OEM-CYCLE
OEM-Cycle
Kawasaki KDX175, KDX200, KDX220, KDX250, KDX450 ENGINE, PARTS, AND FRAME Identification page
In an effort to help fellow bikers properly ID their bike I have provided the following information on VIN ( Vehicle Identification Number ) , Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix it.
This information is not intended for use outside of this web site or for publication.
Scroll to the right as there is a lot of data :-)
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA ONLY AIR BOX CAGE ELEMENT HOLDER AIR BOX (NO BOOT) YEAR TYPE AIR BOX TO CARB BOOT CABLE THROTTLE CARBURETOR CARBURETOR BOOT CDI YEAR TYPE CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH HUB (INNER) CLUTCH FRICTION PLATES CLUTCH COVER YEAR TYPE CLUTCH COVER (INNER) CLUTCH PRESSURE PLATE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CYLINDER YEAR TYPE ENGINE MOUNTS FRONT   ENGINE MOUNTS UPPER EXHAUST ARRESTOR STOCK EXHAUST PIPE FMF FATTY EXHAUST VALVES EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR TYPE FORK INFO YEAR TYPE FORK SEAL SIZES FORK HOLDER LOWER (Bottom triple tree) FORK HOLDER UPPER (top triple tree) FORK GUARDS FORK GUARD MOUNTS YEAR TYPE FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE CALIPER MOUNT YEAR TYPE FRONT BRAKE ROTOR FRONT FENDER YEAR TYPE FRONT HUB YEAR TYPE GAS TANK GOVERNOR YEAR TYPE HEAD KICK IDLER GEAR KICK LEVER KICK LEVER SHAFT ASY YEAR TYPE MUD FLAP OIL LEVEL PISTON WISECO PRIMARY CRANK GEAR REAR AXLE YEAR TYPE RADIATOR LEFT RADIATOR RIGHT RADIATOR RESERVOIR YEAR TYPE RADIATOR SCREENS REAR BRAKE BACKING PLATE YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE REAR BRAKE MASTER CYLINDER REAR BRAKE ROD YEAR TYPE REAR BRAKE ROTOR REAR HUB YEAR TYPE REAR WHEEL SPACERS REED VALVE YEAR TYPE RIM SIZE SEAT SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR STATOR COVER SWING ARM SWING ARM PIVOT PIN YEAR TYPE TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT TRIPLE CLAMP BOTTOM TRIPLE CLAMP TOP VOLTAGE REGULATOR YEAR TYPE WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT WATER PUMP COVER NECK YEAR TYPE ENGINE WEIGHT YEAR TYPE
1980 KDX175   FITS 80-81 KX125, 80-82 KDX175     FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1980 KDX175         KOKUSAN DENKI - 21119-1015 - CU1501 - FITS 80-81 KDX175 - 21119-1015 1980 KDX175 FITS 80-81 KX125 KX250 KX420, 80-82 KDX175   1980 KDX175           1980 KDX175             1980 KDX175               1980 KDX175       1980 KDX175 CONVENTIONAL 1980 KDX175       CONVENTIONAL CONVENTIONAL 1980 KDX175       1980 KDX175   1980 KDX175   1980 KDX175     1980 KDX175 MAX DIA 120.75MM - AXLE DIA 12MM - BRG TO BRG 70-71MM - BLACK - DRUM STYLE - 36 SPOKE - FITS 79-80 KLX250, 80-82 KDX175 1980 KDX175     1980 KDX175   30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041     1980 KDX175           1980 KDX175       1980 KDX175     1980 KDX175         1980 KDX175     1980 KDX175     1980 KDX175           1980 KDX175         1980 KDX175         1980 KDX175             1980 KDX175         1980 KDX175 1980 KDX175
1981 KDX175   FITS 80-81 KX125, 80-82 KDX175     FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1981 KDX175         KOKUSAN DENKI - 21119-1015 - CU1501 - FITS 80-81 KDX175 - 21119-1015 1981 KDX175 FITS 80-81 KX125 KX250 KX420, 80-82 KDX175   1981 KDX175           1981 KDX175             1981 KDX175               1981 KDX175       1981 KDX175 CONVENTIONAL 1981 KDX175       CONVENTIONAL CONVENTIONAL 1981 KDX175       1981 KDX175   1981 KDX175   1981 KDX175     1981 KDX175 MAX DIA 120.75MM - AXLE DIA 12MM - BRG TO BRG 70-71MM - BLACK - DRUM STYLE - 36 SPOKE - FITS 79-80 KLX250, 80-82 KDX175 1981 KDX175     1981 KDX175   30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041     1981 KDX175           1981 KDX175       1981 KDX175     1981 KDX175         1981 KDX175     1981 KDX175     1981 KDX175           1981 KDX175         1981 KDX175         1981 KDX175             1981 KDX175         1981 KDX175 1981 KDX175
1982 KDX175   FITS 80-81 KX125, 80-82 KDX175     FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1982 KDX175           1982 KDX175 FITS 80-81 KX125 KX250 KX420, 80-82 KDX175   1982 KDX175           1982 KDX175             1982 KDX175               1982 KDX175       1982 KDX175 CONVENTIONAL 1982 KDX175       CONVENTIONAL CONVENTIONAL 1982 KDX175       1982 KDX175   1982 KDX175   1982 KDX175     1982 KDX175 MAX DIA 120.75MM - AXLE DIA 12MM - BRG TO BRG 70-71MM - BLACK - DRUM STYLE - 36 SPOKE - FITS 79-80 KLX250, 80-82 KDX175 1982 KDX175     1982 KDX175   30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041     1982 KDX175           1982 KDX175       1982 KDX175     1982 KDX175         1982 KDX175     1982 KDX175     1982 KDX175           1982 KDX175         1982 KDX175         1982 KDX175             1982 KDX175         1982 KDX175 1982 KDX175
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA ONLY AIR BOX CAGE ELEMENT HOLDER AIR BOX (NO BOOT) YEAR TYPE AIR BOX TO CARB BOOT CABLE THROTTLE CARBURETOR CARBURETOR BOOT CDI YEAR TYPE CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH HUB (INNER) CLUTCH FRICTION PLATES CLUTCH COVER YEAR TYPE CLUTCH COVER (INNER) CLUTCH PRESSURE PLATE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CYLINDER YEAR TYPE ENGINE MOUNTS FRONT ENGINE MOUNTS REAR ENGINE MOUNTS UPPER EXHAUST ARRESTOR STOCK EXHAUST PIPE FMF FATTY EXHAUST VALVES EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR TYPE FORK INFO YEAR TYPE FORK SEAL SIZES FORK HOLDER LOWER (Bottom triple tree) FORK HOLDER UPPER (top triple tree) FORK GUARDS FORK GUARD MOUNTS YEAR TYPE FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE CALIPER MOUNT YEAR TYPE FRONT BRAKE ROTOR FRONT FENDER YEAR TYPE FRONT HUB YEAR TYPE GAS TANK GOVERNOR YEAR TYPE HEAD KICK IDLER GEAR KICK LEVER KICK LEVER SHAFT YEAR TYPE MUD FLAP OIL LEVEL PISTON WISECO PRIMARY CRANK GEAR REAR AXLE YEAR TYPE RADIATOR LEFT RADIATOR RIGHT RADIATOR RESERVOIR YEAR TYPE RADIATOR SCREENS REAR BRAKE BACKING PLATE YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE REAR BRAKE MASTER CYLINDER REAR BRAKE ROD YEAR TYPE REAR BRAKE ROTOR REAR HUB YEAR TYPE REAR WHEEL SPACERS REED VALVE YEAR TYPE RIM SIZE SEAT SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR STATOR COVER SWING ARM SWING ARM PIVOT PIN YEAR TYPE TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT TRIPLE CLAMP BOTTOM TRIPLE CLAMP TOP VOLTAGE REGULATOR YEAR TYPE WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT WATER PUMP COVER NECK YEAR TYPE ENGINE WEIGHT YEAR TYPE
1983 KDX200   FITS 83-85 KDX200     FITS 83-85 KDX200, 83-84 KDX250 - 11011-1125 1983 KDX200 FITS 82-83 KX125, 83-85 KDX200 - 14073-1091     FITS 84-85 KX125 83-85 KDX200   1983 KDX200 FITS 82-83 KX125, 83-84 KX250 & KX500, 83 KDX200 & KDX250 FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 1983 KDX200           1983 KDX200       FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119   1349 – FITS 83-85 KDX200 - 11005-1349 1983 KDX200               1983 KDX200 FITS 83-85 KDX200     1983 KDX200 CONVENTIONAL 1983 KDX200 38mm x 50mm x 10.5      CONVENTIONAL CONVENTIONAL 1983 KDX200       1983 KDX200   1983 KDX200   1983 KDX200     1983 KDX200   1983 KDX200     1983 KDX200   30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 83-88 kdx200 - 13064-1128   1983 KDX200     N/A     1983 KDX200       1983 KDX200     1983 KDX200         1983 KDX200   FITS 84 KX125, 83-85 KDX200 - 41034-1108 1983 KDX200     1983 KDX200         FITS 85-87 KX125, 83-85 KDX200 - 13161-1101 1983 KDX200         1983 KDX200 FITS 83-85 KDX200     FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1983 KDX200             1983 KDX200         1983 KDX200 1983 KDX200
1984 KDX200   FITS 83-85 KDX200     FITS 83-85 KDX200, 83-84 KDX250 - 11011-1125 1984 KDX200 FITS 82-83 KX125, 83-85 KDX200 - 14073-1091     FITS 84-85 KX125 83-85 KDX200   1984 KDX200   FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 1984 KDX200           1984 KDX200       FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119   1349 – FITS 83-85 KDX200 - 11005-1349 1984 KDX200               1984 KDX200 FITS 83-85 KDX200   83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1984 KDX200 CONVENTIONAL 1984 KDX200 38mm x 50mm x 10.5      CONVENTIONAL CONVENTIONAL 1984 KDX200       1984 KDX200   1984 KDX200   1984 KDX200     1984 KDX200   1984 KDX200     1984 KDX200   30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 83-88 kdx200 - 13064-1128   1984 KDX200     N/A     1984 KDX200       1984 KDX200     1984 KDX200         1984 KDX200   FITS 84 KX125, 83-85 KDX200 - 41034-1108 1984 KDX200     1984 KDX200         FITS 85-87 KX125, 83-85 KDX200 - 13161-1101 1984 KDX200         1984 KDX200 FITS 83-85 KDX200     FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1984 KDX200             1984 KDX200         1984 KDX200 1984 KDX200
1985 KDX200   FITS 83-85 KDX200     FITS 83-85 KDX200, 83-84 KDX250 - 11011-1125 1985 KDX200 FITS 82-83 KX125, 83-85 KDX200 - 14073-1091     FITS 84-85 KX125 83-85 KDX200   1985 KDX200   FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 1985 KDX200           1985 KDX200     CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119   1349 – FITS 83-85 KDX200 - 11005-1349 1985 KDX200               1985 KDX200 FITS 83-85 KDX200   83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1985 KDX200 CONVENTIONAL 1985 KDX200 38mm x 50mm x 10.5      CONVENTIONAL CONVENTIONAL 1985 KDX200       1985 KDX200   1985 KDX200   1985 KDX200     1985 KDX200   1985 KDX200     1985 KDX200   30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 83-88 kdx200 - 13064-1128   1985 KDX200     N/A     1985 KDX200       1985 KDX200     1985 KDX200         1985 KDX200   FITS 84 KX125, 83-85 KDX200 - 41034-1108 1985 KDX200     1985 KDX200         FITS 85-87 KX125, 83-85 KDX200 - 13161-1101 1985 KDX200         1985 KDX200 FITS 83-85 KDX200     FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1985 KDX200             1985 KDX200         1985 KDX200 1985 KDX200
1986 KDX200   FITS 86-87 KDX200 - 14001-5209     FITS 86-88 KDX200 – 11011-1205 1986 KDX200 FITS 86-87 KDX200   FITS 86+-87 KDX200 - 15001-1202 FITS 86-87 KDX200 FITS 86-88 KDX200 1986 KDX200   FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 1986 KDX200           1986 KDX200     CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 58MM STROKE 1491 – FITS 86-87 KDX200 – 11005-1491 - 66MM STD BORE 1986 KDX200           FITS 86-88 KDX200   1986 KDX200 FITS 86-88 KDX200 FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1986 KDX200 CONVENTIONAL 1986 KDX200 43mm x 55mm x 9.5/10.5/11      CONVENTIONAL CONVENTIONAL 1986 KDX200   FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1986 KDX200 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1986 KDX200   1986 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 GREEN - FITS 88 KX250 KX500, 86-88 KDX200 - 35004-1176-6W   1986 KDX200 F-1161 PAT 585873 - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - ROTOR DIA 250 MM - ROTOR ID 130MM - ROTOR BOLT CIRCLE 8 ON 146.5MM - FITS 1986 KDX200 ONLY 1986 KDX200     1986 KDX200 FITS 86-87 KDX200 - 11001-1215 AIR COOLED 30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 83-88 kdx200 - 13064-1128   1986 KDX200     711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 86-88 KDX200 - 41068-1211 1986 KDX200       1986 KDX200     1986 KDX200       FITS 86-88 KDX200 - 43011-1126 1986 KDX200   R-1122-1 - 20MM - BRG TO BRG 118MM - SPROCKET BOLT CIRCLE 6 ON 150MM - SPROCKET ID 134MM DRUM STYLE BRAKE - FITS 86 KDX200 - 41034-1146 1986 KDX200     1986 KDX200     FITS 86-94 KDX200 FITS 86-88 KDX200 13156-1220 FITS 86-88 KDX200 - 13156-1220 1986 KDX200 FITS 86 KDX200 ONLY (ACCORDING TO THE BOOK)       1986 KDX200 FITS 86-88 KDX200     FITS 86-87 KDX200 - 33032-1118 MEASUREMENTS 1986 KDX200             1986 KDX200         1986 KDX200 1986 KDX200
