Page 3 of 24
Posted: Wed Dec 19, 2012 12:05 am
I worked a bit today making a new muffler.
I took a FMF Power Core and shortened it 5.5" :shock:
In Oregon we can get a sound ticket for being too loud in the woods, sand dunes or any other state ran riding area.
On the street, you can run whatever.
Makes perfect sense to me :?:
Here is what I started with:
First step was disassembly.
Whoever owned this before replaced the packing and sealed both ends with silicone.
I would not recommend using silicone to seal your muffler ends if you ever plan on packing the muffler again as it was very difficult to get it apart.
Since I was cutting mine anyway it wasn't as big of a deal.
With the muffler cut I removed both end and the packing material.
With all the material removed I cut the inner perforated tube to the correct length.
Then I drilled the new end cap holes.
New packing material....
Assembled it.
It took about an hour to do this because I had to go next door to a machine shop and borrow a water cooled band saw to cut the muffler in half.....
Sometimes it adds to your build time because you need to say hi to everyone, answer all their questions ect...
Still I am very happy with how this turned out.
Next, I am thinking about beveling the bottom....
So stay tuned....
Posted: Wed Dec 19, 2012 11:26 pm
OK, I couldn't leave well enough alone.
After marking out my cut lines I decided to start cutting :lol:
KX500 SM MUFFLER MOD1
KX500 SM MUFFLER MOD1.JPG (82.4 KiB) Viewed 17396 times
KX500 SM MUFFLER MOD2
KX500 SM MUFFLER MOD2.JPG (85.2 KiB) Viewed 17396 times
KX500 SM MUFFLER MOD3
KX500 SM MUFFLER MOD3.JPG (93.56 KiB) Viewed 17396 times
A few more tweaks and a trip to the weld shop and I'll have something a little different.
I also ordered some square tubing for the outlet....
KX500 SM MUFFLER MOD4.JPG (15.11 KiB) Viewed 17396 times
KX500 SM MUFFLER MOD5.JPG (11.82 KiB) Viewed 17396 times
More to come...
Posted: Thu Dec 20, 2012 12:24 am
Here is the project after first stage welding.
KX500 SM MUFFLER MOD6.JPG (77.93 KiB) Viewed 17395 times
KX500 SM MUFFLER MOD7.JPG (78.08 KiB) Viewed 17395 times
More to come after I get my square tubing...
Posted: Thu Dec 20, 2012 8:57 pm
And then I started thinking about.....
KX500 SM MUFFLER MOD8.JPG (12.54 KiB) Viewed 17393 times
Posted: Sat Dec 22, 2012 1:13 am
Here's where I am at tonight.
KX500 SM MUFFLER MOD8-1.JPG (162.64 KiB) Viewed 17392 times
KX500 SM MUFFLER MOD8-2.JPG (49.08 KiB) Viewed 17392 times
Now I'm waiting for the aluminum tubing to come in.
Posted: Mon Dec 24, 2012 5:35 am
Or, perhaps I'll do something like this:
k5sm muffler.JPG (42.4 KiB) Viewed 17382 times
Posted: Wed Dec 26, 2012 10:42 pm
I was asked how I was going to make the internal baffling.
This is a rough idea.
I am tying the two pieces of internal baffling with some small pieces of plate not shown in the pics.
The lower tube will be functional but the upper tube will take the major volume of exhaust.
k5sm muffler baffel.JPG (95.38 KiB) Viewed 17370 times
Even though this will be primarily for street use I am installing some stainless steel mesh for a spark arrestor.
KX500 SM MUFFLER MOD ARRESTOR.JPG (29.29 KiB) Viewed 17370 times
Posted: Wed Jan 02, 2013 10:26 pm
The aluminum tubing arrived today so I cut it in half at the approximate finish angle and took the pieces to have them tig welded.
KX500 SM MUFFLER MOD8-3.JPG (89.29 KiB) Viewed 17364 times
KX500 SM MUFFLER MOD8-4.JPG (92.44 KiB) Viewed 17364 times
Once the pieces are tigged together I will finish shaping them and then have them tigged to the muffler body.
Posted: Thu Jan 03, 2013 4:38 pm
by Steve O
Now your just teasing us!
Posted: Thu Jan 03, 2013 8:47 pm
Steve O wrote:Now your just teasing us!
That's not teasing, this is :D
KX500 SM MUFFLER MOD8-5.JPG (59.32 KiB) Viewed 16761 times
