Page 5 of 6
Posted: Fri Dec 30, 2016 4:50 am
Ok.. The case is back from weld and the cylinder has the valves installed so I can cut the sub port outlets to match the valves...
Still waiting on parts.....
Posted: Wed Jan 04, 2017 1:39 am
by Kx500fan
Any updates?
Posted: Thu Jan 05, 2017 10:03 pm
Yeah... Still waiting for the stinkin gears :x
Posted: Thu Jan 05, 2017 10:04 pm
However, the crank should be here very soon 8-)
Posted: Sat Jan 07, 2017 11:58 pm
Finally.. the crank is here :shock:
Incidentally... Send your crank parts out for assembly and balancing while dirty... and they will come back dirty with a new rod kit.
Send them out clean or polished and the results speak for themselves.
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 145.JPG (243.01 KiB) Viewed 43920 times
Posted: Sun Jan 08, 2017 12:02 am
I'll be calling on Tuesday to get an update on the gears...
Posted: Mon Jan 09, 2017 11:53 pm
Jason spent a couple of hours today cleaning up the left case weld for the counter sprocket guard.
Turned out really nice.
He also enlarged the main bearing oiling hole and capture point.
Also, he spent some time cleaning up the chain wear around the output shaft.
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 146.JPG (380.6 KiB) Viewed 43906 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 147.JPG (361.21 KiB) Viewed 43906 times
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 148.JPG (353.02 KiB) Viewed 43906 times
Posted: Thu Jan 19, 2017 1:03 am
A bit more progress...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 150.JPG (431.14 KiB) Viewed 43872 times
Bearings and seals are in...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 149.JPG (421.78 KiB) Viewed 43872 times
Posted: Thu Jan 19, 2017 1:06 am
Gettin it ready..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 151.JPG (444.74 KiB) Viewed 43871 times
Crank is in...
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 152.JPG (455.38 KiB) Viewed 43871 times
Even though we are not ready to install the trans and such we still need some additional info before we send the cylinder and head out for work :shock:
Posted: Thu Feb 02, 2017 9:06 pm
Ready for the cases to be assembled.
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 153.JPG (503.6 KiB) Viewed 43838 times
Case halves are assembled..
KX GURU RACING 1992 KX500 SNOW BIKE ENGINE BUILD FOR BRENT 154.JPG (313.76 KiB) Viewed 43838 times
