Cleaning up a front brake assembly
Posted: Thu Feb 19, 2015 11:57 pm
Ok... DO I really need to say it again????
Ok, Ok...
First and foremost.... Ignore every thing I say.
I am not a professional mechanic, I have no training, and generally I ride stuff that is completely unsafe and I do things that should never be done.
So, here is what I am starting with..
oem-cycle.com kx250 front brake clean up 101.JPG (79.49 KiB) Viewed 7029 times
oem-cycle.com kx250 front brake clean up 102.JPG (76.6 KiB) Viewed 7029 times
oem-cycle.com kx250 front brake clean up 103.JPG (43.86 KiB) Viewed 7029 times
Re: Cleaning up a front brake assembly
Posted: Fri Feb 20, 2015 10:21 pm
Ok, now I have the assembly clean enough to take it apart and not have to worry about contaminating the insides.
True, I will have to clean the insides anyway but why make the job any worse?
oem-cycle.com kx250 front brake clean up 106.JPG (83.65 KiB) Viewed 7025 times
