Page 1 of 4
1999 KX500 KAWASAKI ENGINE BUILD FOR KEVIN
Posted: Fri Dec 11, 2015 12:50 am
This was a interesting engine that came to us.
The base of the cylinder was machined .040", the squish on the head was .045", the timing was retarded, and the boost ports were hogged out.
Someone was looking for some more torque
But this customer want's HP and some more top end so we aim to please...
- OEM-CYCLE.COM 1999 KX500 KAWASAKI BUILD FOR KEVIN 101.JPG (149.95 KiB) Viewed 9344 times
- OEM-CYCLE.COM 1999 KX500 KAWASAKI BUILD FOR KEVIN 102.JPG (125.63 KiB) Viewed 9344 times
Re: 1999 KX500 KAWASAKI ENGINE BUILD FOR KEVIN
Posted: Fri Dec 11, 2015 12:52 am
Parts come to us like this..
- OEM-CYCLE.COM 1999 KX500 KAWASAKI BUILD FOR KEVIN 103.JPG (55.38 KiB) Viewed 9343 times
But they go back out more like this...
- OEM-CYCLE.COM 1999 KX500 KAWASAKI BUILD FOR KEVIN 105.JPG (52.3 KiB) Viewed 9343 times
- OEM-CYCLE.COM 1999 KX500 KAWASAKI BUILD FOR KEVIN 104.JPG (49.37 KiB) Viewed 9343 times
Posted: Fri Dec 11, 2015 9:04 pm
Ordered the rod today.
We will wait for it to get here then polish it.
Then we will send it out for balancing, and rebuilding.
Posted: Sun Dec 13, 2015 3:33 pm
The trans needed 3rd and 4th both input and output
Posted: Fri Jan 15, 2016 3:54 am
Balanced and ready for assembly.
- !cid_20160114_161126.jpg (141.42 KiB) Viewed 9296 times
Posted: Tue Feb 16, 2016 2:29 am
Posted: Tue Feb 16, 2016 2:38 am
Dirt things first, gotta remove all the bearings, seals, and bearing retainers..
- 20160215_162912.jpg (359.44 KiB) Viewed 9258 times
Shish Kebab!!!
- 20160215_162941.jpg (413.24 KiB) Viewed 9258 times
When lapping you can have your buddy hold the cases for you or.....
- 20160215_165344.jpg (417.6 KiB) Viewed 9258 times
Timesaver is the best stuff out there for lapping aluminum..
- 20160215_170330.jpg (355.39 KiB) Viewed 9258 times
Posted: Tue Feb 16, 2016 2:42 am
Gotta get the Timesaver on the entire surface
- 20160215_170332.jpg (363.75 KiB) Viewed 9258 times
This is the typical trouble area for KX500's... Note where the dark grey is around the edges of the cases.
Then look at the yellow area.
The yellow area means that the cases have a gap there.
- 20160215_170500.jpg (379.77 KiB) Viewed 9258 times
So rub rub rub... swirl swirl swirl... rub rub rub... swirl swirl swirl... rub rub rub... swirl swirl swirl... rub rub rub... swirl swirl swirl...
- 20160215_171724.jpg (332.98 KiB) Viewed 9258 times
Now they are dark grey all around which means they are ready for clean up, porting, and repair,,
Posted: Wed Feb 17, 2016 5:30 am
Look at that cute little hole that feeds the main bearings...
- 20160216_123618.jpg (159.26 KiB) Viewed 9250 times
That's better, enlarged and countersunk
- 20160216_124136.jpg (147.36 KiB) Viewed 9250 times
Now look at this oil transfer hole.... See how high it is from the floor of the case?
When you drain the oil, this will leave some behind...
- 20160216_125414.jpg (298.18 KiB) Viewed 9250 times
Problem solved
- 20160216_171354.jpg (104.03 KiB) Viewed 9250 times
Posted: Wed Feb 17, 2016 5:34 am
There are other improvements made but I can't show you them all
