Page 3 of 8
Posted: Thu Oct 01, 2015 8:51 pm
- KX500 WITH A KX450F REAR SHOCK 104.JPG (39.17 KiB) Viewed 80111 times
- KX500 WITH A KX450F REAR SHOCK 105.JPG (37.14 KiB) Viewed 80111 times
Posted: Thu Oct 01, 2015 9:29 pm
Here is the issue with the clevis..
- KX500 WITH A KX450F REAR SHOCK 106.JPG (71.83 KiB) Viewed 80110 times
Posted: Thu Oct 01, 2015 10:01 pm
OK... Sometimes you feel like a dummy...
I unscrewed the clevis off a 92 kx250 shock (Same as the KX500 clevis) and screwed it right on the KX450F shock..
- KX500 WITH A KX450F REAR SHOCK 107.JPG (99.24 KiB) Viewed 80108 times
Posted: Sat Dec 05, 2015 3:55 am
Before I go any further, I need a mock up.
Turns out I just happen to have a few spares laying around...
Except for the stupid swingarm that I had to buy on eBay
- WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 101.jpg (284.55 KiB) Viewed 79976 times
Posted: Sat Dec 19, 2015 5:47 pm
Why not bolt the KX450F shock to the 88 chassis and be done with it?
It is simply too long.
Here is a pic using the kx450f shock with it's stock clevis and bolted to the Uni Trak linkage
- WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 103.jpg (414.73 KiB) Viewed 79947 times
Posted: Sat Dec 19, 2015 5:50 pm
Again, note the difference in the clevis length
- WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 104.jpg (229.42 KiB) Viewed 79947 times
Posted: Sat Dec 19, 2015 5:58 pm
After swapping the clevis everything lines up perfectly
- WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 105.jpg (208.76 KiB) Viewed 79947 times
- WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 106.jpg (263.3 KiB) Viewed 79947 times
- WWW.OEM-CYCLE.COM KX500 REAR SHOCK UPDATE 107.jpg (282.35 KiB) Viewed 79947 times
Looks great!
But it does not work
Note the location of the shock reservoir.
Note that the reservoir goes right through the middle of where the pipe is suppose to go.
Posted: Sat Dec 19, 2015 5:59 pm
So the two choices I see is to reroute the pipe or move the reservoir...
More to come
Posted: Sun Dec 20, 2015 1:46 am
Here is a quick vid to help you better understand what I'm running into:
https://youtu.be/IKh9uMr2l8Y
Posted: Sun Jan 24, 2016 6:23 pm
by Ralow998
Can I do this on my 91 KX 500 frame? Why does it look like the top bearing isn't pressed in? Can I use a shock from a KX 250F of the same year?
