Honda CR125R 1982 Picture
Honda CR125R 1982 Specs:
1982 Honda CR125 Specifications
Engine Type 2-stroke
Displacement 124 cc
Bore x Stroke 55 mm x 50 mm
Engine Cooling Liquid
Spark Plug NGK BR9eg
Carburetor 34mm Keihin
Transmission 6 - speed
Steering Rake (Castor) 26 degrees
Steering Trail 3.8 in
Wheelbase 56.1 in
Ground Clearance 14.6 in
Seat Height 38.6 in
Weight, dry 214 pounds
Fuel Tank Capacity 1.7 gallons
Forks 38mm
Fork Travel 11.6 in
Shock Pro-link
Shock Travel 12.2 in
Front Wheel 21 in
Rear Wheel 18 in
Brakes drum/drum