1987 KDX200 KHI DX200 CE01XXXX FITS 86-87 KDX200 - 14001-5209     FITS 86-88 KDX200 – 11011-1205 1987 KDX200 FITS 86-87 KDX200   FITS 86+-87 KDX200 - 15001-1202 FITS 86-87 KDX200 FITS 86-88 KDX200 1987 KDX200   FITS 87 KX125 KX250 KX500, 87-88 KDX200, 87-88 KXF250 1987 KDX200           1987 KDX200       FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 58MM STROKE 1491 – FITS 86-87 KDX200 – 11005-1491 - 66MM STD BORE 1987 KDX200           FITS 86-88 KDX200   1987 KDX200 FITS 86-88 KDX200 FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1987 KDX200 CONVENTIONAL - CHROME OD 43MM - C/L 35 3/8" 1987 KDX200 43mm x 55mm x 9.5/10.5/11      CONVENTIONAL CONVENTIONAL 1987 KDX200   FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1987 KDX200 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1987 KDX200   1987 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 GREEN - FITS 88 KX250 KX500, 86-88 KDX200 - 35004-1176-6W   1987 KDX200 F-1161 PAT 585873 - GREY - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - FITS 87-92 KDX200 - 41034-1156 1987 KDX200     1987 KDX200 FITS 86-87 KDX200 - 11001-1215 AIR COOLED 30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 83-88 kdx200 - 13064-1128   1987 KDX200     711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 86-88 KDX200 - 41068-1211 1987 KDX200       1987 KDX200     1987 KDX200       FITS 86-88 KDX200 - 43011-1126 1987 KDX200   R-1122-1 - 20MM - BRG TO BRG 118MM - SPROCKET BOLT CIRCLE 6 ON 150MM - SPROCKET ID 134MM DRUM STYLE BRAKE - FITS 87-88 KDX200 - 41034-1157 1987 KDX200     1987 KDX200     FITS 86-94 KDX200 FITS 86-88 KDX200 13156-1220 FITS 86-88 KDX200 - 13156-1220 1987 KDX200 FITS 87 KDX200 ONLY (ACCORDING TO THE BOOK) -       1987 KDX200 FITS 86-88 KDX200     FITS 86-87 KDX200 - 33032-1118 MEASUREMENTS 1987 KDX200             1987 KDX200         1987 KDX200 1987 KDX200
1988 KDX200   FITS 88 KDX20 ONLY     FITS 86-88 KDX200 – 11011-1205 1988 KDX200 FITS 88 KDX200 - 14073-1335 FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 FITS 88 KDX200 ONLY FITS 88 KDX200 ONLY FITS 86-88 KDX200 1988 KDX200   FITS 87 KX125 KX250 KX500, 87-88 KDX200, 87-88 KXF250 1988 KDX200           1988 KDX200         58MM STROKE 1530 – FITS 88 KDX200 ONLY - 11005-1530  1988 KDX200           FITS 86-88 KDX200   1988 KDX200 FITS 86-88 KDX200   83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1988 KDX200 CONVENTIONAL 1988 KDX200 43mm x 55mm x 9.5/10.5/11      CONVENTIONAL CONVENTIONAL 1988 KDX200     FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 1988 KDX200 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1988 KDX200 FITS 88-92 KX250 - 43044-1034 1988 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 GREEN - FITS 88 KX250 KX500, 86-88 KDX200 - 35004-1176-6W   1988 KDX200 F-1161 PAT 585873 - GREY - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - FITS 87-92 KDX200 - 41034-1156 1988 KDX200   FITS 88-06 KDX200 1988 KDX200 FITS 88 KDX200 - 11001-1260 AIR COOLED 30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 83-88 kdx200 - 13064-1128   1988 KDX200     711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 86-88 KDX200 - 41068-1211 1988 KDX200       1988 KDX200     1988 KDX200       FITS 86-88 KDX200 - 43011-1126 1988 KDX200   R-1122-1 - 20MM - BRG TO BRG 118MM - SPROCKET BOLT CIRCLE 6 ON 150MM - SPROCKET ID 134MM DRUM STYLE BRAKE - FITS 87-88 KDX200 - 41034-1157 1988 KDX200   FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1988 KDX200 1.85 X 18 FITS 88 ONLY   FITS 86-94 KDX200 FITS 86-88 KDX200 13156-1220 FITS 88 KDX200 13161-1148 1988 KDX200 FITS 88 KDX200 ONLY (ACCORDING TO THE BOOK) - 45014-1402       1988 KDX200 FITS 86-88 KDX200       1988 KDX200             1988 KDX200       FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1988 KDX200 1988 KDX200
1989 KDX200 KHI DX200 EE01XXXX FITS 89 KDX200 ONLY   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89-94 KDX200 – 11011-1297 1989 KDX200 FITS 89-94 KDX200 - 14073-1362     DX200 FITS 89-94 KDX200 16065-1181 - 16065-1181 FITS 89-94 KDX200 - 21119-1257 - BLACK MALE BULLET, BLACK EYE RING, BLACK/WHITE FEMALE BULLET, BLACK/YELLOW FLAT FEMALE, WHITE/RED FEMALE BULLET 1989 KDX200 FITS 89-94 KDX200 - 12053-1235 - 12053-1255 - 12053-1270 FITS 89-94 KDX200 -  12053-1240 1989 KDX200 FITS 89-91 KDX200, 89 KX125 - 13236-1195 FITS 89-94 KDX200 – 13095-1189 FITS 89-94 KDX200 - 13087-1111   FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 1989 KDX200  fits 89-90 kdx200 - 14032-1262 FITS 89-94 KDX200, 89 KX125 - 13086-1060 FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms   FITS 89-94 KDX200 - 58MM STROKE - 13031-1300 1569 – FITS 89-94 KDX200 - 11005-1569 1989 KDX200         20037 FITS 89-94 KDX200 FITS 89-94 KDX200 - 12005-1121 - 12005-1122 - 12005-1157 FITS 89 KX125, 89-94 KDX200 - 14024-1786 1989 KDX200 F4T100 FITS 89-94 KDX200 - 21007-1177 FITS 89-94 KDX200 - 34028-1302 - 34028-1303 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1989 KDX200 CONVENTIONAL 1989 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 89-92 KDX200 - 44037-1248 44039-1154 FITS 89-92 KDX200 - 44037-1248 44039-1154 CONVENTIONAL CONVENTIONAL 1989 KDX200  FITS 90-92 KDX200 - 41068-1291   FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1989 KDX200   1989 KDX200 FITS 88-92 KX250 - 43044-1034 1989 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 89-92 KDX200 - 41080-1252   1989 KDX200 F-1161 PAT 585873 - GREY - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - FITS 87-92 KDX200 - 41034-1156 1989 KDX200 fits 89-94 kdx200 - 51001-1301-6W FITS 88-06 KDX200 1989 KDX200 FITS 89 KDX200 - 11001-1291 30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 89-94 KDX200 - 13064-1148  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1989 KDX200 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159   711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157   1989 KDX200 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89-94 KDX200 - 39061-1131 FITS 89-91 KDX200 - 43078-1095 1989 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1989 KDX200 FITS 89-90 KDX200 - 43041-1295   FITS 89-94 KDX200 43015-1388 HYDRAULIC 1989 KDX200 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 R-1213 – GRAY – 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM – 36 SPOKES – FITS 89 KDX200, KX125, KX250, KX500 1989 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1989 KDX200 1.85 X 18 FITS 89-94    FITS 86-94 KDX200   FITS 89-94 KDX200 - 13161-1170 1989 KDX200 FITS 89 KDX200 ONLY (ACCORDING TO THE BOOK) - 45014-1420-CC FITS 89-94 KDX200 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1989 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 89-93 KDX200 - 33001-1327-CE  FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1989 KDX200   13T - FITS 89-94 KDX200 - 13127-1175 FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1989 KDX200 FITS 89-06 KDX200 - 16142-1090 FITS 88-90 KX125, 88-91 KX250, 87-88 KXF250, 89-94 KDX200, 91-94 KDX250 - 59256-1067 89-90 KDX200 - 13234-1089 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1989 KDX200 49.9LB NO CARB W/SPARK PLUG KICKER AND OIL 1989 KDX200
1990 KDX200 KHI DX200 0085XX FITS 90-95 KDX200 - 14001-5331 JKADXNE11LA0085## FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89-94 KDX200 – 11011-1297 1990 KDX200 FITS 89-94 KDX200 - 14073-1362   KEIHIN PWK V564 35MM FITS 90-94 KDX200 - 15001-1564 DX200 FITS 89-94 KDX200 16065-1181 - 16065-1181 FITS 89-94 KDX200 - 21119-1257 - BLACK MALE BULLET, BLACK EYE RING, BLACK/WHITE FEMALE BULLET, BLACK/YELLOW FLAT FEMALE, WHITE/RED FEMALE BULLET 1990 KDX200 FITS 89-94 KDX200 - 12053-1235 - 12053-1255 - 12053-1270 FITS 89-94 KDX200 -  12053-1240 1990 KDX200 FITS 89-91 KDX200, 89 KX125 - 13236-1195 FITS 89-94 KDX200 – 13095-1189 FITS 89-94 KDX200 - 13087-1111   FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 1990 KDX200  fits 89-90 kdx200 - 14032-1262 FITS 89-94 KDX200, 89 KX125 - 13086-1060 FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms   FITS 89-94 KDX200 - 58MM STROKE - 13031-1300 1569 – FITS 89-94 KDX200 - 11005-1569 1990 KDX200 FITS 90-94 KDX200 - 32029-1688 FITS 90-94 KDX200 - 32037-1535 - 32037-1536   FITS 90 KDX200 - 49069-1117 20037 FITS 89-94 KDX200 FITS 89-94 KDX200 - 12005-1121 - 12005-1122 - 12005-1157 FITS 89 KX125, 89-94 KDX200 - 14024-1786 1990 KDX200 F4T100 FITS 89-94 KDX200 - 21007-1177 FITS 89-94 KDX200 - 34028-1302 - 34028-1303 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1990 KDX200 CONVENTIONAL - CHROME OD 43MM - C/L 35 3/4" - BRAKE MOUNT C/L 61.5MM - AXLE 15MM - FITS 90-92 KDX200 - 44001-1711-GF 1990 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 89-92 KDX200 - 44037-1248 44039-1154 FITS 89-92 KDX200 - 44037-1248 44039-1154 CONVENTIONAL CONVENTIONAL 1990 KDX200  FITS 90-92 KDX200 - 41068-1291 FITS 90 KDX200 - 43041-1312 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1990 KDX200 FITS 90 KDX200 - 43015-1423 1990 KDX200 FITS 88-92 KX250 - 43044-1034 1990 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 89-92 KDX200 - 41080-1252 WHITE FITS 90-91 KDX200 - 35004-1233-6F 1990 KDX200 F-1161 PAT 585873 - GREY - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - FITS 87-92 KDX200 - 41034-1156 1990 KDX200 fits 89-94 kdx200 - 51001-1301-6W FITS 88-06 KDX200 1990 KDX200 FITS 90-94 KDX200 - 11001-1317 30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 89-94 KDX200 - 13064-1148  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1990 KDX200 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159   711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 90-94 KDX200 - 41068-1297 1990 KDX200 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89-94 KDX200 - 39061-1131 FITS 89-91 KDX200 - 43078-1095 1990 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1990 KDX200 FITS 89-90 KDX200 - 43041-1295   FITS 89-94 KDX200 43015-1388 HYDRAULIC 1990 KDX200 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 1990 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1990 KDX200 1.85 X 18 FITS 89-94    FITS 86-94 KDX200   FITS 89-94 KDX200 - 13161-1170 1990 KDX200 FITS 90 KDX200 ONLY (ACCORDING TO THE BOOK) - 45014-1469 FITS 89-94 KDX200 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1990 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 89-93 KDX200 - 33001-1327-CE  FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1990 KDX200   13T - FITS 89-94 KDX200 - 13127-1175 FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1990 KDX200 FITS 89-06 KDX200 - 16142-1090 FITS 88-90 KX125, 88-91 KX250, 87-88 KXF250, 89-94 KDX200, 91-94 KDX250 - 59256-1067 89-90 KDX200 - 13234-1089 FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1990 KDX200 49.9LB NO CARB W/SPARK PLUG KICKER AND OIL 1990 KDX200
