KX250 KAWASAKI SPECIFICATIONS
88 KX250 STATOR SPECS
Black/white to Black Yellow 432-648 ohms
White/Red to White/Green 7.7-11.5 ohms
89 KX250 STATOR SPECS
Black/white to Black/Yellow 376-564 ohms
White/Red to White/Green 188-283 ohms
90 KX250 STATOR SPECS
Red to Black/Red 417-627 ohms
White to ground 14.3-21.5 ohms
91 KX250 STATOR SPECS
Red to Black/Red 359-539 ohms
92-97 KX250 STATOR SPECS
White/Red to White/Green 396-594 ohms
Red to Black/Red 288-432 ohms
White to Red 14-21 ohms
98 KX250 STATOR SPECS
00-01 KX250, 00 KX125 STATOR SPECS
While to Red 7-15 Ohms
Yellow/While to Yellow 1-5 Ohms
COIL SPECS
1991 KX250 COIL SPECS
PRIMARY (Small wire) 11.0-.15 ohms
Secondary (Spark Plug) 3500-4700 ohms
1994 KX250 COIL SPECS
PRIMARY (Small wire) .26-.36 ohms
99-02 KX250 Ignition Coil Specs
Primary (Small wire) .53 ohms +/- 15% at 20c
Secondary (Spark Plug) 12,600 ohms +/- 15% at 20c
IGNITION TIMING
1992-1994 14 DEG BTDC @ 6000 RPM.
Engine Specs
92-00 KX250 Crank Shaft Service Specs
Connecting rod big end side clearance New .45-.55mm or .018-.022" Service Limit .7mm or .028"
Connecting rod small end inside diameter New 22.003-22.012mm or .8663-.8666" Service Limit 22.05mm or .868"
Connecting rod radial clearance New .037-.049mm or .0015-.0019" Service Limit .1mm or .004"
Crankshaft runout limit New .03mm or .001" Service Limit .05mm or .002"
Transmission Service Specifications
92-2000 KX250
Shift Drum Grove Width New 6.05-6.20mm or .2381-.2441" Service Limit 6.25mm or .246"
Shift Fork Finger Thickness New 4.40-4.50mm or .173-.177" Service Limit 4.3mm or .169"
Shift Fork Guide Pin Diameter New 5.90-6.00mm or .2323-.2362" Service Limit 5.8mm or .228"
Sliding Gear Shift Fork Groove Width New 4.55-4.65mm or .179-.183" Service Limit 4.75mm or .187"
KX250 Needle information and comparison chart
jet needle size chart.jpg (132.55 KiB) Viewed 29133 times
2003 KAWASAKI KX250 Sea level using 32:1 Premix
03 KX250 KAWASAKI STOCK AND AFTER MARKET JETTING.JPG (12.96 KiB) Viewed 29095 times
2004 KAWASAKI KX250 Sea level using 32:1 Premix
04 kx250 jetting chart.png (5.29 KiB) Viewed 29083 times
Re: KX250 KAWASAKI SPECIFICATIONS
4-10-13 Started adding Transmission Service Specifications for the 92-00 KX250
KX250 connecting rod numbers
74-82 kx250 13044-5007 still available
83-84 kx250 13044-5045 not available
85 kx250 13044-5042 not available
86-93 13044-5056 still available
94-96 13032-1076 not available
97 13032-1224 still available
98-99 13032-1236 still available
00-01 13032-1263 not available
02-07 13032-1279 still available
Hot rod Rods FITS 92-04 KX250 4017
7-17-13 carb needle info added.
8-3-13 added 2004 KAWASAKI KX250 Sea level using 32:1 Premix
Added stator specs for a 1989 kx250
Black/white to Black Yellow 376-564 ohms
White/Red to White/Green 176-264 ohms
Added 1988 KX250 stator specs
1999 2000 2001 2002 KX250 CRANKSHAFT AND ROD SPECIFICATIONS
CRANK AND ROD SPECS.JPG (46.36 KiB) Viewed 27603 times
CRANK AND ROD SPECS 2.JPG (47.69 KiB) Viewed 27603 times
CRANK AND ROD SPECS 3.JPG (17.67 KiB) Viewed 27603 times
CRANK AND ROD SPECS 4.JPG (42.61 KiB) Viewed 27603 times
CRANK AND ROD SPECS 5.JPG (12.9 KiB) Viewed 27602 times
1996 KX250 SPECIFICATIONS
1996 KX250 SPECS.jpg (169.6 KiB) Viewed 27431 times
1997 KX250 SPECIFICATIONS
1997 KX250 SPECS.jpg (166.73 KiB) Viewed 27431 times
1998 KX250 SPECIFICATIONS
1998 KX250 SPECS.jpg (130.46 KiB) Viewed 27431 times
1999 KX250 SPECIFICATIONS
1999 KX250 SPECS.jpg (131.42 KiB) Viewed 27431 times
2000 KX250 SPECIFICATIONS
2000 KX250 SPECS.jpg (131.84 KiB) Viewed 27431 times
2001 KX250 SPECIFICATIONS
2001 KX250 SPECS.jpg (127.33 KiB) Viewed 27431 times
2002 KX250 SPECIFICATIONS
2002 KX250 SPECS.jpg (131.46 KiB) Viewed 27431 times
2003 KX250 SPECIFICATIONS
2003 KX250 SPECS.jpg (124.21 KiB) Viewed 27431 times
