Page 1 of 2
Customer jetting for a KX500
Posted: Mon Jun 26, 2017 3:17 pm
Doug Haas. Yes, The Doug Haas 8-)
This is Team Kawasaki’s jetting for back in the day:
Main Jet: 170
Pilot Jet: 55 or 58 if hard starting
Needle: N82M
Clip: 2
Slide: Modified to be 7.0.
Spark plug: B9EVX
Air Screw: 2.0 turns out
Race this setting from just about sea level to about 1,200 feet
Happy Motoring
Balanced, mild port, stock compression, Fatty desert pipe, Rad valve
4500ft
92 octane clear gas
52 pilot
170 main
NEEDLE-JET,N89D | 16009-1613 needle at the top position
All Stock engine, stock pipe, stock pipe
Sea level
110 fuel
160 main and a 50 pilot, stock needle
Same bike Running the quad vent airstriker, 162 main and a 45 pilot. 110 octane fuel. I think I could drop to a 42 pilot.
I can get it to idle with the air screw out 2.5 turns.
Re: Customer jetting for a KX500
Posted: Wed Jul 05, 2017 6:29 pm
by moto939
Glad you made this post so I could confirm what I'm finding....
2001 stock motor
Rad Valve and reed spacer
RM250 short body air striker with Boyesen power wing
1200-1500 ft
110 vp/93 premium-no ethanol
50:1 K2 Maxima
stock needle #2 clip #7 slide
160 main
started with a 52 pilot but could tell in the driveway way too rich, so went to a 45. But like you, needed to be 2.5 ish out on the air screw to get a decent idle. Ran ok, but could tell it was loading up and studdering at low speed. Was running low on time, but dropped in a #8 slide and took it for a quick spin. Big difference.....definitely ran cleaner and smoothed out that transition from low to mid. It ran like a different bike. :D I'm still going to drop to a 42 to get the air screw back into 1.5 or so. If you have any spare #7 slides laying around, it might be worth cutting one to a 8 just for a tuning option.
This carb has such a strong vacuum signal (not sure if that's the correct term or not) that I'm starting to wonder if the stock needle is the way to go. I may measure some of the needles I have and see if any are worth a try.
Posted: Wed Jul 05, 2017 8:20 pm
As soon as I get to mine I will record my findings.
Everything I have seen says that the short bodied air strikers when correctly tuned and jetted will give way better throttle response....
Posted: Tue May 08, 2018 8:18 pm
Leo Sadzewicz
So...
I’ve been doing a whole lot of jetting experiments, bought every needle, every jet, and every slide.
And I have successfully gotten rid of all lean surging.
I’m at 3825’
#55 pilot
N82M 4th(stock)
182 main
#9 slide (which actually cures the problem for higher elevations)
Perfect usable power from idle to the moon.
I know there’s gonna be naysayers, let the crap begin :lol:
Posted: Sun May 27, 2018 9:38 pm
Coby Hosford
5000’ running a N82L 3rd clip 62 pilot 168 main gets rid of that deceleration surge and replaces it with a tractor like acceleration smooth all the way to the top.
Posted: Mon Sep 30, 2019 7:13 pm
38MM AIR STRIKER CARBURETOR (LONG BODY)
Client back east.
Elevation 400 ft
48 pilot 165 main n82m in the 3 Rd position. #7 slide
Posted: Thu Oct 31, 2019 4:04 pm
38MM AIR STRIKER CARBURETOR (LONG BODY) Kawakaze
400ft
90 deg F
150 Main
45 pilot
Suzuki NECJ needle, second position from the top
#7 slide
Air screw 1.5 out
Posted: Sun Jul 26, 2020 2:45 am
All stock KX500...
New engine...
Motul 800 at 50:1 with Clear gas 92.
Jetting can and will vary depending on all the variables.
So, I don't recommend these specs unless you do throttle chops and read your plug to make sure you don't burn it up.
400ft.
Main 158,
Needle 2nd clip N82M,
7 slide,
52 pilot.
Temp 80f
We ran it in with a AFR gauge and were approx 13.0:1
We made 53.11 RWHP on the dyno..
Posted: Sat Sep 19, 2020 7:36 am
by kyser777
Sandblaster wrote: Mon Sep 30, 2019 7:13 pm 38MM AIR STRIKER CARBURETOR (LONG BODY)
Mathew Beauchamp
48 pilot 165 mine n82m in the 3 Rd position. #7 slide
what is the engine base , reed, etc... and riding condition
thinking to try the same with a 87 kx500 engine+spacer+vf2+gold gnarly cr500pipe... :D
thanks
Posted: Sun Sep 20, 2020 2:02 pm
Unfortunately that person has disappeared.
Most new airstrikers come with a 55 pilot and 170 main.
I'd start there and work my way down doing throttle chops to make sure how it is running.