1991 KDX200   FITS 90-95 KDX200 - 14001-5331   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89-94 KDX200 – 11011-1297 1991 KDX200 FITS 89-94 KDX200 - 14073-1362   KEIHIN PWK V564 35MM FITS 90-94 KDX200 - 15001-1564 DX200 FITS 89-94 KDX200 16065-1181 - 16065-1181 FITS 89-94 KDX200 - 21119-1257 - BLACK MALE BULLET, BLACK EYE RING, BLACK/WHITE FEMALE BULLET, BLACK/YELLOW FLAT FEMALE, WHITE/RED FEMALE BULLET 1991 KDX200 FITS 89-94 KDX200 - 12053-1235 - 12053-1255 - 12053-1270 FITS 89-94 KDX200 -  12053-1240 1991 KDX200 FITS 89-91 KDX200, 89 KX125 - 13236-1195 FITS 89-94 KDX200 – 13095-1189 FITS 89-94 KDX200 - 13087-1111   FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 1991 KDX200 FITS 91-94 KDX200 14032-1296 FITS 89-94 KDX200, 89 KX125 - 13086-1060 FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms   FITS 89-94 KDX200 - 58MM STROKE - 13031-1300 1569 – FITS 89-94 KDX200 - 11005-1569 1991 KDX200 FITS 90-94 KDX200 - 32029-1688 FITS 90-94 KDX200 - 32037-1535 - 32037-1536     20037 FITS 89-94 KDX200 FITS 89-94 KDX200 - 12005-1121 - 12005-1122 - 12005-1157 FITS 89 KX125, 89-94 KDX200 - 14024-1786 1991 KDX200 F4T100 FITS 89-94 KDX200 - 21007-1177 FITS 89-94 KDX200 - 34028-1302 - 34028-1303 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1991 KDX200 CONVENTIONAL - CHROME OD 43MM - C/L 35 3/4" - BRAKE MOUNT C/L 61.5MM - AXLE 15MM - FITS 90-92 KDX200 - 44001-1711-GF 1991 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 89-92 KDX200 - 44037-1248 44039-1154 FITS 89-92 KDX200 - 44037-1248 44039-1154 CONVENTIONAL CONVENTIONAL 1991 KDX200  FITS 90-92 KDX200 - 41068-1291 FITS 91-94 KDX250, 91 KX125 KX250, 91-92 KX500 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1991 KDX200   1991 KDX200 FITS 88-92 KX250 - 43044-1034 1991 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 89-92 KDX200 - 41080-1252 WHITE FITS 90-91 KDX200 - 35004-1233-6F 1991 KDX200 F-1161 PAT 585873 - GREY - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - FITS 87-92 KDX200 - 41034-1156 1991 KDX200 fits 89-94 kdx200 - 51001-1301-6W FITS 88-06 KDX200 1991 KDX200 FITS 90-94 KDX200 - 11001-1317 30T - FITS 80-82 KDX175, 83-91 KDX200 - 59051-1041 FITS 89-94 KDX200 - 13064-1148  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1991 KDX200 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159   711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 90-94 KDX200 - 41068-1297 1991 KDX200 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89-94 KDX200 - 39061-1131 FITS 89-91 KDX200 - 43078-1095 1991 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1991 KDX200     FITS 89-94 KDX200 43015-1388 HYDRAULIC 1991 KDX200 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 1991 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1991 KDX200 1.85 X 18 FITS 89-94    FITS 86-94 KDX200   FITS 89-94 KDX200 - 13161-1170 1991 KDX200 KAYABA KYB - SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 260MM - BODY OD 53.7MM - CHROME OD 14MM - EYE TO EYE 440MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT OUTSIDE 41.9MM, INSIDE 22.6MM, HOLE ID 10MM FITS 91-94 KDX200 - 45014-1500 FITS 89-94 KDX200 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1991 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 89-93 KDX200 - 33001-1327-CE  FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1991 KDX200   13T - FITS 89-94 KDX200 - 13127-1175 FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1991 KDX200 FITS 89-06 KDX200 - 16142-1090 FITS 88-90 KX125, 88-91 KX250, 87-88 KXF250, 89-94 KDX200, 91-94 KDX250 - 59256-1067   FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1991 KDX200 49.9LB NO CARB W/SPARK PLUG KICKER AND OIL 1991 KDX200
1992 KDX200 KHI DX200 EE01XXXX FITS 90-95 KDX200 - 14001-5331 JKADXNE16NA###### FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89-94 KDX200 – 11011-1297 1992 KDX200 FITS 89-94 KDX200 - 14073-1362   KEIHIN PWK V564 35MM FITS 90-94 KDX200 - 15001-1564 DX200 FITS 89-94 KDX200 16065-1181 - 16065-1181 FITS 89-94 KDX200 - 21119-1257 - BLACK MALE BULLET, BLACK EYE RING, BLACK/WHITE FEMALE BULLET, BLACK/YELLOW FLAT FEMALE, WHITE/RED FEMALE BULLET 1992 KDX200 FITS 89-94 KDX200 - 12053-1235 - 12053-1255 - 12053-1270 FITS 89-94 KDX200 -  12053-1240 1992 KDX200   FITS 89-94 KDX200 – 13095-1189 FITS 89-94 KDX200 - 13087-1111   FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 1992 KDX200 FITS 91-94 KDX200 14032-1296 FITS 89-94 KDX200, 89 KX125 - 13086-1060 FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms   FITS 89-94 KDX200 - 58MM STROKE - 13031-1300 1569 – FITS 89-94 KDX200 - 11005-1569 1992 KDX200 FITS 90-94 KDX200 - 32029-1688 FITS 90-94 KDX200 - 32037-1535 - 32037-1536     20037 FITS 89-94 KDX200 FITS 89-94 KDX200 - 12005-1121 - 12005-1122 - 12005-1157 FITS 89 KX125, 89-94 KDX200 - 14024-1786 1992 KDX200 F4T100 FITS 89-94 KDX200 - 21007-1177 FITS 89-94 KDX200 - 34028-1302 - 34028-1303 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1992 KDX200 CONVENTIONAL - CHROME OD 43MM - C/L 35 3/4" - BRAKE MOUNT C/L 61.5MM - AXLE 15MM - FITS 90-92 KDX200 - 44001-1711-GF 1992 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 89-92 KDX200 - 44037-1248 44039-1154 FITS 89-92 KDX200 - 44037-1248 44039-1154 CONVENTIONAL CONVENTIONAL 1992 KDX200  FITS 90-92 KDX200 - 41068-1291   FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1992 KDX200   1992 KDX200 FITS 88-92 KX250 - 43044-1034 1992 KDX200 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 89-92 KDX200 - 41080-1252   1992 KDX200 F-1161 PAT 585873 - GREY - 15MM AXLE DIAMETER - OUTSIDE TO OUTSIDE OF BRGS 97MM - FITS 87-92 KDX200 - 41034-1156 1992 KDX200 fits 89-94 kdx200 - 51001-1301-6W FITS 88-06 KDX200 1992 KDX200 FITS 90-94 KDX200 - 11001-1317 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 89-94 KDX200 - 13064-1148  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1992 KDX200 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159   711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 90-94 KDX200 - 41068-1297 1992 KDX200 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89-94 KDX200 - 39061-1131   1992 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1992 KDX200     FITS 89-94 KDX200 43015-1388 HYDRAULIC 1992 KDX200 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 1992 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1992 KDX200 1.85 X 18 FITS 89-94    FITS 86-94 KDX200   FITS 89-94 KDX200 - 13161-1170 1992 KDX200 KAYABA KYB - SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 260MM - BODY OD 53.7MM - CHROME OD 14MM - EYE TO EYE 440MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT OUTSIDE 41.9MM, INSIDE 22.6MM, HOLE ID 10MM FITS 91-94 KDX200 - 45014-1500 FITS 89-94 KDX200 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1992 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 89-93 KDX200 - 33001-1327-CE  FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1992 KDX200   13T - FITS 89-94 KDX200 - 13127-1175 FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1992 KDX200 FITS 89-06 KDX200 - 16142-1090 FITS 88-90 KX125, 88-91 KX250, 87-88 KXF250, 89-94 KDX200, 91-94 KDX250 - 59256-1067   FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1992 KDX200 49.9LB NO CARB W/SPARK PLUG KICKER AND OIL 1992 KDX200
1993 KDX200 KHI DX200 EE01XXXX (KHI DX200 EE02XXXX) FITS 90-95 KDX200 - 14001-5331 JKADXNE13PA###### FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89-94 KDX200 – 11011-1297 1993 KDX200 FITS 89-94 KDX200 - 14073-1362   KEIHIN PWK V564 35MM FITS 90-94 KDX200 - 15001-1564 DX200 FITS 89-94 KDX200 16065-1181 - 16065-1181 FITS 89-94 KDX200 - 21119-1257 - BLACK MALE BULLET, BLACK EYE RING, BLACK/WHITE FEMALE BULLET, BLACK/YELLOW FLAT FEMALE, WHITE/RED FEMALE BULLET 1993 KDX200 FITS 89-94 KDX200 - 12053-1235 - 12053-1255 - 12053-1270 FITS 89-94 KDX200 -  12053-1240 1993 KDX200   FITS 89-94 KDX200 – 13095-1189 FITS 89-94 KDX200 - 13087-1111   FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 1993 KDX200 FITS 91-94 KDX200 14032-1296 FITS 89-94 KDX200, 89 KX125 - 13086-1060 FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms   FITS 89-94 KDX200 - 58MM STROKE - 13031-1300 1569 – FITS 89-94 KDX200 - 11005-1569 1993 KDX200 FITS 90-94 KDX200 - 32029-1688 FITS 90-94 KDX200 - 32037-1535 - 32037-1536     20037 FITS 89-94 KDX200 FITS 89-94 KDX200 - 12005-1121 - 12005-1122 - 12005-1157 FITS 89 KX125, 89-94 KDX200 - 14024-1786 1993 KDX200 F4T100 FITS 89-94 KDX200 - 21007-1177 FITS 89-94 KDX200 - 34028-1302 - 34028-1303 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1993 KDX200 USD - 200-R 200-L - BLUE - CHROME OD 41MM - C/L 36.25" (921MM) - UPPER 49.9MM - LOWER 55.6MM - BRAKE MOUNTS C/L 61MM - AXLE CLAMP ID'S 15MM 1993 KDX200 41mm x 53mm x 8/9.5/10.5  FITS 93-94 KDX200 - 44037-1282 - CLICK HERE FOR MEASUREMENTS   FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 1993 KDX200 FITS 91-94 KDX250, 93-94 KDX200 41068-1304 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1993 KDX200   1993 KDX200   1993 KDX200 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200   1993 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 93-94, KDX250 92-94, KLX300 97-07 , KLX250 94-96, KLX650R 93-96 - 41034-1219 1993 KDX200 fits 89-94 kdx200 - 51001-1301-6W FITS 88-06 KDX200 1993 KDX200 FITS 90-94 KDX200 - 11001-1317 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 89-94 KDX200 - 13064-1148  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1993 KDX200 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159   711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 90-94 KDX200 - 41068-1297 1993 KDX200 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89-94 KDX200 - 39061-1131   1993 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1993 KDX200     FITS 89-94 KDX200 43015-1388 HYDRAULIC 1993 KDX200 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 1993 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1993 KDX200 1.85 X 18 FITS 89-94    FITS 86-94 KDX200   FITS 89-94 KDX200 - 13161-1170 1993 KDX200 KAYABA KYB - SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 260MM - BODY OD 53.7MM - CHROME OD 14MM - EYE TO EYE 440MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT OUTSIDE 41.9MM, INSIDE 22.6MM, HOLE ID 10MM FITS 91-94 KDX200 - 45014-1500 FITS 89-94 KDX200 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1993 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 89-93 KDX200 - 33001-1327-CE  FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1993 KDX200   13T - FITS 89-94 KDX200 - 13127-1175 FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1993 KDX200 FITS 89-06 KDX200 - 16142-1090 FITS 88-90 KX125, 88-91 KX250, 87-88 KXF250, 89-94 KDX200, 91-94 KDX250 - 59256-1067   FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1993 KDX200 49.9LB NO CARB W/SPARK PLUG KICKER AND OIL 1993 KDX200
1994 KDX200   FITS 90-95 KDX200 - 14001-5331   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89-94 KDX200 – 11011-1297 1994 KDX200 FITS 89-94 KDX200 - 14073-1362   KEIHIN PWK V564 35MM FITS 90-94 KDX200 - 15001-1564 DX200 FITS 89-94 KDX200 16065-1181 - 16065-1181 FITS 89-94 KDX200 - 21119-1257 - BLACK MALE BULLET, BLACK EYE RING, BLACK/WHITE FEMALE BULLET, BLACK/YELLOW FLAT FEMALE, WHITE/RED FEMALE BULLET 1994 KDX200 FITS 89-94 KDX200 - 12053-1235 - 12053-1255 - 12053-1270 FITS 89-94 KDX200 -  12053-1240 1994 KDX200   FITS 89-94 KDX200 – 13095-1189 FITS 89-94 KDX200 - 13087-1111   FITS 89-91 KX125, 89-94 KDX200 - 14032-1266 1994 KDX200 FITS 91-94 KDX200 14032-1296 FITS 89-94 KDX200, 89 KX125 - 13086-1060 FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms   FITS 89-94 KDX200 - 58MM STROKE - 13031-1300 1569 – FITS 89-94 KDX200 - 11005-1569 1994 KDX200 FITS 90-94 KDX200 - 32029-1688       20037 FITS 89-94 KDX200 FITS 89-94 KDX200 - 12005-1121 - 12005-1122 - 12005-1157 FITS 89 KX125, 89-94 KDX200 - 14024-1786 1994 KDX200 F4T100 FITS 89-94 KDX200 - 21007-1177 FITS 89-94 KDX200 - 34028-1302 - 34028-1303 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1994 KDX200 USD - 200-R 200-L - BLUE - CHROME OD 41MM - C/L 36.25" (921MM) - UPPER 49.9MM - LOWER 55.6MM - BRAKE MOUNTS C/L 61MM - AXLE CLAMP ID'S 15MM 1994 KDX200 41mm x 53mm x 8/9.5/10.5  FITS 93-94 KDX200 - 44037-1282 - CLICK HERE FOR MEASUREMENTS   FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 1994 KDX200 FITS 91-94 KDX250, 93-94 KDX200 41068-1304 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1994 KDX200 FITS 94-95 KDX200 KLX250 KLX650R - 43015-1553 1994 KDX200   1994 KDX200 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200   1994 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 93-94, KDX250 92-94, KLX300 97-07 , KLX250 94-96, KLX650R 93-96 - 41034-1219 1994 KDX200 fits 89-94 kdx200 - 51001-1301-6W FITS 88-06 KDX200 1994 KDX200 FITS 90-94 KDX200 - 11001-1317 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 89-94 KDX200 - 13064-1148  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1994 KDX200 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200 - 35019-1159   711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 86-94 KDX200 - 13097-1157 FITS 90-94 KDX200 - 41068-1297 1994 KDX200 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89-94 KDX200 - 39061-1131   1994 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1994 KDX200     FITS 89-94 KDX200 43015-1388 HYDRAULIC 1994 KDX200 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 R-1213 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 1994 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1994 KDX200 1.85 X 18 FITS 89-94    FITS 86-94 KDX200   FITS 89-94 KDX200 - 13161-1170 1994 KDX200 KAYABA KYB - SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 260MM - BODY OD 53.7MM - CHROME OD 14MM - EYE TO EYE 440MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT OUTSIDE 41.9MM, INSIDE 22.6MM, HOLE ID 10MM FITS 91-94 KDX200 - 45014-1500 FITS 89-94 KDX200 GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN - FITS 90-95 KX500, 89-94 KDX200 - 36010-5187-6W 1994 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 94 KDX200 - 33001-1327-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1994 KDX200   13T - FITS 89-94 KDX200 - 13127-1175 FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1994 KDX200 FITS 89-06 KDX200 - 16142-1090 FITS 88-90 KX125, 88-91 KX250, 87-88 KXF250, 89-94 KDX200, 91-94 KDX250 - 59256-1067   FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1994 KDX200 49.9LB NO CARB W/SPARK PLUG KICKER AND OIL 1994 KDX200
