KX250 1999 bad piston needs rebuild
Mechanical problems discussed for Dirt Bikes and Dual Sport Bikes
A customer came in with a bike that seized a piston.
Upon getting the bike apart we found that the cylinder was heavily ported.
I don't do much with the 250's but judging from what I see, somebody got carried away....
The customer said up until it seized it ran good.
I don't know, what do you think?
The transfers are very crude but could be cleaned up some.
kx250 99 cylinder ported 101.JPG (112.38 KiB) Viewed 7772 times
kx250 99 cylinder ported 102.JPG (81.1 KiB) Viewed 7772 times
kx250 99 cylinder ported 103.JPG (91.35 KiB) Viewed 7772 times
kx250 99 cylinder ported 104.JPG (62.98 KiB) Viewed 7772 times
Re: KX250 1999 bad piston needs rebuild
kx250 99 cylinder ported 105.JPG (52.17 KiB) Viewed 7771 times
kx250 99 cylinder ported 106.JPG (54.11 KiB) Viewed 7771 times
kx250 99 cylinder ported 107.JPG (50.29 KiB) Viewed 7771 times
So it looks to me like they were trying to achieve more top end but went to far..
Then... they added a fly wheel weight to it...
I don't know what the port timing is but I could degree it.
Return to “Mechanical problems”
