Page 1 of 6
Posted: Fri Dec 09, 2016 10:05 pm
Brents 1992 KX500 engine needs a bit of work before it's ready for his snow bike.
Starting with the cylinder.. It has been ported by Eric Gore.
This cylinder porting would be great for a trail bike but not so good for a Snow bike..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 101.JPG (96.3 KiB) Viewed 39865 times
When you see stuff like this on a bike it makes you a bit nervous on what you will find..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 102.JPG (103.8 KiB) Viewed 39865 times
Posted: Fri Dec 09, 2016 10:15 pm
Here is a few more issues..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 103.JPG (111.59 KiB) Viewed 39864 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 104.JPG (93.85 KiB) Viewed 39864 times
Posted: Fri Dec 09, 2016 10:17 pm
At first glance the transmission didn't look to bad... excluding the milky oil of course..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 105.JPG (114.98 KiB) Viewed 39863 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 106.JPG (122.65 KiB) Viewed 39863 times
Posted: Fri Dec 09, 2016 10:20 pm
The crank is looking a bit haggard..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 107.JPG (129.42 KiB) Viewed 39862 times
This gear looks pretty good..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 108.JPG (63.06 KiB) Viewed 39862 times
Posted: Fri Dec 09, 2016 10:22 pm
This one has a bit of wear... as to be expected..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 109.JPG (74.75 KiB) Viewed 39861 times
This one is chipped which is why there was some metal shavings in the bottom of the cases..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 110.JPG (74.97 KiB) Viewed 39861 times
Posted: Fri Dec 09, 2016 10:24 pm
Both these gears have a bit of wear but no worry..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 111.JPG (66.34 KiB) Viewed 39860 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 112.JPG (85.2 KiB) Viewed 39860 times
Posted: Fri Dec 09, 2016 10:26 pm
The small clutch basket gear has a chip out of it..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 113.JPG (69.66 KiB) Viewed 39859 times
And the big one is bad as well :shock:
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 114.JPG (100.42 KiB) Viewed 39859 times
Posted: Fri Dec 09, 2016 10:41 pm
More gear damage..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 115.JPG (61.93 KiB) Viewed 39858 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 116.JPG (104.35 KiB) Viewed 39858 times
Posted: Sat Dec 10, 2016 3:24 am
More damage...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 117.JPG (70.16 KiB) Viewed 39843 times
More damage...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 118.JPG (295.12 KiB) Viewed 39843 times
Posted: Sat Dec 10, 2016 3:27 am
Note the 4mm pin for the center flapper?
Can you say Jacked up!!!
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 119.JPG (59.87 KiB) Viewed 39842 times
Crack in the exhaust port..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 120.JPG (106.27 KiB) Viewed 39842 times