1995 KDX200   FITS 90-95 KDX200 - 14001-5331   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1995 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEHIN PWK V980 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1995 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1995 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       1995 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 1995 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944     FITS 95-06 KDX200   1995 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1995 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1995 KDX200 43mm x 55mm x 9.5/10.5/11    FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1995 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     1995 KDX200 FITS 94-95 KDX200 KLX250 KLX650R - 43015-1553 1995 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1995 KDX200     1995 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1995 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 1995 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1995 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1995 KDX200     FITS 95-06 KDX200, 97-05 KDX220 1995 KDX200 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 - 14037-1099-6W - 14037-1121-6W   1995 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1995 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1995 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1995 KDX200 2.15X18 FITS 95-06         1995 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1995 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1995 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1995 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1995 KDX200 1995 KDX200
1996 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1996 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1996 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1996 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       1996 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 1996 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944     FITS 95-06 KDX200   1996 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1996 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1996 KDX200 43mm x 55mm x 9.5/10.5/11    FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1996 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     1996 KDX200 FITS 96 KDX200 KLX250 KLX650R - 43015-1573 1996 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1996 KDX200     1996 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1996 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 1996 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1996 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1996 KDX200     FITS 95-06 KDX200, 97-05 KDX220 1996 KDX200 VIOLET 14037-1099-RE FITS 96 KX500 KDX200   1996 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1996 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1996 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1996 KDX200 2.15X18 FITS 95-06         1996 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1996 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1996 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1996 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1996 KDX200 1996 KDX200
1997 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1997 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1997 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1997 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       1997 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 1997 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   1997 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1997 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1997 KDX200 43mm x 55mm x 9.5/10.5/11    FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1997 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     1997 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 1997 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1997 KDX200     1997 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1997 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 1997 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1997 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1997 KDX200     FITS 95-06 KDX200, 97-05 KDX220 1997 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   1997 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1997 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1997 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1997 KDX200 2.15X18 FITS 95-06         1997 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1997 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1997 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1997 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1997 KDX200 1997 KDX200
1998 KDX200 KHI DX200 HE00XXXX FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1998 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1998 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1998 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       1998 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 1998 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   1998 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1998 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1998 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1998 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     1998 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 1998 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1998 KDX200     1998 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1998 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 1998 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1998 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1998 KDX200     FITS 95-06 KDX200, 97-05 KDX220 1998 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   1998 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1998 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1998 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1998 KDX200 2.15X18 FITS 95-06         1998 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1998 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1998 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1998 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1998 KDX200 1998 KDX200
1999 KDX200 KHI DX200 HE00XXXX FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212 JKADXNHC2XA###### FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1999 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEHIN PWK V980 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1999 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1999 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       1999 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 1999 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   1999 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1999 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1999 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1999 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     1999 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 1999 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1999 KDX200 .111”   1999 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1999 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 1999 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1999 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1999 KDX200     FITS 95-06 KDX200, 97-05 KDX220 1999 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   1999 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1999 KDX200 .144” R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1999 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1999 KDX200 2.15X18 FITS 95-06 FITS 99-04 KDX200 & KDX220       1999 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1 1220 112.5     1999 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1999 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164      SH623-12 8.4 151 1999 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1999 KDX200 1999 KDX200
2000 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2000 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEHIN PWK V981 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2000 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2000 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 1125 FITS 95-06 KDX200 & 97-05 KDX220     273A 2000 KDX200 273A-1 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2000 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2000 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2000 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2000 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2000 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     2000 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2000 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2000 KDX200     2000 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2000 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 2000 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2000 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2000 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2000 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2000 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2000 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2000 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2000 KDX200 2.15X18 FITS 95-06 FITS 99-04 KDX200 & KDX220       2000 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1 1229-1125     2000 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2000 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164      SH623-12 9.9 061 2000 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2000 KDX200 2000 KDX200
2001 KDX200 KHI DX200 HE01---- FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212 JKADXNHC91A###### FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2001 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2001 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2001 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       2001 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2001 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2001 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2001 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2001 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2001 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     2001 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2001 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2001 KDX200     2001 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2001 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 2001 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2001 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2001 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2001 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2001 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2001 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2001 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2001 KDX200 2.15X18 FITS 95-06 FITS 99-04 KDX200 & KDX220       2001 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2001 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2001 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2001 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2001 KDX200 2001 KDX200
