The best CR500 engine build I have ever seen... Kinda :-)
This was originally posted at http://www.bannedcr500riders.com by dogger315.
Full credit goes to him and thanks goes to Roost for letting me post it here..
dogger315
This is a series of post that will detail the assembly of a CR500 Engine.
The series is aimed at the novice mechanic and may seem overly simple to
the old hands out there so please keep that in mind
In addition to the build, I will detail all the modifications made to
race prep this engine for MX.
This is a scratch build from mostly new 2001 parts except for the tranny
which is a close ratio. I had some used parts around the shop and
utilized a 2001 cylinder head, hose joint, exhaust manifold and right
side case cover from that stash. Those parts were restored to new
condition.
Before starting the assembly, the race prep started by sending the
crankshaft and piston assembly to Crankworks for balance from 4500
to 7500 rpm. All the rest of the rotating components were sent to
Evans Performance for Cryo-REM treatment. This isotropic finish
greatly reduces friction while the cryo treatment increases the strength
of the components. This in turn improves shifting action, lessens gear
wear and allows the engine to run cooler.
Starting with the right side case, install the bearing retainers
Dogger315 cr500 engine build at www.oem-cycle.com 100.jpg (216.34 KiB) Viewed 19714 times
Install the rubber baffle.
Dogger315 cr500 engine build at www.oem-cycle.com 101.jpg (240.41 KiB) Viewed 19714 times
Install the crankshaft in the right side case using a crankshaft installation
tool.
Dogger315 cr500 engine build at www.oem-cycle.com 102.jpg (266.93 KiB) Viewed 19714 times
Then install the previously assembled transmission clusters
Dogger315 cr500 engine build at www.oem-cycle.com 103.jpg (125.69 KiB) Viewed 19714 times
Re: The best CR500 engine build I have ever seen
Dogger315 cr500 engine build at www.oem-cycle.com 104.jpg (118.81 KiB) Viewed 19714 times
after lubricating with clean gear oil (Honda HP Pro) into the right side case.
The clusters have to be installed meshed together.
Dogger315 cr500 engine build at www.oem-cycle.com 105.jpg (261.97 KiB) Viewed 19714 times
Next up are the shift forks. Forks stamped "R" and "L" on the right
side of the shift drum with "R" on the bottom and the fork stamped
"C" on the left. Douse everything in gear oil before installing
Dogger315 cr500 engine build at www.oem-cycle.com 106.jpg (213.74 KiB) Viewed 19714 times
Now install the shift drum after coating it with gear oil. Insert the shift
fork pins into the shift drum grooves.
Dogger315 cr500 engine build at www.oem-cycle.com 107.jpg (202.93 KiB) Viewed 19714 times
Finally, coat the shift fork shafts with gear oil and install.
Dogger315 cr500 engine build at www.oem-cycle.com 108.jpg (199.62 KiB) Viewed 19714 times
Now turn your attention to the left side case half and install the bearing
retainer as shown using threadlock on the screws and torquing to 7 lb.ft.
Dogger315 cr500 engine build at www.oem-cycle.com 109.jpg (224.09 KiB) Viewed 19714 times
install the crankcase ventilation hose.
Dogger315 cr500 engine build at www.oem-cycle.com 110.jpg (203.25 KiB) Viewed 19714 times
Back to the right side case, lubricate the two dowels with oil and install
along with a new gasket.
(KXGURU recommends a OEM or Cometic gasket)
Dogger315 cr500 engine build at www.oem-cycle.com 111.jpg (260.2 KiB) Viewed 19714 times
Place the left side case on the right and install using the crankshaft
installation tool as shown to pull the case together while keeping a
constant gap.
Dogger315 cr500 engine build at www.oem-cycle.com 112.jpg (263.25 KiB) Viewed 19714 times
Remove the crankshaft installation tool, install the 10 bolts (Red arrows),
and tighten to 7 lb.ft. Pack the seal lips with grease and install (Blue
arrows). Grease a new O ring and place it in the collar (Yellow arrow)
and install. Don't forget the seal over the clutch actuating rod bore
inside the ignition cavity (not marked). Finally, trim the excess gasket
material above the cylinder deck.
Dogger315 cr500 engine build at www.oem-cycle.com 113.jpg (181.59 KiB) Viewed 19714 times
Grease the lips and install a new seal (Blue arrow), and collar (Yellow
arrow), on the right side.
Dogger315 cr500 engine build at www.oem-cycle.com 114.jpg (236.16 KiB) Viewed 19714 times
That wraps up this segment. Next up are all the components in the right
side case cover and the ignition.
