1989-2004 KX500 Window specs
Posted: Fri Oct 11, 2013 2:07 am
10-23-20 UPDATE: Go to page two..
4-3-17... Latest info on Window mod..
After speaking to Stewart (Current KX500 Stock class Land Speed Record Holder) about the window here is the scoop.
Yes, he gained 3hp on the top end windowed vs non windowed.
Remember, this was a heavily modded engine generating a lot of heat.
Why the gain using a window?
Heat dissipation especially on the piston crown...
If your setting a land speed record, desert racing, Kart racing, Supermoto, or similar (Wide open for extended periods) then you need a window.
If your a trail rider or only see wide open throttle for short periods of time then you likely will not need it.
It will not hurt to have one as far as what Stewart could tell.
My piston is windowed and I run mine in the desert, dunes, and Street Tard.
My engine has a lot of hours on it over the last 10 years and no issues.
So, I will continue to run a window just cause it's cool
Here is the rest of the info..
For years the common belief of big bore KX riders was to window your piston.
According to all the information I could find it adds 2 hp and keeps your engine cooler.
So over at KXRiders several members are discussing the viability of it as well as modifications to the existing design.
What is a windowed piston?
Simply, a piston with a hole in the side.
Obviously the size and placement of the window will have a real impact on performance.
The post below are directly taken from KXriders. I didn't include all comments as there was some a little off track:
Motorrad:
Going to change your Piston window design.. I think the previous tuners design we are all using.. (no names needed)... may be too large, and LOW starving the boost ports to the transfers, as well as the floor ports...............
may go to a triangle shape.
Motorrad:
I think I have a good idea of changing it. would involve re-location. idea came from some of BDI's secret squirel porting... insted of porting the added ports into the jug.... put them in the piston.. more to come.
stewarts piston port area 1.003sqin
my idea .72sq in and it would free and clear the boost ports...
so roughly 75% size
if you dig HARD... I commented on this design to said builder back when he first came up with it.. wink but like many.. I drank the Koolaid, and listened to him, instead of myself.
Motorrad:
I guess my theory is... why would one add a piston port right in the middle of a Rear boost port... causing the intake charge to go to the crank case, instead of a direct path to where it needs to go....
I hope people jump in on this discussion. Im not a one man band here.
Motorrad:
Here is a VERY VERY crude drawing of what Im talking about... live with it. USMC 500:
Motorrad:
Motorrad:
so roughly 75% size
Motorrad:
Motorrad:
