I have a set of TM wheels.
No idea what they fit I have some measurements.
Rear
18 x 2.15 rim
Axle diameter: 20mm
Outside to outside of the bearings: 152.5mm
Rotor OD: 220mm
Rotor ID: 114.98mm
Rotor bolt pattern: 6 on a 128.5mm (approx) bolt circle
Sprocket ID: Approx 107mm
Sprocket bolt pattern: 9 on a 124mm (approx) bolt circle
Front
21 x 1.6 rim
Axle diameter 20mm
Outside to outside of the bearings: 106mm
Floating rotor
Rotor OD: 270mm
Rotor bolt pattern: 6 on a unequal 90mm (approx) bolt circle
TM wheel specs
Need or have information, Specs, or measurements?
Return to “MEASUREMENTS PICS & SPECIFICATIONS”
