L OF FORK TUBES FITS 00-04 KX500 44039-1295 2004 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 2004 KX500 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342   FITS 93-03 KX125 KX250, 94-04 KX500 - 92143-1581 - 92143-1580   2004 KX500 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 2004 KX500 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674    2004 KX500   GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W F-1249 - AXLE OD 20MM - BRG TO BRG 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125 KX250, 94-04 KX500 - 41034-1226 2004 KX500 BLACK – FITS 04 KX500 51083-5077-6Z (SHOULD FIT 88-04 KX500)   2004 KX500 SET FITS 89-04 KX500 FITS 92-04 KX500 - 13168-1497 FITS 86-04 KX500, 87-92 KX250, 88-05 KX125, 88-06 KDX200, 97-05 KDX220 - 49114-1058 FITS 85-04 KX500 - 59051-1129 FITS 87-04 KX500 - 49111-1052 FITS 89-04 1288 E-2 OR E-1, GASKET SURFACE TO NUT SURFACE .913" - 11001-1288 26T - FITS 86-04 KX500 - 59051-1150 - CLICKI HERE FOR MEASURMENTS FITS 98-04 KX500 - 13064-1201 - KAWI MAN SAYS 86-04 WILL ALL WORK 2004 KX500 FITS 85-04 KX500 - 13066-1056  FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159 FITS 03-04 KX500 58029-1078-266 WHITE 800 ML = .846 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 FITS 74-91 KX125 KX250, 83-04 KX500 - 51023-1115 FLAT TOP 2 RINGS BOOK SAYS  90-04 KAWI MAN SAYS 83-04 WILL WORK 13001-1327 575M08600 FITS 88-04 KX500 86MM STD BORE 2004 KX500 26T - FITS 88-04 KX500 - 13097-1205 BOOK SAYS THEY FIT 97-04 KX500 - 39061-1235 39061-1236 BUT KAWI MAN SAYS THEY FIT 88-04 KX500 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250 GREEN – FITS 97-04 KX500 – 49089-1087-6W GREEN – FITS 97-04 KX500 – 49089-1088-6W 2004 KX500 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 HYDRAULIC BRAKE 2004 FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S     FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105    2004 KX500   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368 2004 KX500 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 2004 KX500 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM 2004 KX500 FITS 88-04 KX500, 91-94 KDX250 - 12021-1070 PAN STAMP 1531 – FITS 03-04 KX500 - KX GURU SAYS IT FITS 89-04 KX500 FITS 87-04 KX500 - 13239-1143 FITS 86-04 KX500 - 13140-1058, 13140-1059, 13140-1142 FITS 94-01 KX125 KX250, 94-04 KX500, 00-09 KX65 - 13156-1347 FITS 94-04 KX500 - 13161-1203 2004 KX500   1186 - FITS 90-04 KX500 - 39007-1186 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 2004 KX500 FITS 90-04 KX500 - 32037-1532 and 32037-1533 WHITE – FITS 03-04 KX500 - 36001-1390-266 WHITE – FITS 03-04 KX500 – 36001-1419-266 2004 KX500 (1 COIL STYLE) BOOK SAYS FITS 97-04 KX500 - 21003-1307 - KAWI MAN SAYS 92-04 - 153-230 OHMS: BLACK/WHITE TO BLACK/YELLOW - 7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW 2004 KX500 GRAY FITS 83-04 KX500 - 14031-1220 GRAY - FITS 03-04 KX500 - 32160-1807-GD - KAWAI MAN SAYS IT FITS 89-04 FITS 03-04 KX500 - 33001-1496-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2004 KX500 FITS 82-91 KX125, 83-91 KX250, 83-04 KX500 - 46019-1054 14025-1646 32099-1044 32099-1036 SHAFTS FIT 88-04 KX500 - GEARS FIT 90-04 KX500 16T - FITS 88-04 KX500 - 13127-1159 18T - FITS 90-04 KX500 - 13260-1100  2004 KX500 22T - FITS 90-04 KX500 - 13260-1101 22T - FITS 89-04 KX500 - 13260-1020 24T - FITS 86-04 KX500 - 13129-1744 