KX Guru Racing JT Engine Works KX500 Induction Crank testing
Re: KX Guru Racing JT Engine Works KX500 Turbo Crank testing
Disassembly went fairly smoothly... no issues.... Nothing really worn out beyond usability... Just dirty... and really not that bad.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 121.jpg (501.66 KiB) Viewed 16611 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 122.jpg (536.51 KiB) Viewed 16611 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 123.jpg (339.8 KiB) Viewed 16611 times
If the testing proves out that this is a good mod then this crank will be disassembled, cleaned, polished, and sent to Steve Parris for his patented Turbo Crank modifications, then reassembly and balance. For my own bike, I will not build a crank without balancing.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 124.jpg (282.32 KiB) Viewed 16611 times
And now to the heart of the matter....
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 125.jpg (218.49 KiB) Viewed 16610 times
Ain't she a beauty?
Masking off the bearings from the work that will be done on the cases.
We don't want to contaminate the bearings and seals any more then what would happen during a careful disassembly.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 126.jpg (370.96 KiB) Viewed 16610 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 127.jpg (469.12 KiB) Viewed 16610 times
You can see the black mark at the top of the crank area.
that is to give us a guide when we round the corner.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 128.jpg (398.02 KiB) Viewed 16609 times
Man stuff at the Man cave...
https://www.youtube.com/watch?v=1x5plM6KFL8
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 129.jpg (521.36 KiB) Viewed 16609 times
After all modifications were made everything was thoroughly inspected by our professional in shop quality control inspector.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 130.jpg (316.48 KiB) Viewed 16609 times
The clutch components looked good so they were rinsed off and put back in... even the plates...
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 131.jpg (315.12 KiB) Viewed 16606 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 132.jpg (469.4 KiB) Viewed 16606 times
The crank is in so now it's time to get this thing rolling again..
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 133.jpg (454.34 KiB) Viewed 16606 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 134.jpg (437.52 KiB) Viewed 16606 times
The piston is back in... yes, this is not what I want to do but it is necessary to get a fair comparison.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 134-2.jpg (410.22 KiB) Viewed 16602 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 135.jpg (480.04 KiB) Viewed 16604 times
All the pieces and parts going back together...
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 136.jpg (333.73 KiB) Viewed 16604 times
Just in case you were wondering what assembly lube Jason used..
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 137.jpg (403.55 KiB) Viewed 16604 times
It's 9pm and we are ready to drop it back in... Not world record time but for what we did and how we had to do things, not bad :D
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 138.jpg (488.47 KiB) Viewed 16604 times
The engine is in and Jason is working on jetting...
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 140.jpg (561.6 KiB) Viewed 16600 times
After a few hours of test rides and jetting changes we are using a 152 main :o :shock: :o
I know I know... but that's what it want's with forced induction....
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 141.jpg (589.04 KiB) Viewed 16600 times
Ready for the Butt dyno test...
https://youtu.be/G5x2159y-4w
At this point the simple truth of the matter is, as much HP as we made on the KX250, we lost on the KX500... We have all sorts of theories, guesses, and fabrications... We had hoped to have a solution before this question was asked but so far we really haven't had the time to get back to it. But we have a loose plan of action to follow depending on what we find as we test. So, don't loose hope... We are working on it. And who knows, it may be something very simple or it could require a complete redesign. But whatever we find we will share... :shock:
There are so many possibilities...
We are starting with the easiest and simplest things first and working out to the difficult and absurd... Believe me... we want to figure this out.
If we can make it like it is in the 250 combined with some other Guru mods we will have something real special..
60something
Post by 60something »
Just remember, it took Edison more than a couple tries to find the right light bulb filament! ;)
1987 Kawasaki KX500
Lol... I used that same analogy about the crank just the other day.
It seems that there are some naysayers that don't believe it can possibly work.
Yet, we already have one working on a KX250.
I even posted the dyno results..
Disbelief and some were down right nasty about it :o
Why do they feel this way?
Because when something works that they can't wrap their head around or it doesn't fit their specific idea's on how something works, then it must be impossible :lol:
But no worries... We will try and try.
We have a lot of idea's on why it works on the 250 and not the 500.
We will start with the easiest to modify first and go from there.
Keep in mind, I have no financial interest in making this work, I just want to make more power for my bike 8-)
And after the initial results on the 250 were so amazing, and the ride reports have been so positive, I want that same sort of increase on the 500... Then I will add my other mods and really smile..
