KX500 ELECTRICAL SPECS & WIRING DIAGRAM
Posted: Tue Jun 29, 2021 12:56 am
STATOR
83-85 KX500 - 21003-1109 -
336-504 OHMS BLACK/RED TO BLACK YELLOW
14.2-21.4 OHMS RED TO BLACK/YELLOW
10.4-15.6 OHMS WHITE/RED TO BLACK/YELLOW
(2 coil style) 86 KX500 - 21003-1141 -
432-648 OHMS BLACK/RED TO BLACK/YELLOW -
4.0-6.0 OHMS WHITE/GREEN TO WHITE/RED
(2 coil style) 87-89 KX500 - 21003-1169 -
432-648 OHMS: BLACK/WHITE TO BLACK/YELLOW -
4.0-6.0 OHMS: WHITE/RED TO BLACK/YELLOW
90-04 KX500 - 153-230 OHMS (Ricky Stator says you can run it up to 350 with no issues. I have also ran them out of spec with no issues as well) BLACK/WHITE TO BLACK/YELLOW -
7.9-11.9 OHMS: WHITE/RED TO BLACK/YELLOW
KX500 Spark Plug
1983-1984 KX500 REGULAR B9EG, V-TYPE (GOLD) B9EGV, IRIDIUM BR9EIX
1985-1997 KX500 REGULAR B8EG, V-TYPE (GOLD) B8EGV, IRIDIUM BR8EIX
1998-2004 KX500 REGULAR BR8EG, V-TYPE (GOLD) N/A, IRIDIUM BR8EIX WITH A SOLID TERMINAL NUT
The spark plug gap for the 1983-2004 KX500 is .024"
IGNITION COIL
Primary (Small wire)
83-86 KX500 .85-1.15 ohms
87 kx500 .8-1.2 ohms
88-89 kx500 .85-1.15 ohms
1990 and newer .26-.36 ohms
Secondary (Spark plug wire)
83-86 KX500 5.0-6.8K ohms
87 kx500 5.6-8.4K ohms
88-89 kx500 5.0-6.8K ohms
1990 and newer 2.6-3.6K ohms
Re: KX500 ELECTRICAL SPECS & WIRING DIAGRAM
Posted: Tue Jun 29, 2021 1:07 am
83-85 KX500
83-85 KX500.jpg (459.29 KiB) Viewed 11960 times
Posted: Tue Jun 29, 2021 1:08 am
1986 KX500
86 KX500.jpg (565.64 KiB) Viewed 11960 times
1987 KX500
1987 KX500.jpg (483.22 KiB) Viewed 11960 times
Posted: Tue Jun 29, 2021 1:09 am
1988 KX125 KX250 KX500
88 KX125 KX250 KX500.jpg (522.12 KiB) Viewed 11959 times
1989 KX500
1989 KX500.jpg (415.29 KiB) Viewed 11959 times
Posted: Tue Jun 29, 2021 1:10 am
1990-2004 KX500
90-04 KX500.jpg (374.04 KiB) Viewed 11959 times
ELECTRICAL SPECS KX500 1990-2004.png (546.89 KiB) Viewed 11957 times
