Hot Rod...KX500
sandmaster995
Hot Rod...KX500
Post by sandmaster995 »
Am I reading the WPS book right?.......85-04 Con-rod kits are the same for K5's (hotrods) p/n 421-8148
Going to order today, maybe early next week. Unable to find big end bearing listed by itself. Where would you get one?
Re: Hot Rod...KX500
Yep, the 85-04 connecting rods are the same.
You can verify with Hot Rods here:
http://www.hotrodsproducts.com/ProductI ... tem_id=902
You will find that from 89-04 the engines only have minor changes such as fly wheel and rotor, shift shaft, and shift lever.
It's hard to improve upon perfection :D
I have never seen a big end connecting rod bearing available without the connecting rod.
Then again if you go to the Hot Rods web site link above, you can get the sizes except the pin.
I can get you the pin size.
Then you could contact a bearing house and see what they could get.
The washers will be hard to find...
What did your side play measure at the big end?
Re: Hot Rod...KX500
Post by Motorrad »
Hot rods + k5 = broken cases
sandmaster995
Re: Hot Rod...KX500
What would you suggest, OEM ?
Re: Hot Rod...KX500
If I had no access to another rod I would go OEM way before Wiseco or Hot Rods.
I typically only use Wiseco or Hot Rods for interchange info...
I see a lot of both of those companies cranks destroyed.
I see a lot of OEM's worn out but not real often are they broke.
These guys built my last crank.
http://www.pinsonnaultracing.com/
Pinsonnault Racing
22 A Street
P.O. Box 79
West Warren,MA 01092
Phone:1-413-244-1936
Balance/Rebuild/Weld/True $225 plus return shipping ($15). Rod Kit $110 extra if not supplied.
That was as of Nov 30th 2012
sandmaster995
Re: Hot Rod...KX500
Thanks for the info. I never would have imagined branding such as those would not be at least "decent".
I am curious though..... What rod would pisonnault use? That deal is sounding more sweet by the minute.
Re: Hot Rod...KX500
That's a good question.
I believe he said OEM, Vesrah, and one other but I could be wrong.
Give him a call and let us know :?
Re: Hot Rod...KX500
I think he uses Pro X as well....
Re: Hot Rod...KX500
Post by Motorrad »
If it was my motor. Oem , versah , ims. In that order
sandmaster995
Re: Hot Rod...KX500
Thanks guys. Knowledge is gooood !!!!!!!! Albeit painful and expensive. :lol:
