How to remove a kick lever shaft from a XR350 & XR500
Posted: Tue Feb 04, 2014 10:40 pm
Joe's guide on how to remove your kick lever shaft from your XR350 & XR500?
First remove your kick lever and clutch cover.
- XR KICK LEVER SHAFT REMOVAL 1.JPG (50.79 KiB) Viewed 6947 times
Then, bolt your kick lever back on.
- XR KICK LEVER SHAFT REMOVAL 2.JPG (48.45 KiB) Viewed 6947 times
Lay the engine on it's side..
- XR KICK LEVER SHAFT REMOVAL 3.JPG (26.52 KiB) Viewed 6947 times
Re: How to remove your kick lever shaft from your XR350 & XR
Posted: Tue Feb 04, 2014 10:50 pm
Now, pull the lever all the way down... and tap upward on the bottom of the kick lever.
You don't have to tap very hard.
- XR KICK LEVER SHAFT REMOVAL 4.JPG (64.91 KiB) Viewed 6946 times
The kick lever shaft will pop out but you will have to move it around a bit to get it out.
- XR KICK LEVER SHAFT REMOVAL 5.JPG (34.89 KiB) Viewed 6946 times
