CR250R HONDA TECHNICAL SPECS
STATOR AND COIL ELECTRICAL PULSE GENERATOR COIL OHM SPECS
1981 CR250R CR450R
1982-1983 CR250R CR480R
1984-1985 CR250R CR500R
1986 CR250R
1986 CR500R
1987 CR500R
ELECTRICAL SPECS.jpg (543.67 KiB) Viewed 8314 times
CR250R HONDA 90-91 STATOR OHM SPECS
BLUE/YELLOW TO GREEN WHITE 180-280 OHMS
93-96 CR250R STATOR SPECIFICATIONS
BLUE TO WHITE 120-220 ohm
BLUE/YELLOW TO GREEN/WHITE 180-280 ohm
97-98 STATOR SPECS
BLUE TO WHITE WIRE 2-20 OHMS
BLUE/YELLOW TO GREEN/WHITE 180-280 OHMS
YELLOW TO YELLOW/WHITE 1-5 OHMS
02-07 CR250R Stator Ohm Specs
Stator Coil
Yellow to White .5-4 ohms
Pulse Generator
Blue/yellow to Green/white 180-280 ohms
Re: CR250R HONDA TECHNICAL SPECS
97-98 STATOR SPECS
8-21-16 added
Stator Coil
Pulse Generator
