01 kx500 kawasaki parts for sale
If the parts are still here then they are still available...
Carburetor 100.00 the float pin mount, on one side is broken but still functional
KX500 KAWASAKI 2001 CARBURETOR.JPG (97.76 KiB) Viewed 5254 times
Rear shock with spring for 220lb rider
KX500 KAWASAKI 2001 shock.JPG (70.4 KiB) Viewed 5254 times
Shock arm linkage 100. All the bearings are good
KX500 KAWASAKI 2001 shock arm linkage.JPG (72.24 KiB) Viewed 5254 times
Re: 01 kx500 kawasaki parts for sale
Front wheel hub and brake rotor, Good bearings. 100.00
front wheel hub and rotor.JPG (92.49 KiB) Viewed 5253 times
Shock mounts 25.00
KX500 KAWASAKI 2001 mounts.JPG (81.05 KiB) Viewed 5253 times
Swing arm pivot pin 15.00
swing arm pivot pin.JPG (67.35 KiB) Viewed 5253 times
Swing arm 100.00 All the bearings and adjustment bolts are good.
swing arm.JPG (105.93 KiB) Viewed 5253 times
Radiator screens 25.00
radiator screens.JPG (67.76 KiB) Viewed 5253 times
Clutch basket. Has some moderate to heavy wear but still works. 40.00
clutch basket.JPG (56.22 KiB) Viewed 5252 times
Clutch Inner clutch hub 40.00
inner clutch hub.JPG (72.3 KiB) Viewed 5250 times
Clutch pressure plate 25.00
KX500 KAWASAKI 2001 pressure plate.JPG (33.53 KiB) Viewed 5250 times
