Page 1 of 7
Building your own Dyno
Posted: Sat Nov 15, 2014 5:40 pm
So you think you made some cool mod on your scoot.
You take it out and run it down the road and the butt dyno say's "YEAH!!!!!"
But often times the butt dyno is extremely inaccurate.
So, lets examine building your own Dyno
What?
Sound scary?
Perhaps not as much as you might first think.
What does a dyno measure?
Work.
So imagine a big fly wheel with a known weight and diameter being driven and measuring how fast you can speed up that flywheel...
Here is one fellas example:
https://www.youtube.com/watch?v=ZQNVKyNYyIA
Re: Building your own Dyno
Posted: Sat Nov 15, 2014 6:07 pm
Of course you could incorporate things like your engine RPM, Exhaust Gas temps, Water temps ect.
So let's start with the basics.
A steel frame, a heavy flywheel on pillow blocks, a way to strap your scoot down, a trigger for measuring the flywheel speed, engine rpm, and how to capture that data on your lap top.
And how about some ventilation
Posted: Sat Nov 15, 2014 6:13 pm
Oh... and some safety gear...
Fire extinguisher, ear protection, decking to cover most of the flywheel.... What else???
Posted: Sat Nov 15, 2014 6:43 pm
Interesting site.
I will be looking at it closely later today...
http://www.land-and-sea.com/do-it-yours ... -plans.htm
Posted: Sat Nov 15, 2014 6:50 pm
tobys 2 strokes
I got to spend a day in Dave Roberts shop (ILR performance) with my tecate 330 on his Dyno. its a Land and Sea dyno.
it measures it at the crank.
I think you could make somthing simular with a hyd pump and valves and pressure sensors
Posted: Sat Nov 15, 2014 7:01 pm
That's cool.
What kind of results did you get?
For me, (Cause I'm simple) I'd rather measure at the rear wheel for a couple of reasons.
I don't want to pull my engine every time I want to do a dyno run.
Something as simple as a different chain and sprocket set will change effect your rear wheel HP.
And it seems like it would be difficult to calibrate and maintain calibration of the fluid type dyno's.
I need simple.....
But let's discuss it...
Posted: Sat Nov 15, 2014 7:24 pm
Dutch-K5 Fan
Whant one for my sellf like so many things
http://www.hpi.be/dyno.php
Maybe this could work?
Dutchie
Posted: Sat Nov 15, 2014 7:28 pm
Thanks for the link Dutchie...
You should buy it and let us know how it works
Posted: Sat Nov 15, 2014 8:25 pm
by Crofter985
This is the Australian web page I mentioned in the other thread.
http://dtec.net.au/index.htm
For a 1000 bucks Australian you get the hardware and software just supply your own flywheel
Posted: Sun Nov 16, 2014 4:29 am
the land and seas are allright. the strain sensor failed often on the one i was around.
what works good is if you take the power off your front sprocket. take an old sprocket and weld a ~4 in long piece of pipe onto it. use a large enough ID to get your snap ring pliers inside to attach it to your bike. on the other end of the piece of pipe, weld on a flange. weld the same flange onto a shaft going to your dyno and bob's your uncle. its nice to have a rubber dampnner in your system somewhere.
power varies alot with air temp, crankcase temp, coolant temp all sorts of things so consistancy is important.
