Assembling K5 KIPS
Posted: Wed Nov 21, 2018 4:48 pm
I just got done watching the KX Guru videos and I have a couple of questions...
1. Does it matter if you use grease when assembling or 2 stroke oil? Seems to me that everything gets coated with oil when running anyway so... I use oil.
2. I noticed that the ports looked different than mine. I'm assuming that was a modified cylinder? Which lead me to my last question...
3. It may have been the lighting or the camera angle or whatever but when actuating the rod in that video, was the port actually fully closed/blocked?
I spent a lot of time making sure the travel of my rod was limited because it seemed that the valves were over-rotating and the ports were exposed (open) a little. Its my understanding that at low RPM the flap should be down and the ports fully closed and everything starts to open up with increased RPM.
Someone please let me know. Thanks in advance.
