motojason
Quote from: queen of spodes on September 22, 2014, 03:06:24 PM
Before I dump $80 on this tool I'll likely only use a few times in my lifetime, do I absolutely need this tool or can I make something for cheap that does the same thing?
No, you do not need that tool. I don't like the idea of pressing on the crank to assemble the bottom end. That tool only acts as a crank spacer to keep the flywheels parallel while you press the cases onto the crank. I put my crank in the freezer and my cases in the oven. Then I use some threaded plumbing fittings from the hardware store to pull the crank into the cases if it needs some additional tweaking. Use 1-1/4 to 1-1/2" black iron couplings and 3/4 reducer. Use the fittings as a spacer between the crank's ends and the case, use washers between spacers and nut on the crank's primary side or bolt on the ignition side. When you tighten the nut or bolt onto the crank it draws it into the case without putting stress on the crank pin. The plumbing parts and big washers cost me about $6-7 at Ace and I have used them on KXs, YZs, and CR cranks with no problems
motojason
And... Awesome job on the restoration! That is a great bike and its nice to see the care and quality that you are putting into the project. What do you plan on doing with it when you are done?
dinkyguitar
I didn't use any special tools either when I closed my cases on my 87 KX250.
I used a barbecue to heat my cases to about 170 deg, and also froze the crank.
Once the case heated I quickly got the crank and dropped it in. I had to use a piece of 2x4 to tap the crank in because the coldness of the crank hitting the heated case will sometimes stop it from sliding in.
Then, I quickly applied yamabond to the case, got the other half of the case and installed it.....you have to work quickly, but it can be done. Just have everything ready and planned and make a dry run first.
With heat and freezing parts, you can put or removed just about every bearing in the motor without buying special tools.
dinky,
queen of spodes
Quote from: motojason
Just the workaround I was hoping for.
Quote from: motojason on September 25, 2014, 01:57:53 AM
Thanks! I will have well over two grand in it by the time its done, maybe closer to 2500 after tires, bars, ect. I am not going to finish the wheels at this time - had them soda blasted clean but will leave the wheelsets to the next owner. Hope they remain silver per stock.
My hope is to sell it to someone who will put it away and not ride it much if at all. Parts are extremely scarce for this machine. Would love to see it in a museum eventually. It won't be museum ready when I'm done but close.
motojason
Quote from: queen of spodes on September 25, 2014, 03:47:47 AM
I would have a hard time parting with it if I had done all that work. I wouldn't be able to keep from riding it either! That is half the fun for me, the building is just the prelude to the riding. Love the character of 80s KXs.
Looking forward to finishing my 85 500 this winter and plan to rebuild my 88 250 sometime next year. Then I might be done for awhile. Well, unless a 79 125 turns up... grin
Good luck with finding your 125 a good home.
Please keep posting till it's done, this is a great thread!
queen of spodes
Rest assured this bike will be ridden a little if/when I finish with it.
queen of spodes
I've ordered the replacements but am curious to see what others think. How important is it to replace the shaft snap-rings when disassembling?
- queen of spodes 89 kx125 107.png (721.18 KiB) Viewed 9559 times
