HOW TO STRAIGHTEN YOUR DIRT BIKE RADIATOR
Posted: Tue Sep 25, 2012 2:38 am
HOW TO STRAIGHTEN YOUR DIRT BIKE RADIATOR.
Dirt bike radiators are very efficient at removing excess heat out of your engine.
They do this through the use of Aluminum and a lot of surface area.
The aluminum is very thin so they are very light.
All these factors contribute to efficient cooling but also contribute to easy bending, twisting, and denting.
So, here is the trouble:
Ever dropped your bike in the garage, ran into a tree, or cased a 120ft triple and took a denture adventure?
Now your shroud mounts don't line up and your radiators look like junk.
As you can see this radiator is bent like a banana, twisted, and shaped like a parallelogram and not a rectangle.
A new radiator will set you back some serious coin.
The cheap Chinese knock offs are not up to OEM specs and can leave you having to re-drill mounting holes.
If your radiator does not leak, here is a easy and inexpensive way to fix your dirt bike radiator:
That's right, some safety glasses, a cheap press, a old screw driver, and a nail puller that I flattened out the end on.
