Pictures for 2003 Honda CR125R
Specs for 2003 Honda CR125R
ENGINE
ENGINE: 125cc, liquid cooled, single cylinder, two stroke, with RC valve
DISPLACEMENT: 125cc
BORE X STROKE: 54.0mm X 54.5mm
COMPRESSION RATIO: 8.0:1
CARBURETION: 38mm Mikuni TMX-x
IGNITION: Digital ignition with three-dimensional mapping and electronic advance
DIMENSIONS
WEIGHT: 193.0 lbs.
GROUND CLEARANCE: 13.6 in.
WHEELBASE: 57.4 in.
FUEL CAPACITY: 2.0 gal.
SEAT HEIGHT: 37.3 in.
DRIVETRAIN
TRANSMISSION: Close-ratio five-speed
FINAL DRIVE: #520 chain; 13T/51T
SUSPENSION: Front: 46mm inverted Kayaba cartridge fork with 18-position rebound & 20-position compression damping adj., 12.6" of travel
Rear: Pro-Link Kayaba single shock with spring preload, 30 position rebound damping and 18-position (low speed) and 2-turn (high)
BRAKES/WHEELS/TIRES
BRAKES Front: Single 240mm disc with twin-piston caliper
Rear: Single 240mm disc
TIRES Front: 80/100-21
Rear: 100/90-19
