This is a panthera Motorsports Kawasaki kx500 complete starter kit. The starter kit is in good working condition with normal signs of use. It was on the bike for approximately 4 hours of light use. Electrical harness and battery box are custom made with no need for modification of air box and is designed to go under the seat. Panthera Motorsports does not offer the wiring harness or battery box which makes for a tough install. This kit is ready to go, you will just need a battery. I used the antigravity XPS battery. This kit is used and sold as is. NO REFUNDS. This kit cost over $2300.00 after all electrical and battery box were made.
I am not liable for any improper install or damage to vehicle.
What is included:
-Power dynamo complete ignition system
-Panthera fly wheel cover
-Power dynamo flywheel with starter gear
-Starter
-Coil adapter plate to mount in OEM location
-CRF450x starter relay
-Complete wiring harness (not provided by panthera)
-Starter button
-Battery box
-Directions
All information on this kit can be found on their website at: www.pantheramotorsports.com
$1400 with free shipping in the U.S
Panthera KX500 electric starter
- Attachments
- starter 3.jpeg (108.08 KiB) Viewed 25716 times
- starter 2.jpeg (109.71 KiB) Viewed 25716 times
- starter.jpeg (113.85 KiB) Viewed 25716 times
Re: Panthera KX500 electric starter
I haven't used mine yet and your selling it
What's up?
What's up?
I would offer you $1100. Not sure if you can PRIVATE MESSAGE on this site.
Thanks, Ted
Thanks, Ted
Yes, click on his user name.Tedb wrote: Wed Apr 10, 2019 4:14 am I would offer you $1100. Not sure if you can PRIVATE MESSAGE on this site.
Thanks, Ted
Then, click on the PM
Luckydogfab
I don’t suppose this is still available?