2002 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2002 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2002 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2002 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       2002 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2002 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2002 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2002 KDX200 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2002 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2002 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     2002 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2002 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2002 KDX200 GREEN - FITS 88 KX250 KX500, 86-88 KDX200 - 35004-1176-6W     2002 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2002 KDX200 FITS 95-02 KDX200 & 98-02 KDX220 FITS 88-06 KDX200 2002 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2002 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2002 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2002 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2002 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2002 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2002 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2002 KDX200 2.15X18 FITS 95-06 FITS 99-04 KDX200 & KDX220       2002 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2002 KDX200 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2002 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2002 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2002 KDX200 2002 KDX200
2003 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2003 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2003 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2003 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       2003 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2003 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2003 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2003 KDX200   2003 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2003 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     2003 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2003 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2003 KDX200     2003 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2003 KDX200   FITS 88-06 KDX200 2003 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2003 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2003 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2003 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2003 KDX200 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2003 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2003 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2003 KDX200 2.15X18 FITS 95-06 FITS 99-04 KDX200 & KDX220       2003 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2003 KDX200 FITS 89-06 KDX200, 97-05 KDX220     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2003 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2003 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2003 KDX200 2003 KDX200
2004 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2004 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2004 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2004 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       2004 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2004 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2004 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2004 KDX200   2004 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2004 KDX200 FITS 93-96 KLX650R KLX650C, 94-96 KLX250R, 95-04 KDX200, 97-04 KLX300R - 41068-1352     2004 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2004 KDX200 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2004 KDX200     2004 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2004 KDX200   FITS 88-06 KDX200 2004 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2004 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2004 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2004 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2004 KDX200   FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561   HYDRAULIC 2004 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2004 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2004 KDX200 2.15X18 FITS 95-06 FITS 99-04 KDX200 & KDX220       2004 KDX200 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2004 KDX200 FITS 89-06 KDX200, 97-05 KDX220     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2004 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2004 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2004 KDX200 2004 KDX200
2005 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2005 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2005 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2005 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       2005 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2005 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2005 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2005 KDX200   2005 KDX200 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2005 KDX200       2005 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2005 KDX200   2005 KDX200     2005 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2005 KDX200   FITS 88-06 KDX200 2005 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2005 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2005 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2005 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2005 KDX200   FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561   HYDRAULIC 2005 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2005 KDX200 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2005 KDX200 2.15X18 FITS 95-06         2005 KDX200         2005 KDX200 FITS 89-06 KDX200, 97-05 KDX220     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2005 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2005 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2005 KDX200 2005 KDX200
2006 KDX200   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2006 KDX200 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK 35MM FITS 95-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2006 KDX200 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2006 KDX200 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220       2006 KDX200 FITS 95-06 KDX200   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1742 – 66MM .198L – FITS 95-06 KDX200 – 11005-1742 2006 KDX200     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566   FITS 95-06 KDX200   2006 KDX200 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220     2006 KDX200   2006 KDX200   FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2006 KDX200       2006 KDX200 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2006 KDX200   2006 KDX200     2006 KDX200 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2006 KDX200   FITS 88-06 KDX200 2006 KDX200 FITS 95-06 KDX200 - 11001-1409 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2006 KDX200   .7 LITERS 711M06600 PROLITE 2598CD - 66MM STD BORE - FITS 86-06 KDX200 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2006 KDX200     FITS 95-06 KDX200, 97-05 KDX220 2006 KDX200 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2006 KDX200   FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561   HYDRAULIC 2006 KDX200   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2006 KDX200   FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2006 KDX200 2.15X18 FITS 95-06         2006 KDX200         2006 KDX200 FITS 89-06 KDX200, 97-05 KDX220     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 2006 KDX200 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2006 KDX200 FITS 89-06 KDX200 - 16142-1090     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 2006 KDX200 2006 KDX200
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA ONLY AIR BOX CAGE ELEMENT HOLDER AIR BOX (NO BOOT) YEAR TYPE AIR BOX TO CARB BOOT CABLE THROTTLE CARBURETOR CARBURETOR BOOT CDI YEAR TYPE CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH HUB (INNER) CLUTCH FRICTION PLATES CLUTCH COVER YEAR TYPE CLUTCH COVER (INNER) CLUTCH PRESSURE PLATE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CYLINDER YEAR TYPE ENGINE MOUNTS FRONT ENGINE MOUNTS REAR ENGINE MOUNTS UPPER EXHAUST ARRESTOR STOCK EXHAUST PIPE FMF FATTY EXHAUST VALVES EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR TYPE FORK INFO YEAR TYPE FORK SEAL SIZES FORK HOLDER LOWER (Bottom triple tree) FORK HOLDER UPPER (top triple tree) FORK GUARDS FORK GUARD MOUNTS YEAR TYPE FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE CALIPER MOUNT YEAR TYPE FRONT BRAKE ROTOR FRONT FENDER YEAR TYPE FRONT HUB YEAR TYPE GAS TANK GOVERNOR YEAR TYPE HEAD KICK IDLER GEAR KICK LEVER KICK LEVER SHAFT YEAR TYPE MUD FLAP OIL LEVEL PISTON WISECO PRIMARY CRANK GEAR REAR AXLE YEAR TYPE RADIATOR LEFT RADIATOR RIGHT RADIATOR RESERVOIR YEAR TYPE RADIATOR SCREENS REAR BRAKE BACKING PLATE YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE REAR BRAKE MASTER CYLINDER REAR BRAKE ROD YEAR TYPE REAR BRAKE ROTOR REAR HUB YEAR TYPE REAR WHEEL SPACERS REED VALVE YEAR TYPE RIM SIZE SEAT SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR STATOR COVER SWING ARM SWING ARM PIVOT PIN YEAR TYPE TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT TRIPLE CLAMP BOTTOM TRIPLE CLAMP TOP VOLTAGE REGULATOR YEAR TYPE WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT WATER PUMP COVER NECK YEAR TYPE ENGINE WEIGHT YEAR TYPE
1997 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1997 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1997 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1997 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 1997 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 1997 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       1997 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1997 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1997 KDX220 43mm x 55mm x 9.5/10.5/11    FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1997 KDX220       1997 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 1997 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1997 KDX220     1997 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1997 KDX220     1997 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1997 KDX220     N/A FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1997 KDX220     FITS 95-06 KDX200, 97-05 KDX220 1997 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   1997 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1997 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1997 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1997 KDX220           1997 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1997 KDX220 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX   1997 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1997 KDX220         1997 KDX220 1997 KDX220
