This article was wrote by 81cr450. I just transferred a bunch of it
I'm pretty good with motors , but the shiney stuff is not my thing. So this is only halfway. I may powdercoat eventually but so far it's just to get it running & riding
What I bought was a 93 rmx250. I like the wide ratio trans of the RMX & Guy Coopers' whip in the early 90's Dirtrider always had me wanting an RM. I'm more of a big bore 2-stroke guy so the motor really needed to be breathed on a bit. I ended up just using the 93 trans & clutch. The jug is from a 91 RM which has the biggest exhaust port of the series. The case & crank are 1995 because they started using crank stuffing in the later motors. The head is a 95 rm because it actually has a squish band. I'm using VF3 reeds because they reduce crankcase volume too. I would have done some stuffing but I am lazy.
Here I gotta say thanks to Bix & Mike Wier. Mike runs OEM-CYCLE. I'm not sure what his Dad , Bix', place is called but these 2 gave me a smoking deal on the crank & jug. Both parts were to me in 3 days.
I had others supply parts but these guys stood out.
I'm also using a new PSI pipe I found on ebay for $125 shipped, talk about SCORE.
I intend to dual-sport this for a bit , but as with anything I build its always for sale. As part of the dual sporting I went with a KTM LC4 tank & grafted it to the bike. I figure I need the extra range of more fuel. I really wanted a 6.6 gallon 2003 yz250/450f tank but couldnt find one so I took what was cheap.
My photos will start with the motor & I'll kinda go from there as I complete the build. The handle bars on these are way far back & I have a trick for that. The plastic & seat cover colors that are available now dont match the old suzuki yellow & I have a few tips on that.
I do have a question though , have any of you used permatex anti-sieze on your powervalves. I've been using it on my last 3 powervalve motors & it takes a few rides to really loosen up but once it does it works quite nice. It kinda helps keep you from beating on a fresh motor because the powervalves dont react as fast as normal so you kinda ride a DOG till the lube melts in .
Sorry for the long post but I'm kind of a Blatherer
On the piston I windowed it & dropped the boysen port before the replate. On a kx500 it equals 2.5 hp in the mid range. The reason I think it works like that is if you think of swinging a bucket to keep the water in the bottom the highest point of pressure is in the very bottom so a window relieves this hgih pressure point.
- rmx250 1.png (302.43 KiB) Viewed 13509 times
The piston is also skirt coated with an antifriction coating & ceramic on top
Here's the boysen port drop
- rmx250 2.png (226.81 KiB) Viewed 13509 times
Powerseal does beautiful work as well.
Heres where the bike is at
- rmx250 3.png (387.56 KiB) Viewed 13509 times
Yes it's in my kitchen & yes its a work in progress. You can see the tank on it at this point but the shrouds still need to be attached.
The 91 jug needed some port work to smooth out the powervalve area & the powervalves had to be relieved as I went 2mm overbore
- rmx250 4.png (216.16 KiB) Viewed 13509 times
You can see the rechambered head above as well & below here you can see how the everthing is flush when the valves are open, they were 1/4 inch deep before the work.
- rmx250 5.png (178.14 KiB) Viewed 13509 times
The RMX is know for having excellent fuel economy due to such a small exhaust window, you can kind of see it here when the powervalves arent open
- rmx250 6.png (186.87 KiB) Viewed 13509 times
