CR500 Engine tag plate where is the tag plate?
Posted: Thu May 29, 2014 1:36 am
Look on your left engine case toward the back.
Then compare the first two numbers on the tag with this chart
1981 CR450 PE02E-500XXXX
1982 CR480 PE02E 5100000
1983 CR480 PE02E-5200000
1984 CR500 PE02E-530XXXX
1985 CR500 PE02E-540XXXX
1986 CR500 PE02E-550XXXX
1987 CR500 PE02E-550XXXX
1988 CR500 PE020E-570XXXX
1989 CR500 PE02E-580XXXX
1990 CR500 PE02E-590XXXX
1991 CR500 PE02E-5000000
1992 CR500 PE02E-5100000
1993 CR500 PE02E-5200000
1994 CR500 PE02E-5300000
1995 CR500 PE02E-5400000
1996 CR500 PE02E-5500000
1997 CR500 PE02E-5600000
1998 CR500 PE02E-5700000
1999 CR500 PE02E-6000000
2000 CR500 PE02E-6100000
2001 CR500 PE02E-6200000
