Gearing commander! Nice!
Posted: Thu Jun 13, 2013 4:07 pm
Want to see how a gearing change will effect your performance?
You can enter in your sprocket and tire size and it will show you RPM vs MPH.
http://www.gearingcommander.com/
I was trying to figure out my RPM's at hwy speeds for my KX500 Supermoto.
Here is stock:
Here is the numbers with my current gearing:
Then, I changed the rear wheel size for the use of a 17" rear wheel:
It should be said that just because you put the numbers in there, does not mean your engine will pull it
Do I think my stock KX500 engine will pull 124 MPH?
NO
With a few mods?
Maybe
Will I have the hair to hold the throttle on for that long to test that theory?
We'll see
Thanks goes to Motorrad for posting this tool over at kxriders.
Here is stock:
NO
With a few mods?
Maybe
We'll see
