The 2008 RMZ Triple Clamps may be a viable swap, assuming that the RG3 and OEM Suzuki Clamps and Stem are dimensionally similar. I put a set of RG3 Billet clamps on a KDX220. (They were picked up for real cheap). They did require significant machining to the surface the bottom bearing sits on to allow enough depth for thread engagement. Some people may not be happy with the thread engagement that is left for the top nut, as the nut is flush to the top of the stem and no additional thread protrude.
The steering stop was rather easy with this setup. I was able to drill, tap, and use a high grade nut and bolt to create the stops.
I do have some pictures that I will post up.
Re: 2008 RMZ Triple Clamps
Yes, please post some pics.
You can make just about any set of clamps work.
Call Emig Racing and they can make you a custom steering stem.
816-520-5665
816-520-5665
