Page 4 of 4
Re: MY 1991 KX250 HAS NO SPARK!
Posted: Sun Jul 31, 2016 1:47 pm
If you can find the replacement parts then no, you don't need a whole new stator.
Another option is to call Ricky Stator and have them rebuild yours.
They will even give you a one year warranty on it.
Posted: Sun Jul 31, 2016 7:21 pm
by Rookestar
Ok thanks is that site an American site as in from the uk
Posted: Sun Jul 31, 2016 8:23 pm
http://www.rickystator.com/
Ricky Stator
Mailing address:
1672 Main St., Unit E, PMB 104
Ramona, CA 92065
PHONE: 1-866-631-3837
FAX: 760-787-0313
Regular Hours (All Times PACIFIC)
Monday-Friday: 8am - 4:30pm
Saturday & Sunday: Out Riding
info@rickystator.com
Posted: Mon Aug 01, 2016 12:17 pm
by Rookestar
Hi I've just Took off my starter and seen that the red/black and red had tap on them so i rewired them and put new electrical tape around them and now getting Reading around 300 ohms were do I go from here Thanks
Posted: Mon Aug 01, 2016 1:12 pm
If you still have no spark and you know that you have a good ground, the connectors are all good, the stator has good ohm specs, the coil has good ohm specs, the kill switch is good, there is only one other thing it can be...
Posted: Mon Aug 01, 2016 1:52 pm
by Rookestar
Cdi ?? If so I have bought a Second hand Cdi box for a kx 250 1991 and still no spark so then i bought a kx 250 1993 cdi box because it had a White wire and was matching my starter wires and still no spark so that's 3 cdi ov got
or maybe it could be me as I'm no specialist when it comes to electrics starters and coils
Posted: Tue Aug 02, 2016 10:12 am
by Rookestar
Hi can you tell me if this is right my multimeter only flashes like for instance it says 300ohms then goes straight down to 000ohms never stays Constant is this right thanks
Posted: Tue Aug 02, 2016 3:16 pm
No, it has to be solid.
Sometimes you need to clean the contact points really well..
Posted: Sat Aug 06, 2016 12:32 pm
by Rookestar
Hi I ended up buying new starter coil cdi as a set it started straight away thanks for all the halp you've bean very helpful thanks
Posted: Mon Aug 08, 2016 2:25 am
No problem.
post some pics of your ride sometime and show us your riding area's...
