KX500 WR or overdrive transmission, is it possible?
Posted: Mon Nov 26, 2012 2:28 am
KX500 WR (Wide Range) or overdrive transmission, is it possible?
Yes it is.
Just think how nice it would be to have a lower 1st and a longer 5th.
With top speeds approaching 120mph that should make just about all hard core mxer's happy.
As the saying goes, "Speed is only a question of money"
Here is an article from kxriders that goes into some detail.
It has comments from the guy that built the kx500 with the current land speed record.
http://www.kxriders.com/forums/index.ph ... 842.0.html
From the members at KXriders I have found that the gears are not available.
You can beg all you want but few members have them and they aren't selling.
Having a set made would be very expensive.
There was some talk of the KLX C and R models and possibly the KLR650's having a higher ratio that might work.
Well, I intend to see what the real deal is and let you know conclusively.
Yes it is.
