KX500 KOYO TO NSK BEARING NUMBERS
Posted: Fri Jun 15, 2018 6:51 pm
Ok... Recently some Koyo bearings were purchased that turned out to be bad even though they were brand new.
Motorrad gave me this interchange list of bearings from Koyo to SKF
I ordered all these and they all worked great.
so... here it is..
Ordered a bunch of parts today including all the snap rings for the transmission
Tomorrow I am ordering all the bearings from Motorrads list:
Main bearings.
KIPS bearings
Water Pump
Clutch Pressure plate
Shift Drum bearing
Transmission LEFT CASE
Transmission RIGHT CASE
(special note on this bearing... A LOT of the ones out there now have a Plastic cage... Request a metal one, and CHECK IT before you leave
I Just don't trust plastic cages in transmissions....)
so... here it is..
Main bearings.
KIPS bearings
Water Pump
Shift Drum bearing
