What modern hubs can I put on my 86 kx500
Posted: Thu Apr 11, 2019 12:42 am
by Neilson95
What modern hubs can I change to and put in my 86 kx500 I no I i I will have to make a few changes but I want to put front and rear hubs in
Re: What modern hubs can I put on my 86 kx500
Posted: Thu Apr 11, 2019 3:45 am
All modern hubs will present the same challenges you will find on the kx450f hubs.
All the major manufactures use a 25mm rear axle and a 20mm front axle except for KTM and Husky which use a even bigger front axle.
All use larger rotor sizes.
I plan on building a modern version 83 kx500 that I will be updating just about everything on so I'm right behind you..