1998 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1998 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1998 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1998 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 1998 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 1998 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       1998 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1998 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1998 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1998 KDX220       1998 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 1998 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1998 KDX220     1998 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1998 KDX220 FITS 95-02 KDX200 & 98-02 KDX220   1998 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1998 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320   1998 KDX220     FITS 95-06 KDX200, 97-05 KDX220 1998 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   1998 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1998 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1998 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1998 KDX220           1998 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1998 KDX220 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX   1998 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1998 KDX220         1998 KDX220 1998 KDX220
1999 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 1999 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 1999 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 1999 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 1999 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 1999 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       1999 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1999 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  1999 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     1999 KDX220       1999 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 1999 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 1999 KDX220     1999 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1999 KDX220 FITS 95-02 KDX200 & 98-02 KDX220   1999 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 1999 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 1999 KDX220     FITS 95-06 KDX200, 97-05 KDX220 1999 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   1999 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 1999 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 1999 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 1999 KDX220   FITS 99-04 KDX200 & KDX220       1999 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       1999 KDX220 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX   1999 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        1999 KDX220         1999 KDX220 1999 KDX220
2000 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212 JKBDXBAC1YA###### FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2000 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2000 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2000 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 2000 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 2000 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       2000 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2000 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2000 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2000 KDX220       2000 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2000 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2000 KDX220     2000 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2000 KDX220 FITS 95-02 KDX200 & 98-02 KDX220   2000 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2000 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2000 KDX220     FITS 95-06 KDX200, 97-05 KDX220 2000 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2000 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2000 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2000 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2000 KDX220   FITS 99-04 KDX200 & KDX220       2000 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2000 KDX220 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX   2000 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2000 KDX220         2000 KDX220 2000 KDX220
2001 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2001 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2001 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2001 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 2001 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 2001 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       2001 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2001 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2001 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2001 KDX220       2001 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2001 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2001 KDX220     2001 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2001 KDX220 FITS 95-02 KDX200 & 98-02 KDX220   2001 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2001 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2001 KDX220     FITS 95-06 KDX200, 97-05 KDX220 2001 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2001 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2001 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2001 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2001 KDX220   FITS 99-04 KDX200 & KDX220       2001 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2001 KDX220 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX   2001 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2001 KDX220         2001 KDX220 2001 KDX220
2002 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2002 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2002 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2002 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 2002 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 2002 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       2002 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2002 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2002 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2002 KDX220       2002 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2002 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2002 KDX220     2002 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2002 KDX220 FITS 95-02 KDX200 & 98-02 KDX220   2002 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2002 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2002 KDX220     FITS 95-06 KDX200, 97-05 KDX220 2002 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2002 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2002 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2002 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2002 KDX220   FITS 99-04 KDX200 & KDX220       2002 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2002 KDX220 FITS 89-06 KDX200, 97-05 KDX220   FITS 95-02 KDX200, 97-02 KDX220 - 33001-1451-TX   2002 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2002 KDX220         2002 KDX220 2002 KDX220
2003 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2003 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2003 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2003 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 2003 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 2003 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       2003 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2003 KDX220 CONVENTIONAL - K328-AR K328-AL, CHROME OD 43MM - C/L 37 3/8" - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 95-02 KDX200, 97-02 KDX220  2003 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2003 KDX220       2003 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2003 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2003 KDX220     2003 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2003 KDX220     2003 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2003 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2003 KDX220     FITS 95-06 KDX200, 97-05 KDX220 2003 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2003 KDX220 FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  HYDRAULIC 2003 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2003 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2003 KDX220   FITS 99-04 KDX200 & KDX220       2003 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2003 KDX220 FITS 89-06 KDX200, 97-05 KDX220       2003 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2003 KDX220         2003 KDX220 2003 KDX220
2004 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2004 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2004 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2004 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 2004 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 2004 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       2004 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2004 KDX220   2004 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2004 KDX220       2004 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2004 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2004 KDX220     2004 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2004 KDX220     2004 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2004 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2004 KDX220     FITS 95-06 KDX200, 97-05 KDX220 2004 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2004 KDX220   FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561   HYDRAULIC 2004 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2004 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2004 KDX220   FITS 99-04 KDX200 & KDX220       2004 KDX220 SPRING THICKNESS 11.3MM - SPRING OD 87MM, LENGTH 243MM - BODY OD 53.5MM - CHROME OD 14MM - EYE TO EYE 430MM - UPPER MOUNT WIDTH 27MM, HOLE ID 10MM - LOWER MOUNT WIDTH INTERNAL 22.8MM, EXTERNAL 41.7MM - HOLE ID 10MM - FITS 95-04 KDX200, 97-04 KDX200 - 45014-1596-W1       2004 KDX220 FITS 89-06 KDX200, 97-05 KDX220       2004 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2004 KDX220         2004 KDX220 2004 KDX220
2005 KDX220   FITS 96-06 KDX200, 97-05 KDX220 - 14001-1212   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 95-06 KDX200, 97-05 KDX220 - 11010-1575 2005 KDX220 1597 - FITS 95-06 KDX200, 97-05 KDX220 - 14073-1597   KEIHIN PWK V981 – FITS 97-05 KDX220 – 15001-1981 FITS 95-06 KDX200, 97-05 KDX220 16065-1298 1432 F8T13573 – FITS 95-06 KDX200, 97-05 KDX220 – 21119-1432 2005 KDX220 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 FITS 93-96 KLX650R KLX250R, 97-07 KLX300R, 95-06 KDX200, 97-05 KDX220, 06-10 KLX250S - 12053-1328 2005 KDX220 FITS 96-06 KDX200, 97-05 KDX220 – 13236-1264 FITS 95-06 KDX200 & 97-05 KDX220     FITS 97-05 KDX220 2005 KDX220 FITS 97-05 KDX220 - 14032-1419   FITS 95-06 KDX220, 97-05 KDX220R, 91-94 KDX250 - 21121-1230    FITS 95-06 KDX200, 97-05 KDX220 - 58MM STROKE 1744 – FITS 97-05 KDX220 – 11005-1744 2005 KDX220     FITS 95-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-06 KDX220, 97-05 KDX220 – 18090-1566       2005 KDX220 F4T100 72 FITS 95-06 KDX200, 97-05 KDX220 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 2005 KDX220   2005 KDX220 43mm x 55mm x 9.5/10.5/11  FITS 98-06 KDX200, 98-05 KDX220 - 44037-1369 FITS 95-06 KDX200, 97-05 KDX220 - 44039-1256     2005 KDX220       2005 KDX220 FITS 97-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 43015-1588 2005 KDX220 FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 2005 KDX220     2005 KDX220 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 2005 KDX220     2005 KDX220 FITS 97-05 KDX200 - 11001-1410 30T - FITS 92-06 KDX200, 97-05 KDX220 - 59051-1309 FITS 95-06 KDX200, 97-05 KDX220 - 13064-1174  FITS 89-06 KDX200, 97-05 KDX220 - 13066-1071 2005 KDX220     750M06900 - 2717CD - 69MM STD BORE - FITS 98-05 KDX220 FITS 95-06 KDX200, 97-05 KDX220 - 13097-1320 FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S 2005 KDX220     FITS 95-06 KDX200, 97-05 KDX220 2005 KDX220 WHITE 14037-1099-RZ FITS 97-04 KX500, 97-06 KDX200, 97-05 KDX220, 97-07 KLX300, 06-07 KLX250   2005 KDX220   FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561   HYDRAULIC 2005 KDX220   R-1237 20MM AXLE DIA - BRG TO BRG 130MM - ROTOR BC 6X ON 116MM - SPROCKET BC 6X ON 150MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91-94, KLX250R 94-96, KLX300R 97-07 - 41034-1216 2005 KDX220 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 88-06 KDX200, 97-05 KDX220 12021-1067 2005 KDX220           2005 KDX220         2005 KDX220 FITS 89-06 KDX200, 97-05 KDX220       2005 KDX220 SHAFTS FIT 89-06 KDX200 97-05 KDX220, GEARS FIT 95-06 KDX200 97-05 KDX220   FITS 89-06 KDX200, 97-05 KDX220 - 13128-1164        2005 KDX220         2005 KDX220 2005 KDX220
