i have a 1994 yz125 i need a crankshaft assembly. i cant fi
Posted: Fri Mar 22, 2013 2:28 am
Question from customer:
hi im adam.
i cant find one any where but i have found a 94 yz250 crank.
would that fit.
hopefully you can help me out.
thanks
Answer:
Hello Adam.
Unfortunately there is no way the YZ250 crank will fit in your 125.
According to the book only a 94 yz125 crank will fit.
If your crank halves are good you can have a new rod kit pressed in.
I would contact the guys at Pinsonnault Racing
http://www.pinsonnaultracing.com/
They do quality work at reasonable rates.
hi im adam.
would that fit.
thanks
Answer:
Hello Adam.
