Page 1 of 3
Sean Collier's "The Beast" Engine in for a refresh and mods.
Posted: Thu May 25, 2017 11:32 pm
As some will remember we had this engine in about 9 months ago.
We were told under no uncertain terms not to improve the performance.
So here was what we were told.
Make it shift good, and try to make it survive for a while longer.
The plating on the cylinder was worn out around the exhaust port, the piston was junk, and all the shift components were extremely worn out.
So, we replaced all the worn out parts with used parts that were still in factory spec.
We cleaned everything, polished a few parts, replaced all the bearings, seals, gaskets, o-rings, snap rings, and even tossed in a used piston with new rings.
After it was done the engine ran very well but it still had worn plating that desperately need to be replaced.
The crank was pretty worn as well..
Also, the power on this engine was explosive which makes it difficult to ride for 30+ minutes against other pro riders :shock:
Oscar put an hour meter on the bike the first time we had it.
When we got it back it had 10.8 more race hours on it.
Frankly I'm shocked it held together :lol:
Our goal this time is to rebuild the cylinder and head to the same specs as the engine in Groot.
New plating, porting, piston and crank are all in the works, along with some special mods that we will get too later 8-)
Re: Sean Collier's "The Beast" Engine in for a refresh and mods.
Posted: Thu May 25, 2017 11:49 pm
I received the engine today..
Sean Collier The Beast engine rebuild 101.jpg (416.17 KiB) Viewed 23351 times
It just needs a minor tune up :lol:
On the pressure washing mat.
Sean Collier The Beast engine rebuild 102.jpg (315.31 KiB) Viewed 23351 times
Posted: Thu May 25, 2017 11:51 pm
Ready to crack here open...
Sean Collier The Beast engine rebuild 105.jpg (321.46 KiB) Viewed 23350 times
I love when a polished part looks like this nearly a year of racing later..
Sean Collier The Beast engine rebuild 103.jpg (361.58 KiB) Viewed 23350 times
Posted: Thu May 25, 2017 11:53 pm
The bad thing is... the exhaust port is not looking any better...
Sean Collier The Beast engine rebuild 104.jpg (233.35 KiB) Viewed 23349 times
Here is a vid showing the play in the piston..
https://www.youtube.com/watch?v=VUTfanjjw08
Posted: Thu May 25, 2017 11:55 pm
I already know the port timing so I don't have to worry about that.
But I still need to get the head squish calculated so I need to get some additional measurements..
Sean Collier The Beast engine rebuild 106.jpg (396.66 KiB) Viewed 23347 times
More to come... :o
Posted: Tue Jun 06, 2017 11:08 pm
I started doing the rough porting on the cylinder today..
As you can see, this thing was ready to blow :shock:
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 114.jpg (212.3 KiB) Viewed 23271 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 115.jpg (230.58 KiB) Viewed 23271 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 116.jpg (349.52 KiB) Viewed 23271 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 117.jpg (147.37 KiB) Viewed 23271 times
Posted: Tue Jun 06, 2017 11:09 pm
We are going to toss the stock carb and use a 97 KX250 carb 8-)
before
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 118.jpg (335.57 KiB) Viewed 23270 times
After
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 119.jpg (306.25 KiB) Viewed 23270 times
Posted: Fri Jun 09, 2017 2:06 am
I spent a bit of time doing the rough porting the other day..
Today, Jason put his hand to the port tools and began to massage the cylinder..
No gloves, no eye protection... Nice Jason... Nice...
KX GURU RACING rebuilding the beast 120.jpg (412.5 KiB) Viewed 23255 times
Posted: Mon Jun 12, 2017 5:19 am
Jason has a bit more roughing is done..
KX GURU RACING rebuilding the beast 121.jpg (254.96 KiB) Viewed 23240 times
Posted: Tue Jun 27, 2017 11:43 pm
by shue415
Hey
Why hasnt sean been racing the kx 500?
I see at mammoth he raced a KTM