1980 KDX250   FITS 80-81 KX250, 80-82 KDX250       1980 KDX250       FITS 80-82 KDX250, 80-81 KX250, 16065-1029   1980 KDX250     1980 KDX250 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 80-82 KX250 KDX250 13095-1026 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044     1980 KDX250             1980 KDX250               1980 KDX250       1980 KDX250   1980 KDX250           1980 KDX250       1980 KDX250   1980 KDX250   1980 KDX250     1980 KDX250   1980 KDX250     1980 KDX250 FITS 74 76 78-81 KX250, 80-82 KDX250 FITS 80-86 KX250, 80-84 KDX250   FITS 80-82 KDX250 KX250 1980 KDX250       OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028   1980 KDX250       1980 KDX250     1980 KDX250         1980 KDX250     1980 KDX250     1980 KDX250           1980 KDX250         1980 KDX250         1980 KDX250     FITS 80-82 KX250, 80 KDX250 - 13128-1025       1980 KDX250         1980 KDX250 1980 KDX250
1981 KDX250   FITS 80-81 KX250, 80-82 KDX250     FITS 82 KX250, 81-82 KDX250 11010-5063 1981 KDX250 FITS 82 KX250, 81-82 KDX250 - 14073-1069     FITS 80-82 KDX250, 80-81 KX250, 16065-1029   1981 KDX250 FITS 82-83 KX125, 82 KX250, 81-82 KDX250 FITS 82-83 KX125, 82 KX250, 81-82 KDX250 12053-1062 1981 KDX250 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 80-82 KX250 KDX250 13095-1026 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   BLACK - FITS 80-82 KX250, 81-82 KDX250 14032-1028 1981 KDX250             1981 KDX250               1981 KDX250       1981 KDX250   1981 KDX250           1981 KDX250       1981 KDX250   1981 KDX250   1981 KDX250     1981 KDX250   1981 KDX250     1981 KDX250 FITS 74 76 78-81 KX250, 80-82 KDX250 FITS 80-86 KX250, 80-84 KDX250   FITS 80-82 KDX250 KX250 1981 KDX250       OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028   1981 KDX250       1981 KDX250     1981 KDX250         1981 KDX250     1981 KDX250     1981 KDX250           1981 KDX250         1981 KDX250   FITS 82 KX250, 81-84 KDX250 14031-1088   FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1981 KDX250             1981 KDX250         1981 KDX250 1981 KDX250
1982 KDX250   FITS 80-81 KX250, 80-82 KDX250     FITS 82 KX250, 81-82 KDX250 11010-5063 1982 KDX250 FITS 82 KX250, 81-82 KDX250 - 14073-1069     FITS 80-82 KDX250, 80-81 KX250, 16065-1029   1982 KDX250 FITS 82-83 KX125, 82 KX250, 81-82 KDX250 FITS 82-83 KX125, 82 KX250, 81-82 KDX250 12053-1062 1982 KDX250 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 80-82 KX250 KDX250 13095-1026 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   BLACK - FITS 80-82 KX250, 81-82 KDX250 14032-1028 1982 KDX250             1982 KDX250               1982 KDX250       1982 KDX250   1982 KDX250           1982 KDX250       1982 KDX250   1982 KDX250   1982 KDX250     1982 KDX250   1982 KDX250     1982 KDX250 FITS 74 76 78-81 KX250, 80-82 KDX250 FITS 80-86 KX250, 80-84 KDX250   FITS 80-82 KDX250 KX250 1982 KDX250       OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028   1982 KDX250       1982 KDX250     1982 KDX250         1982 KDX250     1982 KDX250     1982 KDX250           1982 KDX250         1982 KDX250   FITS 82 KX250, 81-84 KDX250 14031-1088   FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1982 KDX250             1982 KDX250         1982 KDX250 1982 KDX250
1983 KDX250         FITS 83-85 KDX200, 83-84 KDX250 - 11011-1125 1983 KDX250       FITS 84-85 KXT250, 81-84 KDX250, 82-84 KX250, 16065-1048   1983 KDX250 FITS 82-83 KX125, 83-84 KX250 & KX500, 83 KDX200 & KDX250   1983 KDX250 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 83-84 KX250 KDX250 13095-1050 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044     1983 KDX250   FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011         1983 KDX250               1983 KDX250       1983 KDX250   1983 KDX250           1983 KDX250       1983 KDX250   1983 KDX250   1983 KDX250     1983 KDX250   1983 KDX250     1983 KDX250   FITS 80-86 KX250, 80-84 KDX250     1983 KDX250       OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028   1983 KDX250       1983 KDX250     1983 KDX250         1983 KDX250     1983 KDX250     1983 KDX250           1983 KDX250         1983 KDX250   FITS 82 KX250, 81-84 KDX250 14031-1088   FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1983 KDX250             1983 KDX250         1983 KDX250 1983 KDX250
1984 KDX250         FITS 83-85 KDX200, 83-84 KDX250 - 11011-1125 1984 KDX250       FITS 84-85 KXT250, 81-84 KDX250, 82-84 KX250, 16065-1048   1984 KDX250     1984 KDX250 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 83-84 KX250 KDX250 13095-1050 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044     1984 KDX250   FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011         1984 KDX250               1984 KDX250       1984 KDX250   1984 KDX250           1984 KDX250       1984 KDX250   1984 KDX250   1984 KDX250     1984 KDX250   1984 KDX250     1984 KDX250   FITS 80-86 KX250, 80-84 KDX250     1984 KDX250       OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028   1984 KDX250       1984 KDX250     1984 KDX250         1984 KDX250     1984 KDX250     1984 KDX250           1984 KDX250         1984 KDX250   FITS 82 KX250, 81-84 KDX250 14031-1088   FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042 1984 KDX250             1984 KDX250         1984 KDX250 1984 KDX250
1991 KDX250 DX250DE0017-- FITS 91-94 KDX250   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454   1991 KDX250           1991 KDX250   FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 1991 KDX250 FITS 91-94 KX250 KDX250 13102-1110 88-89 KX250, 91-94 KDX250 - 13095-1171 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 90-91 KX250, 91-94 KDX250 14032-1283 1991 KDX250         FITS 90 KX250, 91-94 KDX250 - 13031-1302   1991 KDX250           FITS 90-92 KX250, 91-94 KDX250 - LH 12005-1140, RH 12005-1141   1991 KDX250   FITS 91 KX125 KX250 KDX25, 92 KX500 - 34028-1332 - 34028-1333 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1991 KDX250   1991 KDX250           1991 KDX250 FITS 91-94 KDX250, 93-94 KDX200 41068-1304 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1991 KDX250   1991 KDX250 FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 1991 KDX250     1991 KDX250 F-1240 - 15MM AXLE DIA - BRG TO BRG 97MM - ROTOR OD 250MM ID 100MM - ROTOR BC 4 ON 116MM - FITS KDX200 95-06, KDX220 97-05, KDX250 91, KLX650 93-96 -41034-1217 1991 KDX250     1991 KDX250 E-1 1348 26T – FITS 87 93-07 KX250, 91-94 KDX250 59051-1271     1991 KDX250       INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308   1991 KDX250       1991 KDX250     1991 KDX250 FITS 91-94 KDX250, 95-03 KDX200, 97-02 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 91 KDX250 - 43015-1466   1991 KDX250     1991 KDX250 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R   1991 KDX250           1991 KDX250         1991 KDX250 FITS 91-94 KDX250     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1991 KDX250     FITS 88-89 KX250, 91-94 KDX250 - 13128-1151 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218   1991 KDX250 FITS 88-91 KX250, 91-94 KDX250 - 16142-1085     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1991 KDX250 1991 KDX250
1992 KDX250   FITS 91-94 KDX250   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454   1992 KDX250           1992 KDX250   FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 1992 KDX250 FITS 91-94 KX250 KDX250 13102-1110 88-89 KX250, 91-94 KDX250 - 13095-1171 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 90-91 KX250, 91-94 KDX250 14032-1283 1992 KDX250         FITS 90 KX250, 91-94 KDX250 - 13031-1302   1992 KDX250           FITS 90-92 KX250, 91-94 KDX250 - LH 12005-1140, RH 12005-1141   1992 KDX250   FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE   1992 KDX250   1992 KDX250           1992 KDX250 FITS 91-94 KDX250, 93-94 KDX200 41068-1304 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1992 KDX250   1992 KDX250 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 1992 KDX250     1992 KDX250   1992 KDX250     1992 KDX250   26T – FITS 87 93-07 KX250, 91-94 KDX250 59051-1271     1992 KDX250       INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308   1992 KDX250       1992 KDX250     1992 KDX250 FITS 91-94 KDX250, 95-03 KDX200, 97-02 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469   1992 KDX250     1992 KDX250 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R   1992 KDX250           1992 KDX250         1992 KDX250 FITS 91-94 KDX250     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1992 KDX250     FITS 88-89 KX250, 91-94 KDX250 - 13128-1151 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218   1992 KDX250 FITS 88-91 KX250, 91-94 KDX250 - 16142-1085     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1992 KDX250 1992 KDX250
1993 KDX250   FITS 91-94 KDX250   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454   1993 KDX250           1993 KDX250   FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 1993 KDX250 FITS 91-94 KX250 KDX250 13102-1110 88-89 KX250, 91-94 KDX250 - 13095-1171 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 90-91 KX250, 91-94 KDX250 14032-1283 1993 KDX250         FITS 90 KX250, 91-94 KDX250 - 13031-1302   1993 KDX250           FITS 90-92 KX250, 91-94 KDX250 - LH 12005-1140, RH 12005-1141   1993 KDX250   FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1993 KDX250   1993 KDX250         FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 1993 KDX250 FITS 91-94 KDX250, 93-94 KDX200 41068-1304 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1993 KDX250   1993 KDX250 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 1993 KDX250     1993 KDX250   1993 KDX250     1993 KDX250   26T – FITS 87 93-07 KX250, 91-94 KDX250 59051-1271     1993 KDX250       INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308   1993 KDX250       1993 KDX250     1993 KDX250 FITS 91-94 KDX250, 95-03 KDX200, 97-02 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469   1993 KDX250     1993 KDX250 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R   1993 KDX250           1993 KDX250         1993 KDX250 FITS 91-94 KDX250     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1993 KDX250     FITS 88-89 KX250, 91-94 KDX250 - 13128-1151 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218   1993 KDX250 FITS 88-91 KX250, 91-94 KDX250 - 16142-1085     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1993 KDX250 1993 KDX250
