There's the outside cover pic you're referring to I believe.
If you pick the right stator one should be plenty, I found a stock hayabusa stator puts out 400 watts & a stock rzr stator is 500 watt. By the time I buy the newer 250 ignition $150 ,0$ if you're using what you already have though , & $150 for the other stator bits it really would be smarter just to cough the $500 for the mbz ,
I is probably not that smart though. Hence my next question, the magnetic polarity of the 2 stators side by side, would they need to be repellent or attractive, or would being on 2 different planes / diameter make that moot?