Helpful top from 100hp honda
antiseize on the dowels will make it easy coming apart next time, oil may work the same but ive never tried it so i dont know. becareful how far in you put the seals
Now it's time to install all the components on the right side of the
combined cases. When I speak of gear lube, I am using Honda HP
Pro. This is a good lube for assembly and break-in. If you want to
switch to the latest synthetic after break-in, that's your choice.
Start with the neutral stopper arm.
Dogger315 cr500 engine build at www.oem-cycle.com 115.jpg (249.16 KiB) Viewed 19714 times
Install the lever and a new spring and washer. Torque the bolt (arrow) to 9 lb.ft.
Assemble the drum shifter components into the guide plate. Coat all the
components with clean gear lube. As I stated previously, these are new
pawls, springs and plungers that should be replaced at every rebuild.
Dogger315 cr500 engine build at www.oem-cycle.com 116.jpg (351.5 KiB) Viewed 19714 times
Install guide pin in the shift drum then install the drum center (Red arrow)
while holding the neutral stopper arm back with a screwdriver. Torque the
center pin (purple arrow) to 16 lb.ft.
Dogger315 cr500 engine build at www.oem-cycle.com 117.jpg (258.08 KiB) Viewed 19714 times
Set the drum center to a position other than neutral and install the
pre-assembled guide plate with the drum shifter over the center pin (Red
arrow), while holding on to the rachet pawls. Torque the three retaining
bolts (Blue arrows) to 10 lb.ft.
Dogger315 cr500 engine build at www.oem-cycle.com 118.jpg (294.09 KiB) Viewed 19714 times
Assemble the kick start assembly as shown.
Dogger315 cr500 engine build at www.oem-cycle.com 119.jpg (113.75 KiB) Viewed 19714 times
Place the kick start assembly in the case and wind the new return spring clockwise until the end can be inserted into the case.
Dogger315 cr500 engine build at www.oem-cycle.com 120.jpg (138.6 KiB) Viewed 19714 times
Install the idler gear (Blue arrow)and bushing (Red arrow) after coating both with gear oil.
Dogger315 cr500 engine build at www.oem-cycle.com 121.jpg (310.42 KiB) Viewed 19714 times
Place the shifter collar on the drum shifter (Blue arrow). Assemble the
gearshift spindle return spring, snap ring and thrust washer and install
straddling the case pin as shown.
Dogger315 cr500 engine build at www.oem-cycle.com 122.jpg (272.29 KiB) Viewed 19714 times
Coat the clutch outer guide with gear oils and install.
Dogger315 cr500 engine build at www.oem-cycle.com 123.jpg (212.4 KiB) Viewed 19714 times
Coat the needle bearing with gear oil and install.
Dogger315 cr500 engine build at www.oem-cycle.com 124.jpg (215.46 KiB) Viewed 19714 times
Install the primary drive gear (Red arrow) and bolt/washer (Green arrow).
Install the clutch outer (Purple Arrow). Place a gear jamming device
(Yellow arrow) between the primary gear and clutch drive gear as shown
and torque the primary drive gear bolt (Green arrow) to 33 lb.ft.
Dogger315 cr500 engine build at www.oem-cycle.com 125.jpg (259.63 KiB) Viewed 19714 times
That's everything on the right side.
Dogger315 cr500 engine build at www.oem-cycle.com 126.jpg (224.29 KiB) Viewed 19714 times
Oil and install the two dowels (Red arrows) and a new gasket.
Dogger315 cr500 engine build at www.oem-cycle.com 127.jpg (217.36 KiB) Viewed 19714 times
Install the right side case cover, torquing the bolts to 7 lb.ft. in several
steps and in a criss cross pattern. If you are using ti bolts, make sure you coat
them with grease or ti prep prior to installation or you may never get them out
in one piece.
Dogger315 cr500 engine build at www.oem-cycle.com 128.jpg (197.79 KiB) Viewed 19714 times
Oil and insert the two dowels as shown
Dogger315 cr500 engine build at www.oem-cycle.com 129.jpg (197.7 KiB) Viewed 19714 times
Place a new gasket on the water pump housing followed by the separator
plate.
Dogger315 cr500 engine build at www.oem-cycle.com 130.jpg (185.03 KiB) Viewed 19714 times
Place a second gasket on the separator plate.
Dogger315 cr500 engine build at www.oem-cycle.com 130.jpg (185.03 KiB) Viewed 19715 times
Install the water pump cover and torque the bolts to 9 lb.ft.
Dogger315 cr500 engine build at www.oem-cycle.com 131.jpg (181.52 KiB) Viewed 19715 times
That's it for this time. Next, the clutch and ignition.
