TSR RACING KX500 AND CR500 BILLET AWESOMENESS :-)
Posted: Wed Jan 10, 2018 10:20 pm
Outstanding quality... Buy with confidence..
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASES 108.jpg (483.97 KiB) Viewed 15856 times
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASES 107.jpg (432.94 KiB) Viewed 15856 times
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASES 106.jpg (406 KiB) Viewed 15856 times
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASES 104.jpg (353.07 KiB) Viewed 15856 times
KX GURU RACING TSR BUILT BILLET KX500 ENGINE CASES 103.jpg (316.89 KiB) Viewed 15856 times
Re: TSR RACING BILLET AWESOMENESS :-)
Posted: Wed Jan 10, 2018 10:21 pm
Billet KX500 ignition covers..
KX GURU RACING.COM 2016 KTX500 BUILD 232.JPG (46.75 KiB) Viewed 15855 times
KX GURU RACING.COM 2016 KTX500 BUILD 233.JPG (49.93 KiB) Viewed 15855 times
Re: TSR RACING KX500 AND CR500 BILLET AWESOMENESS :-)
Posted: Wed Jan 10, 2018 10:23 pm
CR500...
Posted: Wed Jan 10, 2018 10:25 pm
Posted: Wed Jan 10, 2018 10:45 pm
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 175.jpg (62.16 KiB) Viewed 15851 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 176.jpg (88.6 KiB) Viewed 15851 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 177.jpg (84.63 KiB) Viewed 15851 times
KX GURU RACING 2016 KTM 250SXF KX500 CONVERSION 178.jpg (67.21 KiB) Viewed 15851 times
Posted: Mon Jan 15, 2018 11:53 pm
Since all you KX500 guys don't have a Clutch master cylinder to use from your KX500 you will need to get a new one.
But which?
Troy at TSR sent me the following:
Magura master cylinder with mineral oil, 10.5
I just got a mold made to be able to get my own custom seals made so my slave cylinder will no longer use std o-ring
