Head studs or head bolts?
Posted: Thu Jan 02, 2014 4:20 am
KXpegger posted this info at kxriders and I thought it was a great explanation as to why studs should be used:
Torque Efficiency
During engine assembly or maintenance, a bolt must be installed by torqueing it into place. Due to the head bolt’s design, it has to be rotated into its slot in order to engage the threads and secure it into place. This process creates both twisting force and a vertical clamping force, which means that when the cylinders within the engine’s combustion chamber begin accumulating load, the bolt will both stretch and twist. Because the bolt has to react to two different forces simultaneously, its capacity to secure the head is slightly reduced and it forms a less reliable seal in high-powered engines.
By contrast, a head stud can be tightened into place without any direct clamping force applied through the tightening. A stud can be threaded into a slot up to “finger tightness,” or the degree to which it would be tightened by hand. Afterward, the cylinder head is installed and a nut is torqued into place against the stud. The nut torque provides the clamping force, rather than the torque of the fastener itself, and the rotational force is avoided entirely. Because the stud is torqued from a relaxed state, the pressure from the nut will make it stretch only along the vertical axis without a concurrent twisting load. The result is a more evenly distributed and accurate torque load compared to that of the head bolt. This ultimately translates into higher reliability and a lower chance of head gasket failure.
I believe the original article was written here:
http://www.thomasnet.com/articles/hardw ... stud-bolts