1994 KDX250   FITS 91-94 KDX250   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454   1994 KDX250           1994 KDX250   FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 1994 KDX250 FITS 91-94 KX250 KDX250 13102-1110 88-89 KX250, 91-94 KDX250 - 13095-1171 FITS 89-04 KX500, 91-94 KDX250 - 13087-1138 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  FITS 90-91 KX250, 91-94 KDX250 14032-1283 1994 KDX250         FITS 90 KX250, 91-94 KDX250 - 13031-1302   1994 KDX250           FITS 90-92 KX250, 91-94 KDX250 - LH 12005-1140, RH 12005-1141   1994 KDX250   FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1994 KDX250   1994 KDX250         FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 1994 KDX250 FITS 91-94 KDX250, 93-94 KDX200 41068-1304 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 1994 KDX250   1994 KDX250 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 1994 KDX250     1994 KDX250   1994 KDX250     1994 KDX250   26T – FITS 87 93-07 KX250, 91-94 KDX250 59051-1271     1994 KDX250       INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308   1994 KDX250       1994 KDX250     1994 KDX250 FITS 91-94 KDX250, 95-03 KDX200, 97-02 KDX220 - 43041-1448 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469   1994 KDX250     1994 KDX250 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R   1994 KDX250           1994 KDX250         1994 KDX250 FITS 91-94 KDX250     FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137 1994 KDX250     FITS 88-89 KX250, 91-94 KDX250 - 13128-1151 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218 FITS 93-96 KLX650R, 91-94 KDX250 (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) - 44039-1218   1994 KDX250 FITS 88-91 KX250, 91-94 KDX250 - 16142-1085     FITS 88-89 KX250, 88-04 KX500, 88-03 KX60, 89-06 KDX200, FITS 91-94 KDX250 1994 KDX250 1994 KDX250
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA ONLY AIR BOX CAGE ELEMENT HOLDER AIR BOX (NO BOOT) YEAR TYPE AIR BOX TO CARB BOOT CABLE THROTTLE CARBURETOR CARBURETOR BOOT CDI YEAR TYPE CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH HUB (INNER) CLUTCH FRICTION PLATES CLUTCH COVER YEAR TYPE CLUTCH COVER (INNER) CLUTCH PRESSURE PLATE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CYLINDER YEAR TYPE ENGINE MOUNTS FRONT   ENGINE MOUNTS UPPER EXHAUST ARRESTOR STOCK EXHAUST PIPE FMF FATTY EXHAUST VALVES EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR TYPE FORK INFO YEAR TYPE FORK SEAL SIZES FORK HOLDER LOWER (Bottom triple tree) FORK HOLDER UPPER (top triple tree) FORK GUARDS FORK GUARD MOUNTS YEAR TYPE FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE CALIPER MOUNT YEAR TYPE FRONT BRAKE ROTOR FRONT FENDER YEAR TYPE FRONT HUB YEAR TYPE GAS TANK GOVERNOR YEAR TYPE HEAD KICK IDLER GEAR KICK LEVER KICK LEVER SHAFT ASY YEAR TYPE MUD FLAP OIL LEVEL PISTON WISECO PRIMARY CRANK GEAR REAR AXLE YEAR TYPE RADIATOR LEFT RADIATOR RIGHT RADIATOR RESERVOIR YEAR TYPE RADIATOR SCREENS REAR BRAKE BACKING PLATE YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE REAR BRAKE MASTER CYLINDER REAR BRAKE ROD YEAR TYPE REAR BRAKE ROTOR REAR HUB YEAR TYPE REAR WHEEL SPACERS REED VALVE YEAR TYPE RIM SIZE SEAT SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR STATOR COVER SWING ARM SWING ARM PIVOT PIN YEAR TYPE TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT TRIPLE CLAMP BOTTOM TRIPLE CLAMP TOP VOLTAGE REGULATOR YEAR TYPE WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT WATER PUMP COVER NECK YEAR TYPE ENGINE WEIGHT YEAR TYPE
1979 KDX400           1979 KDX400   FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045       1979 KDX400     1979 KDX400           1979 KDX400         FITS 79-80 KDX400 & 81 KDX420 13031-1023   1979 KDX400               1979 KDX400       1979 KDX400   1979 KDX400           1979 KDX400       1979 KDX400   1979 KDX400   1979 KDX400     1979 KDX400   1979 KDX400     1979 KDX400         1979 KDX400           1979 KDX400       1979 KDX400     1979 KDX400         1979 KDX400     1979 KDX400     1979 KDX400           1979 KDX400         1979 KDX400         1979 KDX400             1979 KDX400         1979 KDX400 1979 KDX400
1980 KDX400           1980 KDX400   FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045       1980 KDX400     1980 KDX400           1980 KDX400         FITS 79-80 KDX400 & 81 KDX420 13031-1023   1980 KDX400               1980 KDX400       1980 KDX400   1980 KDX400           1980 KDX400       1980 KDX400   1980 KDX400   1980 KDX400     1980 KDX400   1980 KDX400     1980 KDX400         1980 KDX400           1980 KDX400       1980 KDX400     1980 KDX400         1980 KDX400     1980 KDX400     1980 KDX400           1980 KDX400         1980 KDX400         1980 KDX400             1980 KDX400         1980 KDX400 1980 KDX400
1980 KDX420         FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1980 KDX420       FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005   1980 KDX420     1980 KDX420           1980 KDX420             1980 KDX420               1980 KDX420       1980 KDX420   1980 KDX420           1980 KDX420       1980 KDX420   1980 KDX420   1980 KDX420     1980 KDX420   1980 KDX420     1980 KDX420         1980 KDX420           1980 KDX420       1980 KDX420     1980 KDX420         1980 KDX420     1980 KDX420     1980 KDX420           1980 KDX420         1980 KDX420         1980 KDX420             1980 KDX420         1980 KDX420 1980 KDX420
1981 KDX420         FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1981 KDX420       FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005   1981 KDX420     1981 KDX420           1981 KDX420         FITS 79-80 KDX400 & 81 KDX420 13031-1023   1981 KDX420               1981 KDX420 FP4388 - FITS 79-80 KDX400, 80 KDX250, 81 KDX420, 82 KDX450 - 21007-1012     1981 KDX420   1981 KDX420           1981 KDX420       1981 KDX420   1981 KDX420   1981 KDX420     1981 KDX420   1981 KDX420     1981 KDX420         1981 KDX420           1981 KDX420       1981 KDX420     1981 KDX420         1981 KDX420     1981 KDX420     1981 KDX420           1981 KDX420         1981 KDX420         1981 KDX420             1981 KDX420         1981 KDX420 1981 KDX420
1979 KDX450   FITS 75 KX400, 80-81 KX420, 79-80 KDX450       1979 KDX450           1979 KDX450     1979 KDX450           1979 KDX450             1979 KDX450               1979 KDX450       1979 KDX450   1979 KDX450           1979 KDX450       1979 KDX450   1979 KDX450   1979 KDX450     1979 KDX450   1979 KDX450     1979 KDX450         1979 KDX450           1979 KDX450       1979 KDX450     1979 KDX450         1979 KDX450     1979 KDX450     1979 KDX450           1979 KDX450         1979 KDX450         1979 KDX450             1979 KDX450         1979 KDX450 1979 KDX450
1980 KDX450   FITS 75 KX400, 80-81 KX420, 79-80 KDX450       1980 KDX450           1980 KDX450     1980 KDX450           1980 KDX450             1980 KDX450               1980 KDX450       1980 KDX450   1980 KDX450           1980 KDX450       1980 KDX450   1980 KDX450   1980 KDX450     1980 KDX450   1980 KDX450     1980 KDX450         1980 KDX450           1980 KDX450       1980 KDX450     1980 KDX450         1980 KDX450     1980 KDX450     1980 KDX450           1980 KDX450         1980 KDX450         1980 KDX450             1980 KDX450         1980 KDX450 1980 KDX450
1982 KDX450           1982 KDX450       FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005   1982 KDX450   CHAIN SLIDE 1982 KDX450           1982 KDX450             1982 KDX450               1982 KDX450       1982 KDX450   1982 KDX450           1982 KDX450       1982 KDX450   1982 KDX450   1982 KDX450     1982 KDX450   1982 KDX450     1982 KDX450         1982 KDX450           1982 KDX450       1982 KDX450     1982 KDX450         1982 KDX450     1982 KDX450     1982 KDX450           1982 KDX450         1982 KDX450         1982 KDX450             1982 KDX450         1982 KDX450 1982 KDX450
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA ONLY AIR BOX CAGE ELEMENT HOLDER AIR BOX (NO BOOT) YEAR TYPE AIR BOX TO CARB BOOT CABLE THROTTLE CARBURETOR CARBURETOR BOOT CDI YEAR TYPE CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH HUB (INNER) CLUTCH FRICTION PLATES CLUTCH COVER YEAR TYPE CLUTCH COVER (INNER) CLUTCH PRESSURE PLATE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CYLINDER YEAR TYPE ENGINE MOUNTS FRONT   ENGINE MOUNTS UPPER EXHAUST ARRESTOR STOCK EXHAUST PIPE FMF FATTY EXHAUST VALVES EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR TYPE FORK INFO YEAR TYPE FORK SEAL SIZES FORK HOLDER LOWER (Bottom triple tree) FORK HOLDER UPPER (top triple tree) FORK GUARDS FORK GUARD MOUNTS YEAR TYPE FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE CALIPER MOUNT YEAR TYPE FRONT BRAKE ROTOR FRONT FENDER YEAR TYPE FRONT HUB YEAR TYPE GAS TANK GOVERNOR YEAR TYPE HEAD KICK IDLER GEAR KICK LEVER KICK LEVER SHAFT ASY YEAR TYPE MUD FLAP   PISTON WISECO PRIMARY CRANK GEAR REAR AXLE YEAR TYPE RADIATOR LEFT RADIATOR RIGHT RADIATOR RESERVOIR YEAR TYPE RADIATOR SCREENS REAR BRAKE BACKING PLATE YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE REAR BRAKE MASTER CYLINDER REAR BRAKE ROD YEAR TYPE REAR BRAKE ROTOR REAR HUB YEAR TYPE REAR WHEEL SPACERS REED VALVE YEAR TYPE RIM SIZE SEAT SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR STATOR COVER SWING ARM SWING ARM PIVOT PIN YEAR TYPE TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT TRIPLE CLAMP BOTTOM TRIPLE CLAMP TOP VOLTAGE REGULATOR YEAR TYPE WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT WATER PUMP COVER NECK YEAR TYPE ENGINE WEIGHT YEAR TYPE
1991 KDX250-F1  DX250F-008500 - UNCONFIRMED DX250F-000001 - EUROPEAN - UNCONFIRMED
1992 KDX250-F2  DX250F-016000 - UNCONFIRMED   DX250F-008501 - EUROPEAN - UNCONFIRMED
1993? KDX250SR DX250FE00----          1993? KDX250SR           1993? KDX250SR     1993? KDX250SR           1993? KDX250SR             1993? KDX250SR               1993? KDX250SR       1993? KDX250SR   1993? KDX250SR           1993? KDX250SR       1993? KDX250SR   1993? KDX250SR   1993? KDX250SR     1993? KDX250SR   1993? KDX250SR     1993? KDX250SR         1993? KDX250SR           1993? KDX250SR       1993? KDX250SR     1993? KDX250SR         1993? KDX250SR     1993? KDX250SR     1993? KDX250SR           1993? KDX250SR         1993? KDX250SR         1993? KDX250SR             1993? KDX250SR         1993? KDX250SR 1993? KDX250SR
    ENGINE PARTS ARE NON US COMPATIBLE
    TOP END PARTS FOR SURE WILL NOT FIT
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA ONLY AIR BOX CAGE ELEMENT HOLDER AIR BOX (NO BOOT) YEAR TYPE AIR BOX TO CARB BOOT CABLE THROTTLE CARBURETOR CARBURETOR BOOT CDI YEAR TYPE CHAIN GUIDE CHAIN SLIDE YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH HUB (INNER) CLUTCH FRICTION PLATES CLUTCH COVER YEAR TYPE CLUTCH COVER (INNER) CLUTCH PRESSURE PLATE COIL COUNTER SPROCKET GUARD PLASTIC CRANK SHAFT CYLINDER YEAR TYPE ENGINE MOUNTS FRONT   ENGINE MOUNTS UPPER EXHAUST ARRESTOR STOCK EXHAUST PIPE FMF FATTY EXHAUST VALVES EXHAUST VALVE COVER RIGHT YEAR TYPE FLY WHEEL ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR TYPE FORK INFO YEAR TYPE FORK SEAL SIZES FORK HOLDER LOWER (Bottom triple tree) FORK HOLDER UPPER (top triple tree) FORK GUARDS FORK GUARD MOUNTS YEAR TYPE FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE LEVER YEAR TYPE FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT BRAKE CALIPER MOUNT YEAR TYPE FRONT BRAKE ROTOR FRONT FENDER YEAR TYPE FRONT HUB YEAR TYPE GAS TANK GOVERNOR YEAR TYPE   KICK IDLER GEAR KICK LEVER KICK LEVER SHAFT ASY YEAR TYPE MUD FLAP   PISTON WISECO PRIMARY CRANK GEAR REAR AXLE YEAR TYPE RADIATOR LEFT RADIATOR RIGHT RADIATOR RESERVOIR YEAR TYPE RADIATOR SCREENS REAR BRAKE BACKING PLATE YEAR TYPE REAR BRAKE CALIPER REAR BRAKE HOSE REAR BRAKE MASTER CYLINDER REAR BRAKE ROD YEAR TYPE REAR BRAKE ROTOR REAR HUB YEAR TYPE REAR WHEEL SPACERS REED VALVE YEAR TYPE RIM SIZE SEAT SHIFT FORKS SHIFT LEVER SHIFT SHAFT YEAR TYPE SHOCK SHOCK ARM LINKAGE SIDE COVER LEFT SIDE COVER RIGHT YEAR TYPE STATOR STATOR COVER SWING ARM SWING ARM PIVOT PIN YEAR TYPE TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT TRIPLE CLAMP BOTTOM TRIPLE CLAMP TOP VOLTAGE REGULATOR YEAR TYPE WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT WATER PUMP COVER NECK YEAR TYPE ENGINE WEIGHT YEAR TYPE
