How to get nutty with a KX450F rear brake caliper
As some of you know I built the rear brake caliper for Sean Collier's new bike.
I learned several things the first time around so while some of this is a rehash, some of it is new.
First things first you will need a KX450F rear brake caliper... Any year will do up to at least 2012 :o
Next, strip it bare..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 101.jpg (357.92 KiB) Viewed 11012 times
{TIP} Use a air nozzle to blow the seals out... Most of the time you can re-use them.
Or just buy new ones as they are cheap..
Re: How to get nutty with a KX450F rear brake caliper
Put it in there..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 102.jpg (399.61 KiB) Viewed 11009 times
Use some of this on it..
Then some of that..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 103.jpg (417.44 KiB) Viewed 11009 times
It starts looking like this..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 104.jpg (453.49 KiB) Viewed 11009 times
No fancy mills or lathes.
I haven't even measured anything... All eyeball :shock:
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 105.jpg (349.93 KiB) Viewed 11008 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 106.jpg (365.35 KiB) Viewed 11008 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 107.jpg (343.4 KiB) Viewed 11008 times
It's starting to take shape..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 108.jpg (252.7 KiB) Viewed 11007 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 109.jpg (212.54 KiB) Viewed 11007 times
A little grinder work and..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 111.jpg (280.45 KiB) Viewed 11006 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 112.jpg (244.37 KiB) Viewed 11006 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 113.jpg (247.85 KiB) Viewed 11006 times
Ready for weld...
I've left a message with my welder..
We will see how long it will take for him to get back to me...
I received it back from the welder and started the clean up..
It's real rough right now but give it some time :-)
KX GURU RACING rebuilding the beast 122.jpg (311.74 KiB) Viewed 10971 times
KX GURU RACING rebuilding the beast 123.jpg (262.77 KiB) Viewed 10971 times
A little more progress..
KX GURU RACING rebuilding the beast 124.jpg (168.1 KiB) Viewed 10968 times
KX GURU RACING rebuilding the beast 125.jpg (162.89 KiB) Viewed 10968 times
Return to “Brakes”
