Page 1 of 5
KX Guru Racing JT Engine Works KX500 Induction Crank testing
Posted: Wed May 16, 2018 12:23 am
I know, I know... Turbo Cranks have been out for 40 years and they don't work and are a waste of time and money... Except.... We have a Steve Paris Turbo Crank up and running in "Project Clapped out 1998 KX250... what works?" and have shown a 15-20% gain on a broad range of RPM's :shock: :o :shock: We have more testing to do but so far I'm really excited about this.
So much so that I'm going to duplicate the experiments on my KX500..
Steve Paris is the only person to have a Patent on the Turbo Crank idea.
He contacted me about 2 years ago and we talked a bit about how it works, and why it works when so many others did not.
Steve's design acts like a compressor, not a sweeper... Most of the designs I have seen try to fan or sweep the charge up the transfers.
Steve's design compresses the charge and then directs it up the transfers.
I gave it many, many nights of thought as to why it would work when others failed.
I came to a conclusion that the only way it could work was that the cases had to be modified as well as the crank.
So I called Steve and sure enough.... I was right. Yes, sometimes I get lucky.
Here we are, the test bed.
This is my 01 KX500 Supermoto that has had a fair amount of riding done on it.
I hadn't ran it in about a year and a half.
In fact, I think Oscar Cota was the last to ride it down at his place in So Cal when we were putting Sean Colliers bike together..
We robbed a bunch of parts off it for Sean's bike and I just haven't had the time to get it all back up and running.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 101.jpg (555.67 KiB) Viewed 18278 times
Re: KX Guru Racing JT Engine Works KX500 Turbo Crank testing
Posted: Wed May 16, 2018 12:41 am
While I was putting it back together I installed some Myler radiators which are high quality and made in the USA.
I mixed up some new 92 Methanol free gas with Motul 800 at 50:1.
Then Jason took it for a test ride to make sure nothing happened while the bike was in storage.
https://youtu.be/222Db_47z9M
Posted: Wed May 16, 2018 12:44 am
Here is a vid of Jason blowing the cob webs out..
https://youtu.be/_yVJMAcxiEo
Posted: Wed May 16, 2018 6:55 am
by Brute
Hey! I remember that one! :lol:
Hope all is well with you and yours. I will be interested in watching the build.
Posted: Wed May 16, 2018 2:26 pm
She still runs great.
I was a bit shocked to see that the cylinder pressure was at 145lb before we ran it.
We will test it again right after the first series of dyno pulls.
Then, we will test it again before and after our next series of dyno pulls.
If the Turbo Crank mods work like they did on the 250 we should see somewhere from 10-30psi increased pressure.
And from there I have a whole series of case mods to try and will continue to make some additional mods to the cylinder, head, and pipe, to see what all we can get out of it within reason... I still want to be able to ride it lol...
The goal is not to build another drag bike.
I don't want anyone to be able to beat Jeff Grawbarger :lol:
I want a good series of proven mods that Jason can offer for reasonable established prices.
HP = $ :shock:
But more then anything, I just want to know and make my own bikes incredible to ride.
Posted: Sat May 19, 2018 4:30 pm
Here is the plan.
Jason and I will tear the engine down and clean the parts of the bottom end...
The top end will be rinsed off and the top of the piston cleaned.
We will not be cleaning the exhaust valves other then rinsing them off.
We will not replace any bearings, or seals.
We will replace at least the base gasket but not much more.
Posted: Sat May 19, 2018 4:36 pm
Sitting on the dyno... strapped down and ready..
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 110.jpg (443.38 KiB) Viewed 18231 times
4 pulls and threw out the top one...
first dyno series.jpg (108.66 KiB) Viewed 18231 times
48 RWHP.
For a worn out top end that's about what you would expect from a completely stock KX500.
If the engine was completely fresh you can expect 52-55 RWHP from what others have told me.
Some people will want to point out that Kawasaki claimed 63HP but that is Crank HP.
You will loose a bit through your clutch, transmission, chain, sprockets, and rear tire.
So, I don't care about what it is at the crank.
I want to know what my tire is transferring to the ground 8-)
Posted: Sat May 19, 2018 4:44 pm
Got it home from the dyno about 3pm and started disassembly.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 111.jpg (562.62 KiB) Viewed 18229 times
Check out the plug... it's no bad considering the blow by we were getting.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 112.jpg (134.95 KiB) Viewed 18229 times
The engine is out..
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 113.jpg (568.99 KiB) Viewed 18229 times
And sitting on the bench.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 114.jpg (432.4 KiB) Viewed 18229 times
Posted: Sat May 19, 2018 4:51 pm
One of the few after market parts is a Power Dynamo ignition system so we need to be careful and use the same settings.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 115.jpg (419.3 KiB) Viewed 18228 times
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 116.jpg (278.84 KiB) Viewed 18228 times
Documented :shock:
Posted: Sat May 19, 2018 4:54 pm
The top end is actually pretty clean considering it's age.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 117.jpg (373.56 KiB) Viewed 18227 times
The piston top is.... dirty..... :D
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 118.jpg (181.5 KiB) Viewed 18227 times
As you can see, the blow by is significant.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 119.jpg (299.54 KiB) Viewed 18227 times
The exhaust valves operate smoothly but could use a good cleaning and adjustment, but, we are not going to clean, adjust, or replace anything.
KXGURU RACING JT ENGINE WORKS KX500 TURBO CRANK TESTING 120.jpg (241.88 KiB) Viewed 18226 times
