01 kx500 kawasaki parts for sale
Posted: Tue Apr 23, 2013 12:45 am
If the parts are still here then they are still available...
Carburetor 100.00 the float pin mount, on one side is broken but still functional
- KX500 KAWASAKI 2001 CARBURETOR.JPG (97.76 KiB) Viewed 5252 times
Rear shock with spring for 220lb rider
- KX500 KAWASAKI 2001 shock.JPG (70.4 KiB) Viewed 5252 times
Shock arm linkage 100. All the bearings are good
- KX500 KAWASAKI 2001 shock arm linkage.JPG (72.24 KiB) Viewed 5252 times
Re: 01 kx500 kawasaki parts for sale
Posted: Tue Apr 23, 2013 1:03 am
Front wheel hub and brake rotor, Good bearings. 100.00
- front wheel hub and rotor.JPG (92.49 KiB) Viewed 5251 times
Shock mounts 25.00
- KX500 KAWASAKI 2001 mounts.JPG (81.05 KiB) Viewed 5251 times
Swing arm pivot pin 15.00
- swing arm pivot pin.JPG (67.35 KiB) Viewed 5251 times
Swing arm 100.00 All the bearings and adjustment bolts are good.
- swing arm.JPG (105.93 KiB) Viewed 5251 times
Radiator screens 25.00
- radiator screens.JPG (67.76 KiB) Viewed 5251 times
Posted: Tue Apr 23, 2013 1:14 am
Clutch basket. Has some moderate to heavy wear but still works. 40.00
- clutch basket.JPG (56.22 KiB) Viewed 5250 times
Clutch Inner clutch hub 40.00
- inner clutch hub.JPG (72.3 KiB) Viewed 5248 times
Clutch pressure plate 25.00
- KX500 KAWASAKI 2001 pressure plate.JPG (33.53 KiB) Viewed 5248 times
