PWK carb trouble Mid Body O-ring style Jet block gasket replacement
Posted: Fri Jun 15, 2018 4:12 am
Have you replaced almost everything in your carb and you still can't get your bike to run right?
Lean one minute and rich the next?
If you have a older PWK carb you likely need to replace this o-ring style gasket.
https://www.youtube.com/watch?v=t35AApTJY9s
Re: PWK carb trouble
Posted: Fri Jun 15, 2018 4:17 am
You can get the Jet block o-ring gasket on eBay.
There are two different ones depending on the carb.
I found some on eBay and bought a few :lol:
Standard PWK and Long body Air Striker
Jet block o-ring #1 Keihin PWK 33-41 carburetor / 35 36 38 39 40 mid body gasket
https://www.ebay.com/itm/Jet-block-o-ri ... Sw3Hxakr82
Short body
Jet block o-ring #2 short body Keihin PWK 36 38 carburetor mid body gasket
https://www.ebay.com/itm/Jet-block-o-ri ... SwVnlakr8s
Posted: Mon Jul 19, 2021 3:55 pm
