Bonding Aluminum
Posted: Wed Apr 17, 2013 5:28 am
Bonding Aluminum.
With a little research I found several Aluminum glues.
Then it occurred to me, why not use Loctite?
That stuff is brutal, but which kind?
That would depend on your project.
I'm thinking about the 2 piece clutch cover project.
The problem is expansion, oil immersion, bonding surface contact size, vibration, and temperature fluctuation (Probably a few more).
As well as Loctite holds together bearings to shafts, ect I'm wondering if it wouldn't work.
http://www.henkelna.com/industrial/prod ... 0000000389
Any thoughts?
Any thoughts?
