31120-MG2-015 XL600R STATOR PICS AND SPECS
Posted: Mon Mar 04, 2013 11:04 pm
FITS 83-87 XL600R 31120-MG2-015
Please take all measurements with the stator grounded.
The easiest way is to leave it attached to the engine.
Charging coil:
Check for continuity between the Pink and yellow wires.
The Ohms should be .95-1.29
Lamp Coil
Check for continuity between the white/yellow wire and ground.
The Ohms should be .4 - .55
STATOR MEASUREMENTS AND OHM SPECS.JPG (71.42 KiB) Viewed 7372 times