FITS 88-04 KX500 - 13128-1150   2004 KX500 32T - FITS 80-81 KX420, 83-04 KX500 - 13129-1180 26T - FITS 90-04 KX500 - 13260-1102 2004 KX500 26T - FITS 90-04 KX500 - 13260-1103 21T - FITS 89-04 KX500 - 13260-1021 19T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 FITS 88-04 KX500 - 16142-1086 2004 KX500 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2004 KX500 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 88-89 KX250, 88-04 KX500, 89-06 KDX200 - 52014-1067 62 LB WITH OIL AND SPARK PLUG, NO CARBURETOR
YEAR TYPE VIN FRAME USA  ENGINE ID ENGINE CASES AIR BOX CAGE ELEMENT HOLDER AIR BOX NO BOOT (DUCT) YEAR TYPE AIR BOX BOOT JOINT DUCT CABLE CLUTCH CABLE THROTTLE CARBURETOR YEAR TYPE CARBURETOR FLOAT VALVE CARBURETOR BOOT CDI YEAR TYPE CHAIN ADJUSTER BLOCKS CHAIN GUIDE YEAR TYPE CHAIN SLIDE CLUTCH ARM CLUTCH BASKET CLUTCH FRICTION PLATES CLUTCH COVER CLUTCH HUB (INNER) CLUTCH PRESSURE PLATE (OUTER) YEAR TYPE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CRANK SHAFT ROD KIT HOT RODS CYLINDER YEAR TYPE CYLINDER WATER NECK ELBOW ENGINE MOUNTS FRONT ENGINE MOUNTS UPPER EXHAUST PIPE EXHAUST PIPE FMF GNARLY YEAR TYPE EXHAUST PIPE PRO CIRCUIT PLATINUM EXHAUST PIPE PRO CIRCUIT PLATINUM 2 EXHAUST PIPE PRO CIRCUIT WORKS EXHAUST VALVE EXHAUST VALVE COVER FRONT EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL FOOT PEGS YEAR TYPE FOOT PEG SPRINGS FORK FORK SEAL SIZES YEAR TYPE FORK GUARDS FORK GUARD MOUNTS FORK UNDER HOLDER (STEERING STEM LOWER CLAMP) TRIPLE TREE FORK UPPER HOLDER (TOP CLAMP) TRIPLE TREE YEAR TYPE FORK HOLDER BEARINGS (LOWER) FORK HOLDER BEARINGS (UPPER) YEAR TYPE FRONT AXLE FRONT AXLE HOLDER FRONT AXLE SPACERS COLLARS FRONT BRAKE CALIPER YEAR TYPE FRONT BRAKE CALIPER MOUNT FRONT BRAKE HOSE FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER FRONT BRAKE ROTOR YEAR TYPE FRONT BRAKE ROTOR GUARD FRONT FENDER FRONT HUB YEAR TYPE FUEL/GAS TANK GAS TANK CAP YEAR TYPE GOVERNOR GOVERNOR LEVER GOVERNOR SHAFT GOVERNOR WATER PUMP SPUR GEAR GOVERNOR WEIGHT HOLDER HEAD KICK IDLER GEAR KICK LEVER YEAR TYPE KICK LEVER SHAFT MUD FLAP NUMBER PLATE OIL CAPACITY OIL DRAIN PLUG PETCOCK FUEL VALVE TAP PISTON WISECO STD PISTON YEAR TYPE PRIMARY CRANK GEAR RADIATORS RADIATOR SCREENS RADIATOR SHROUDS RADIATOR SHROUD RIGHT YEAR TYPE REAR AXLE REAR BRAKE BACKING PLATE YEAR REAR BRAKE CALIPER REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER MOUNT REAR BRAKE HOSE YEAR TYPE REAR BRAKE ROTOR REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER YEAR TYPE REAR FENDER REAR HUB YEAR TYPE REAR WHEEL SPACERS YEAR TYPE REED VALVE SEAT SHIFT DRUM SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE UNI TRAK SHOCK ARM SUSPENSION RODS (DOG BONES) YEAR TYPE SHOCK BRACKETS SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR YEAR TYPE STATOR COVER SUB FRAME SWING ARM SWING ARM PIVOT PIN YEAR TYPE THROTTLE ASY TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION INPUT 2ND GEAR YEAR TYPE TRANSMISSION INPUT 3RD GEAR TRANSMISSION INPUT 4TH GEAR TRANSMISSION INPUT 5TH GEAR TRANSMISSION OUTPUT SHAFT TRANSMISSION OUTPUT SHAFT NUT YEAR TYPE TRANSMISSION OUTPUT 1ST GEAR TRANSMISSION OUTPUT 2ND GEAR YEAR TYPE TRANSMISSION OUTPUT 3RD GEAR TRANSMISSION OUTPUT 4TH GEAR TRANSMISSION OUTPUT 5TH GEAR WATER PUMP COVER YEAR TYPE WATER PUMP COVER NECK YEAR TYPE WATER PUMP IMPELLER WATER PUMP NECK ELBOW KX500 ENGINE WEIGHT
